RE: Độ số tự động cho Lax 1.8
VD Cho bác về bộ hộp số AT của LAC nhé
SECTION 5A2
TRANSMISSION / TRANSAXLE (AISIN AUTO TRANSAXLE)
AISIN AUTO T/A – AUTOMATIC TRANSAXLE (531)
NO. OPERATION DESCRIPTION OPERATION CODE MODEL
S N L
1 . TORQUE CONVERTER – REPLACE 5310100 2.9 3.0 —
2 . BOLTS, TORQUE CONVERTER TO FLYWHEEL - REPLACE 5310200 0.6 0.6 —
3 . AUTO TRANSAXLE ASSEMBLY - REPLACE 5310300 2.9 3.0 —
. AUTO TRANSAXLE ASSEMBLY - OVERHAUL 5310400 6.5 6.6 —
4 . TUBE, OIL FILLER - REPLACE 5310500 0.7 0.7 —
5 . STICK, OIL GAUGE - REPLACE 5310600 0.2 0.2 —
S : KALOS, N : NUBIRA/LACETTI, L : EVANDA
AISIN AUTO T/A – CASE & RELATED PARTS (532)
S N L
1 . SENSOR, INPUT SHAFT SPEED (ISS) - REPLACE 5320100 0.2 0.2 —
2 . SENSOR, OUTPUT SHAFT SPEED (OSS) - REPLACE 5320200 0.2 0.2 —
3 . SWITCH, PARK/NEUTRAL POSITION (PNP) - REPLACE 5320500 0.2 0.2 —
4 . HARNESS, TRANSAXLE WIRING - REPLACE 5320600 1.5 1.5 —
5 . HOUSING, TRANSAXLE - REPLACE 5320700 3.2 3.3 —
6 . TUBE, DIFFERENTIAL BEARING LUBE APPLY - REPLACE 5320900 3.3 3.4 —
7 . PLATE, TRANSAXLE HOUSING OIL RESERVOIR - REPLACE 5321100 3.3 3.4 —
8 . TUBE, LUBRICATION APPLY - REPLACE 5321500 3.3 3.4 —
9 . FILTER, TRANSAXLE OIL - REPLACE 5321600 1.1 1.1 —
10 . REAR CASE, TRANSAXLE - REPLACE 5321800 3.1 3.2 —
11 . SEAL, DRIVE AXLE FLUID - REPLACE . . . .
Right 5321900 1.1 0.9 —
Left 5322100 1.1 0.9 —
Both 5322200 2.0 1.6 —
12 . PARKING SYSTEM - REPLACE 5322300 4.5 4.6 —
13 . PAN AND/OR GASKET, OIL - REPLACE 5322400 1.1 1.1 —
14 . HOSE, BREATHER - REPLACE 5322500 0.2 0.2 —
15 . ISTONS, ACCUMULATOR - REPLACE 5322600 3.8 3.9 —
AISIN AUTO T/A – INTERNAL POWERTRAIN PARTS (533)
S N L
1 . OIL PUMP - REPLACE 5330100 3.3 3.4 —
2 . CLUTCH ASSEMBLY, SECOND BRAKE - REPLACE 5330200 3.5 3.6 —
3 . ONE-WAY CLUTCH, NO. 1 - REPLACE 5330500 3.3 3.4 —
4 . CLUTCH ASSEMBLY, DIRECT - REPLACE 5330800 3.4 3.5 —
5 . CLUTCH ASSEMBLY, FORWARD & REVERSE - REPLACE 5330900 3.3 3.4 —
6 . DISC & FLANGE, FORWARD CLUTCH - REPLACE 5331000 3.4 3.5 —
7 . DRUM & PISTON, FORWARD CLUTCH - REPLACE 5331100 3.5 3.6 —
8 . PISTON, O/D BRAKE - REPLACE 5331200 3.2 3.3 —
9 . DISC & FLANGE, O/D BRAKE - REPLACE 5331300 3.2 3.3 —
10 . 1ST & REVERSE BRAKE - REPLACE 5331400 3.8 3.9 —
11 . ONE-WAY CLUTCH, NO. 2 - REPLACE 5331500 3.6 3.7 —
AISIN AUTO T/A – GEAR ASSEMBLY (534)
S N L
1 . GEAR ASSEMBLY, PLANETARY - REPLACE 5340100 3.6 3.7 —
2 . GEAR ASSEMBLY, COUNTER DRIVE - REPLACE 5341200 3.6 3.7 —
3 . GEAR ASSEMBLY, DIFFERENTIAL - REPLACE 5341400 3.4 3.5 —
4 . GEAR, REAR PLANETARY SUN - REPLACE 5341500 3.3 3.4 —
5 . HUB, FORWARD CLUTCH - REPLACE 5341600 3.3 3.4 —
6 . GEAR, PLANETARY RING - REPLACE 5341700 3.7 3.8 —
7 . GEAR, FRONT PLANETARY SUN - REPLACE 5341800 3.4 3.5 —
8 . HUB, DIRECT CLUTCH - REPLACE 5341900 3.4 3.5 —
9 . GEAR ASSEMBLY, COUNTER DRIVEN - REPLACE 5342000 3.4 3.5 —
AISIN AUTO T/A – CONTROL VALVE (535)
S N L
1 . VALVE BODY - REPLACE . . . .
Assembly 5350100 1.4 1.4 —
2 . VALVE BODY SOLENOID - REPLACE . . . .
Linear 5350600 1.6 1.6 —
Lockup 5350700 1.6 1.6 —
Shift 1 (SS1) 5350800 1.6 1.6 —
Shift 2 (SS2) 5350900 1.6 1.6 —
Timing 5351000 1.6 1.6 —
AISIN AUTO T/A – FLUID COOLER PIPE (536)
S N L
1 . FLUID COOLER PIPE AND HOSE - REPLACE . . . .
Upper 5360100 0.7 0.7 —
Lower 5360200 0.7 0.7 —
Both 5360300 0.9 0.9 —
AISIN AUTO T/A – AUTOMATIC TRANSAXLE CONTROLS (537)
S N L
1 . KNOB, SHIFT LEVER - REPLACE 5370100 0.2 0.2 —
2 . CABLE, SHIFT CONTROL - REPLACE 5370200 0.7 0.7 —
3 . LEVER, SHIFT CONTROL (AT TRANSMISSION) - REPLACE 5370300 0.4 0.5 —
4 . BASE PLATE, SHIFT LEVER - REPLACE 5370400 0.7 0.7 —
5 . CAP, CONSOLE - REPLACE 5370500 0.3 0.3 —
6 . SCALE, CONSOLE - REPLACE 5370700 0.3 0.3 —
7 . SOLENOID, BTSI - REPLACE 5370800 0.4 0.6 —
