Sẵn topic hỏi giá M3, em post luôn ảnh con này để các bác thưởng thức
General specifications
Engine
Engine 90º V 8
Engine Location Front , longitudinally mounted
Configuration aluminum block and head
Displacement 3.999 liter / 244 cu in
Bore / Stroke 92.0 mm (3.6 in) / 75.2 mm (3 in)
Compression ratio 12.0:1
Valvetrain 4 valves / cylinder, DOHC
Fuel feed Fuel injection
Aspiration Naturally Aspirated
Drivetrain
Chassis/body unitary steel
Front suspension two-joint spring strut axle
Rear suspension five link, anti-dive and anti-squad
Steering rack-and-pinion, power assisted
Brakes vented and cross drilled discs, all-round, ABS
Gearbox SG 6 speed Manual
Drive Rear wheel drive
Dimensions
Weight 1655 kilo / 3648.7 lbs
Length / Width / Height 4615 mm (181.7 in) / 1817 mm (71.5 in) / 1418 mm (55.8 in)
Wheelbase / Track (fr/r) 2761 mm (108.7 in) / 1538 mm (60.6 in) / 1539 mm (60.6 in)
Performance figures
Power 420 bhp / 313 KW @ 8300 rpm
Torque 400 Nm / 295 ft lbs @ 3900 rpm
BHP/Liter 105 bhp / liter
Power to weight ratio 0.25 bhp / kg
Top Speed 250 km/h / 155 mph
0-60 mph Acceleration 4.7 s
Engine
Interior
White
Red
The finally, M3 exhaust sound
[YouTube=IPmbX2c71XM]
