Mình dư không xài tới bán cho rộng nhà. Jensen là thương hiệu sản xuất thiết bị âm thanh hi-end của Mỹ. Made in China. Hàng mua từ ebay us.
Jensen PowerPlus1105 Amplifier
FEATURES:
• 5-Channels
• Max Power Output: 1100 Watts
• Low profile aluminum extruded heat sink
• Compact design allows great flexibility in mounting
• Meets CEA 2006 testing standards
• Full PWM MOSFET power supply
• High current bi-polar output supply
• Optimized class A/B design minimizes distortion and reduces idle sound
• Easily drives 2-Ohm loads
• Diagnostic LEDs
• Encapsulated power and speaker terminals
• Blue illuminated VU meters and logos
• Protection circuit that safeguards against short circuits, DC-offset and thermal overload
SPECIFICATIONS:
Length: 11.6"
Width: 19.5"
Height: 2.3"
Weight: 12 lbs.
Power Source: 12V
Current Draw @ 12V: Idle - 1.25A Maximum - 80A
Continuously variable low pass filter: 40 - 150 Hz (24dB / octave)
Continuously variable high pass filter: 10 Hz - 1.25 KHz (12dB/octave)
Continuously variable bass EQ: 0 - 12dB at 45 Hz
Operating Voltage Range: 10-18 VDC
Operating Temperature Range: -20°C to 65°C / -4°F to 149°F
Storage Temperature Range: -30°C to 70°C / -22°F to 158°F
Maximum Relative Humidity: 95%
Load Impedance: 2/4 Ω
Signal to Noise Ratio: 100dB @ 1KHz
Frequency Response: 0 Hz – 30 kHz -3dB
Input Impedance: 47K Ω nominal
THD + N @ 5 Watts: 0.02%, 1KHz, 14.4VDC
Power Output @ 4Ω: 4 x 64W, 1 x 150W
Power Output @ 2Ω: 4 x 100W, 1 x 280W
