RE: Dây cuaroa cam matiz?
Em có hướng dẫn tháo lắp cho bác nè. Bác chịu khó đọc bằng tiếng Anh nhé
A. Removal
1. Remove:
- RH headlamp.
- Auxiliary drive belt(s).
- Timing belt upper cover [1] .
2. Raise and support front of vehicle.
3. Remove RH front wheel.
4. Slacken crankshaft pulley bolt [2] .
5. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [3] & [4] .
6. Remove:
- Crankshaft pulley bolt [2] .
- Crankshaft pulley [5] .
- Dipstick and tube.
- Timing belt lower cover [6] .
7. Ensure timing marks aligned [7] .
8. Slacken tensioner bolt [8] . Push tensioner away from belt. Lightly tighten bolt.
9. Remove timing belt.
B. Installation
1. Ensure timing marks aligned [4] & [7] .
2. Fit timing belt in anti-clockwise direction, starting at crankshaft sprocket. Ensure belt is taut on non-tensioned side.
3. Slacken tensioner bolt [8] . Allow tensioner to operate.
4. Turn crankshaft slowly two turns clockwise to TDC on No.1 cylinder.
5. Ensure timing marks aligned [4] & [7] .
6. Tighten tensioner bolt [8].
7. Install components in reverse order of removal.
8. Tighten crankshaft pulley bolt [2].
