Em mới đi công tác đặt mua được mấy thứ này, kinh nghiệm chưa nhiều post lên các bác tham khảo và cho ý kiến chuyên môn xem có được ko, lắp cho xe Cap.
Bao gồm đầu đĩa: IN-DASH AM/FM DVD/MP3/CD RECEIVER WITH 4.3” TOUCHSCREEN WIDESCREEN TFT MONITOR WITH BUILT IN TV TUNER AND USB PORT.
DIN mounting
· Motorized slide down full detachable panel
· WMA/MP4/MP3/DVD/SVCD/VCD/CDR/CDRW & SDVD compatible
· USB port
· Front auxiliary input
· Compatible with audio output of iPod or any other MP3 players
· Built in 4.3” Touchscreen Widescreen TFT monitor
· Resolution: 1152 x 234 pixels
· Brightness: 400 NITS
· NTSC/PAL compatible
· On screen display
· PLL synthesized AM/FM tuner
· 30 Station presets
· Switchable USA/Europe radio frequencies
· RDS (Radio Data System)
· Built in TV tuner (NTSC/PAL BG/I/DK switchable)
· Illuminated controls
· Preset EQ response curves
· Separate bass and treble
· Balance and fader controls
· Loudness
· Stereo/mono switch
· Local/distance switch
· Mute function
· Last position memory
· Repeat/intro/random
· Subwoofer output
· 1-Bit D/A converter
· ESP (anti-skip mechanism)
· Dual (front and rear) RCA outputs
· Wireless remote control
· Output power: 80w x 4 channels
-04 speaker:KAPPA63.7I
SPECIFICATIONSGeneralPower Handling, RMS75 WattsPower Handling, Peak225 WattsSensitivity95dBFrequency Response45Hz - 25kHzMounting Depth2-3/16"Impedance
2 Ohms
- 01 Sub:
TS-SW2541D
10" Shallow-Mount Subwoofer with 1000 Watts Max. Power
250 Watts Nominal Power
Unique Design with just 3" Mounting Depth
Small Enclosure Use (0.35 ~ 0.7 Cubic Feet)
-Ampli Inf
REF1600A
-600-Watt mono subwoofer amplifier with on-board electronic crossover and variable bass boost circuit.
Power Output400 watts RMS x 1 channel at 4 ohms and ≤ 1% THD + NSignal-to-Noise Ratio85dBA (reference 1 watt into 4 ohms)Dynamic Power600 watts at 2 ohmsEffective Damping Factor6.3 at 4 ohmsFrequency Response (-3dB)11Hz to 330Hz (-3dB)Maximum Input Signal6VMaximum Sensitivity100mV
