RE: AMPLI???
Theo em biết thì ampli mono one chanel là loại ampli một ngõ ra để đánh sub (mono đánh sub, one chanel là một ngõ ra). Để đánh cả 4 loa cửa và sub thì bác phải sử dụng 2 ampli thôi
Trích đoạn: GM_01
Thế có loại nào mà chi cần một ampli mà đánh được hết ko bác, em ko muốn dềnh dàng thành hai cai đâu àh.
RE: AMPLI???
Bác nào hieu cai nay giai thich cho em voi, em chi biet no doi tuong thich voi headunit nhung nhung cai chuan tiep theo thi ko biet la gi
The MRA-F350 requires a compatible head unit for setup and control, it cannot be used without one. The current list of compatible head units includes (but is not limited to): IVA-D100, IVA-D105, IVA-D300, IVA-D310, IVA-D900, IVA-D901, IVA-W200, IVA-W205, DVA-9860, DVA-9861 and DVA-9965.
Cau hinh con Alpine F350 nay lieu em co lap dc ko?
Details:
5-channel Digital Theater amplifier
50 watts RMS x 5 at 4 ohms
Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
optical digital input
all amplifier functions controlled by touchscreen of your compatible Alpine receiver (no built-in controls)
connects to compatible Alpine navigation systems
MOSFET power supply
CEA-2006 compliant
Bass Engine® features:
variable center-channel high-pass crossover (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
variable front left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
variable rear left and right high-pass crossovers (20-200 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
variable subsonic filter (20-50 Hz in 1/6 octave steps, 6/12/18/24 dB per octave)
subwoofer phase control (0/180 degrees)
time correction adjustment (0-10 mSec)
17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
STAR Topology (minimizes internal noise and prevents ground interference)
detachable front cover
blue power LED
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
13-3/4"W x 2-1/4"H x 9-9/16"D
Loa cua em la INFINITY 63.7i
6.5" 3 Way 225W
Kappa Series Speakers x 04 loa + 01 sub pioneer 1000w
Bay gio lap cai gi ma chi can mot con amp thoi, em da tham khao may loai 5ch nhung thay cong suat nho qua. Xin cac bac tu van gium. (xin loi em danh ko dau vi may em tu nhien bi loi font).
Details:
MOSFET power supply
CEA-2006 compliant
blue power LED
6.5" 3 Way 225W
RE: AMPLI???
Theo E biết thì cái alpine trên Bác chỉ dùng được cho 4 loa Cánh(Chưa chắc đã ngon vì dòng KAPPA này đánh rất khét nhưng nuốt Amp cũng kinh
) . Riêng SUB 1000W thì Bác tìm apm MONO > 1200 W vì nếu cùng họăc bé Công suất hơn khi dùng nóng rất hay bị ngắt
RE: AMPLI???
Em vẫn đang Akay vụ âm thanh hôm nào rảnh em phải diện kiến bác Mê đú cái ra tết bận quá bác ợ
RE: AMPLI???
Đây là một sơ đồ cho âm ly 5.1 nhưng nếu bác lắp Sub hơi thì vẫn cần phải có một âm ly riêng , còn nếu sub điện như hình vẽ thì không cần âm ly nữa
