SPO confirmed
973
257
Lương Sơn Bạc
E tìm thấy trên mạng có thông tin reset này cũng hay hay,ko biêt có hiệu quả ko,các bác tham khao cho vui nha!
Có phản hồi đánh giá là tốt,cảm nhận giống như là lúc đầu mua xe!
E trích nguyên văn vì ....
:)<span style=""background-color: #ff0000;"">A</span>! Hi..frineds:
I just read the "DIY throttle reset" on the W203 forum, Don't know if this works for our W204.
Below is the steps that I copy from W203 thread:
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
People said after these steps, the throttle response will be much better, is this true and works for our W204?
I just want to know people's opinion before I try it myself.
Please reply
<span style=""background-color: #ff0000;"">B</span>.I tried this before I searched this forum, looks like a lot of people know about this reset on this forum, some people even do this reset every two weeks with their MB to make the ECU to re-learn their own driving style.
People who tried this said this works with all MB or most MB, so I tried it with my W204.
After the reset, I felt the car drives like when I first got it, throttle response is much better too, and the RPM shift points raise from 3000rpm to around 3500rpm-4000rpm, feel more power than before and no more lag.
Basically this is like reset the ECU and let it re-learn your driving style, I think people should do this reset after their break-in period, and they should be able to tell the differece.
I did my reset last night after my 1700 miles break-in period and the car feels like new again!
Waiting bác bannang,KVL,ducvcci,...bóng bàn
hiii
123
26
Dzụ này hay à, bác nào đã làm rồi cho anh em xin một ít re viu ạ.
Thanks bác chủ thớt.
95
9
pác VN có ý kiến gì không ?
Không biết trên bài báo có nói là bao nhiêu km/miles thì nên reset theo cách này 1 lần ?
Anh Ba
15/7/09
6.620
726
HCMC
bannang.com
E đã nghe đến điều này , kiểu chạy của e thì có hơi hao xăng tí,:D ko biếc reset lại có hao thêm ko ?
Nếu reset lại mà tăng tốc GL550 thì tốt quá .
Cảm ơn bác Po nhé , lâu quá rồi ko bác .
394
Theo em nếu muốn nâng điểm chuyển số thì đi không êm nhưng mà mạnh hơn , bình thường chuyển số < 3K, bây giờ shift points lên 3500rpm-4000rpm. Tốn xăng hơn vì đi số thấp
KVL confirmed
5.345
303
Hồ Chí Minh
Cái này ngày trước đã từng đề cập tới, em đã thử mà ko thấy cảm nhận khác biệt gì.
1.442
chưa dám thử.MÀ GLK thử dc ko ta:cool:
Anh em nào làm trc.Cho cảm nhận rồi có gì em theo:D
