RE: cho em xin y' kien'
rồi,lại có hàng khủng sắp về VN,mà chẳng bít là đùa hay sao,chứ chiếc DBS đầu tiên mới ra đường có mấy tuần
thôi,Aston DBS chưa có xe cũ bác ạ,mua con Aston này đi[link]http://cgi.ebay.com/ebaymotors/Aston-Martin-DB9-Volante-2006-ASTON-MARTIN-DB9-VOLANTE-1299-MONTH-WITH-25-DOWN_W0QQcmdZViewItemQQcategoryZ157056QQihZ012QQitemZ220251159727QQrdZ1QQsspagenameZWDVW[/link]Trích đoạn: aston
thiet mu` bac' . bac' cho em hoi~ gia' bao nhiu vay. dze` VN minh` khoang~ nhiu . khi nao` em no' dia` em chup. cho cac' bac' may tam hen .
Body
Two-door coupe body style with 2+0 seating
Bonded aluminium VH structure
Aluminium, magnesium alloy and carbon fibre composite body
Extruded aluminium door side-impact beams
High Intensity Discharge headlamps (dipped beam)
Halogen projector headlamps (main beam)
LED rear lamps and side repeaters
Engine
All alloy quad overhead cam 48 valve 5935cc V12
Compression ratio 10.9:1
Front mid-mounted engine, rear-wheel drive
Fully catalysed stainless steel exhaust system with active bypass valves
Transmission
Rear mid-mounted six-speed manual gearbox
Alloy torque tube with carbon fibre propeller shaft
Limited-slip differential
Final drive ratio: 3.71:1
Steering
Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock to lock
Column tilt and reach adjustment
Wheels and Tyres
Front: 8.5’’ x 20’’ Pirelli P Zero 245/35
Rear: 11’’ x 20’’ Pirelli P Zero 295/30
Suspension
Adaptive Damping System (ADS) with Track mode
Front: Independent double wishbones incorporating anti-dive geometry, coil springs, anti-roll bar and monotube adaptive dampers
Rear: Independent double wishbones with anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube adaptive dampers
Brakes
Dynamic Stability Control (DSC) with Track mode
Anti-Lock Braking System (ABS)
Electronic Brakeforce Distribution (EBD)
Emergency Brake Assist (EBA)
Traction Control
Front: Ventilated carbon ceramic discs, 398mm diameter with six-piston calipers
Rear: Ventilated carbon ceramic discs, 360mm diameter with four-piston calipers
Interior
Semi-aniline leather and Alcantara interior
Matrix alloy facia trim and Iridium Silver centre console finish
Carbon fibre door trims and door pulls
Auto-dimming rear-view mirror with garage door opener (USA & Canada only)
Sports seats with 10-way electrical adjustment, including height, tilt and lumbar adjustment
Memory seats & exterior mirrors (three positions)
Dual-stage driver/passenger front airbags
Side airbags (sports seats only)
Heated seats (sports seats only)
Heated rear screen
Automatic temperature control
Organic electroluminescent (OEL) displays
Trip computer
LED map lights
Cruise control
Hard Disk Drive (HDD) satellite navigation system*1,2
Bluetooth® telephone preparation*1
Powerfold exterior mirrors
Front and rear parking sensors
Tyre pressure monitoring system*1
Alarm and immobiliser
Remote-control central door locking and boot release
Umbrella and holder
Battery Disconnect Switch (BDS)
Battery conditioner
Tracking device (UK only)*3
Boot-mounted umbrella
In-Car Entertainment
Aston Martin 700W Premium Audio System with Dolby® Pro Logic II®, includes a six-CD autochanger Integrated Apple iPod® connector*4
USB connector with Waveform Audio Format (WAF), Windows Media Player (WMA) and MPEG (MP3) audio file compatibility
3.5mm auxiliary socket
Options
Lightweight seats with six-way adjustment, including front and rear height adjust (does not include side airbags or heated seats feature. Not available in USA or Canada)
20’’ alloy wheels with graphite finish. Satellite radio system (USA only)
Piano Black facia trim and centre console finish
Leather storage saddle
Personalised sill plaques
Auto-dimming interior rear-view mirror*1
Auto dimming interior rear view mirror with garage door opener (Europe only)
Alarm upgrade (volumetric & tilt sensors)
Tracking device*1/3
First aid kit
Ashtray and cigar lighter
Dimensions
Length: 4721mm (185.9’’)
Wheelbase: 2740mm (107.9’’)
Width: 1905mm (75’’) exc. Mirrors 2060mm (81.1’’) inc. Mirrors
Fuel Tank Capacity: 78 litres (17.2 Imp gall, 20.5 US gall)
Height: 1280mm (50.4’’)
Weight: 1695kg (3737 lb)
Performance
Max speed: 191mph (307km/h)
Max power: 380kW (510bhp/517 PS) @ 6500 rpm
Acceleration: 0-100km/h (62mph) 4.3 seconds
Max torque: 570 Nm (420 lb.ft) @ 5750 rpm
*1 Not available in all markets. Please consult your dealer for details.
*2 Includes Traffic Messaging Channel (TMC) in Continental Europe.
*3 Complies with UK Thatcham Category 5 requirements. Excludes subscription. Standard in the UK.
*4 iPod is a trademark of Apple Inc., registered in the U.S. and other countries
*5 Data not applicable to North American market
© 2007 Aston Martin
Body
Engine
Transmission
Steering
Wheels and Tyres
Suspension
Brakes
Traction Control
Interior
Heated rear screen
Trip computer
LED map lights
Cruise control
Umbrella and holder
Battery conditioner
Options
Tracking device*1/3
First aid kit
Dimensions
Performance
© 2007 Aston Martin
bác ơi ......đừng chơi astonmartin ....thà làm em masterati còn độc hơn đó bác....
Giá xe về VN thì khó nói chuẩn lắm bác ah, nếu bác muốn nhanh và đi bằng đường hàng không thì nó cũng chêng vài nghìn thằng mẽo rồi. Lại còn option cho xe nữa ,Bác chơi full hay không full? Còn thuế thì vẫn là 83% nhập khẩu, 50% TTDB và 10% VAT. Bác cứ tự nhẩm tính ra thì biết. Bác mua chỗ quen họ nhập cho thì rẻ hơn ngoài ít nhất cũng phải 5000-7000 usd.
