77
21
Nhờ bác các bác review em HU này
Pioneer FH-P80BT
Cái này em search được, ko phải trên xe em
Main features[*] Max. Power Output MOSFET 50W x 4 [*] Tuner AM/FM [*] Plays CD-R, CD-RW, MP3, WMA, WAV, AAC [*] Bluetooth Yes [*] Display Illumination Blue OEL Display [*] Button Illumination Blue [*] Rotary Commander Yes [*] Remote Control Included [*] Cellular telephone auto muting (+) Yes
This feature automatically reduces the volume of your system when an incoming call is detected or you dial an outgoing call on a cellular phone installed in your car.
Connectivity [*] Aux-in Yes (Rear) [*] Direct Sub Drive (+) Yes
Combine the MOSFET 50Wx4 power amp and EEQ Plus technology to get Direct Sub Drive, another unique Pioneer technology feature. It enables you to amplify your front speakers by 2 x 50 W and add a 70 W amplified filtered subwoofer (in 2 Ohm mode) in the rear to enjoy outstanding full power bass without an extra amplifier. It's an easy solution for lovers of booming bass. [*] Hard-wired Remote Input Yes [*] High Voltage Output (+) 4V
To provide a high output to your amplifier, Pioneer has built a special High Voltage Preamp circuit yielding no less thatn 4 V non-clipping output to the preout terminal. Such a high output voltage means the power amplifier does not have to work so hard to produce sufficient gain to give high volume levels. As a result, even a low gain power amplifier can be used, giving excellent sound quality with low noise. [*] IP Bus Yes [*] iPod Direct Control Yes [*] RCA Preout (+) 3 (F+R+S/W or NON-FAD)
Thanks to the RCA pre-outs, it is easy to expand your sound system. You can significantly improve your in-car sound quality by connecting extra amplifiers to your headunit. You could customize your sound system with separate amplifiers for the front speakers, the rear speakers and a subwoofer. Combining Pioneer 's EEQ+ with the RCA pre-outs let you create the exact sound you want, with the focus on complete flexibility! [*] Sub-display Output Yes [*] USB Input Yes
Bluetooth [*] Bluetooth Ready Yes [*] Handsfree Telephony Yes [*] Audio Streaming Yes
iPod Compatibility [*] iPod Ready Yes, via optional cable CD-IU50 [*] Compatible Generations (+) September 2005 - September 2007
Notes:
* Pioneer cannot guarantee the future compatibility of our products with any iPod (or iPod firmware update) which is released after the Pioneer product release.
* The compatibility information is based on the above-mentioned firmware version.
* iPod shuffle is not supported. Only iPods with a "30-pin Dock Connector" are connectable. [*] Supported Functions • Battery charging
• List browsing
• Music playback (track up/down, fast foward, rewind, pause, repeat and shuffle)
Tuner Features [*] Radio Data System (RDS) (+) Yes
RDS (Radio Data System) is a system for pro-viding information along with FM broadcasts. This inaudible information provides such fea-tures as program service name, program type, traffic announcement standby, automatic tuning and program type tuning, intended to aid radio listeners in finding and tuning in to a desired station. Note: • RDS service may not be provided by all stations. • RDS functions like AF (alternative frequencies search) and TA (traffic announcement standby) are only available when your radio is tuned in to an RDS station. [*] Traffic Announcement Yes [*] Best Stations Memory (BSM) (+) Yes
Best Stations Memory scans and memorises the six strongest, clearest stations available on each band. [*] PTY Search (+) Yes
A PTY search is performed by program type as indicated in the PTY list (the program types are: News&Inf, Popular, Classics, Others). It also provides automatic tuning to emergency broad-casts (PTY alarm).
CD Player Features [*] MP3 Text Display Yes [*] USB Text Yes [*] Disc Title Memory Yes
Audio [*] Advanced Sound Retriever Yes [*] ASL (Automatic Sound Leveliser) (+) Yes
Compensating for additional outside noise, the automatic sound leveliser uses signal processing to automatically and electronically adjust the internal volume so that your music always sounds right. [*] D/A Converter 1-bit [*] Graphic Equaliser 7-band, with 5 preset EQ curves and 2 custom [*] High Pass Filter (+) Yes
When the subwoofer is connected and you do not want low sound to play from the front or rear speakers, turn the high pass filter on. Only fre-quencies higher than those in the selected range will be output from the front or rear speakers. [*] Low Pass Filter Yes [*] Loudness (+) Yes
At low volume levels, low and high frequency sounds in music can be overpowered by ambient noise levels in the vehicle. Loudness control provides a one-button way to boost these frequencies and provide better overall sound at low volume levels. [*] Source Dependent EQ memory Yes [*] Source Level Adjuster (SLA) (+) Yes
Đa ta các bác
