RE: Cho em hỏi tí
Ko phải photoshop đâu em nó của hãng Bimota Ý đấy .Đời em nó là 2007 .Nhưng cái em thắc mắc là lúc nó muốn quẹo thì làm sao vì nó ko dùng bộ phuộc có chức năng giảm xóc và chỉnh hướng như thông thường ở các loại xe khác.
Chassis
Frame: Omega machined aluminium alloy
Wheelbase: 1375 mm / 54.1 in
Rake: Fully adjustable
Front suspension: Progressive linkage with fully adjustable Double System monoshock
Front wheel travel: 120 mm / 4.7 in
Front brake: 2 x 320 mm semi-floating discs, 4-piston callipers - Brembo
Front wheel: 6 spoke design light alloy forged 3.50x17
Front tyre: 120/70 ZR 17
Rear suspension: Direct linkage with fully adjustable Double System monoshock
Rear wheel travel: 120 mm / 4.7 in
Rear brake: 220 mm disc, 2-piston caliper
Rear wheel: 6 spoke design light alloy forged 5.50x17
Rear tyre: 180/55 ZR 17
Fuel tank capacity: 13 l / 3.4 US gal (including 3 l / 0.8 US gal reserve)
Weight: 149 kg / 340,6 lbs (includes battery, lubricants and cooling liquid, where applicable)
Seat height: 830 mm / 32.7 in
Instruments: Speedometer, rev counter, high beam indicator, direction indicators, oil pressure warning light, low fuel warning light, neutral light
Engine
Type: Ducati - L twin cylinder, 2 valves per cylinder Desmodromic; air cooled
Displacement: 991 cc
Bore x Stroke: 94x71.5
Compression ratio: 10,5:1
Power: 63 kW - 85.5 Hp @ 8000 rpm
Torque: 87.5 Nm - 9 kgm @ 6300 rpm
Fuel injection: Electronic fuel injection, 45 mm throttle body
Exhaust: Aluminium muffler with catalytic converter
Emissions: Euro 2
Transmission
G earbox: 6 speed
Ratios: 1st 37/15, 2nd 30/17, 3rd 27/20, 4th 24/22, 5th 23/24, 6th 24/28
Primary drive: Straight cut gears (ratio 32/59)
Final drive: Chain; Front sprocket 15; Rear sprocket 38
Clutch: Dry multi-plate with hydraulic control
