343
Xe em còi muốn tiết kiệm không gian nên định chơi quả âm ly 5 kênh cho cả 4 loa cánh và sub, các cụ xem giúp em nên chơi cái nào trong 2 cái sau:
Blaupunkt THA555 PnP :
THA Plug-n-Play Series 5-Channel Class D Car Amplifier
RMS Power Rating:
4 ohms: 55 watts x 4 chan. + 200 watts x 1 chan.
2 ohms: 65 watts x 4 chan. + 250 watts x 1 chan.
Bridged, 4 ohms: 150 watts x 2 chan. + 200 watts x 1 channel
Max power output: 110 watts x 4 chan. + 400 watts x 1 chan.
Wired remote bass level control included
LED power indicators
Tuned Bass EQ (0-12 dB bass boost)
5/4/3 channel operation
Speaker-level inputs
Preamp RCA outputs
Direct AUX input for secondary sources like MP3 players or DVD players. Especially significant if you do not have AUX input on your in-dash receiver.
Variable high-pass filter (50-250 Hz, 24 dB/octave)
Variable low-pass filter (10-250 Hz, 12 dB/octave)
Frequency response: 10-30000 Hz
Efficiency: 95 dB
Dimensions: 14"L x 6-1/4"W x 1-1/2"H
KICKER ZX700.5 :
Class D Multi-Channel Amplifier
RMS Power Rating:
4 ohms: 70 watts x 4 chan. + 210 watts x 1 Class D Sub channel
2 ohms: 85 watts x 4 chan. + 420 watts x 1 Class D Sub channel
4 ohms (bridged): 130 watts x 2 chan. + 420 watts x 1 chan. (2 ohms sub channel, 210 watts @ 4 ohms)
Peak Power Rating:
4 ohms: 140 watts x 4 chan. + 420 watts x 1 Class D Sub channel
2 ohms: 170 watts x 4 chan. + 840 watts x 1 Class D Sub channel
4 ohms (bridged): 260 watts x 2 chan. + 840 watts x 1 chan. (2 ohms sub channel, 420 watts @ 4 ohms)
Bass Boost Remote Control: 0 - 18dB at 40Hz
CEA-2006 Compliant
24dB per octave Crossover:
Active at 50Hz - 200Hz
High Pass, Low Pass, or Full-Pass selectable
4 gauge power/ground leads
Dimensions: 20"L x 9 5/8"W x 2 1/8"H
Em thank you các cụ!
182
RE: Âm ly 5 kênh các cụ xui em nên lắp cái nào?
bác đánh loa gì , model , bao nhiêu watt. ? Sub cũng thế. Rồi anh em mới tư vấn dc... bác muốn chi bao nhiêu tiền để AE còn định hướng. Tư vấn sai, lắp vào ko nghe hay mang tiếng lắm hahahaa.
Con kicker nhỉnh hơn nhiều.
343
Trích đoạn: khanhfat
Em cám ơn bác. Em định lắp 4 loa cánh Blaupunkt 50W Rms, Sub Blaupunkt 250W Rms. Amly cho Sub có cần phải >250W không bác?
419
27
Cao Lãnh
@bác Công Nông: bác đã lắp chưa?
Nếu đầu đọc đĩa của bác là DVD có sẵn DTS hoặc 5.1 thì nên chọn ampli 5.1. Nếu lắp tôi sẽ chọn Blaupunkt :)
367
Bác đi xe gì vậy,nếu bác muốn tiết kiệm không gian trên xe thì có loại của sony nè bác:Cái này loại mono 1S
Loại này 4 kênh 4S:
c
Hai loại này nhỏ,tiết kiệm được không gian trên xe nhiều lắm bác ah.
182
lắp con kicker vẫn chuẩn hơn. tai vì xe ko phaỉ lúc nào cũng chạy điện ổn định cho 50w stable đâu bác. Gắn con kicker thì sẽ lơị hơn nhiều power vì khi ampli nóng power sẽ mất đi đôi chút nên vưà đủ kéo loa bác hay. Luôn xài watt cuả ampli cao hơn loa chút để đảm bảo loa đánh hết khả năng. Bác nên mix match nhiều loại khác nhau đi cùng hãng ko hay lắm nhất là blaupunk ampli chỉ loại vưà cho ng muốn add ampli vào system có sẵn cuả xe thôi.
696
360
HCMC
Trích đoạn: Công Nông
nếu bác đã chơi loa của Blaupunkt thì chơi luôn amplier của nó cho đủ bộ và cùng chũng loại.....:)....
182
do^ng` bo^. loa is hit and miss hang tot nghe hay.... hang vua` vua` nen chon loai ngon hon cho o^~n.
360
70
baosinh nói:
Tôi không thạo về mặt này, nhưng bác thử ra 20 Ngô Quyền (Hà Nội) gặp bác Tùng, hoặc 1 Lê Văn Lương (Hà Nội) gặp bác Thịnh, xem các bác ấy tư vấn thế nào?
Xong bác nhớ chia sẻ với ACE trên OS nghe. Riêng tôi cũng 'lăn tăn' giống bác: chơi 1 âm-ly 5 kênh (có sẵn 1 kênh cho sub) hay là phải mua 2 âm-ly (1 cái 4 kênh cho 4 loa cánh, còn 1 cái 1 kênh mono cho sub)
Nếu là E thì E cứ chơi 1 amply 4 kênh và 1 amply riêng cho Sub vì amply riêng cho SUB lúc nào cũng nhiều chức năng hơn! E thích tách riêng ra chứ ko chơi All in ONE. Vấn đề chỉ là TIỀN mà thôi bác ạ!
