tình hình là tết rảnh nên em đi vòng vòng mấy trang web chơi thì phát hiên nó đây.
có lẫy chuyển số nữa nè
nội thất nè
mông em nó nè bác
sunroof này phê àh
bộ chân của nó nè
xin mời các bác ném đá thoải mái
Powertrain SE/SEL/Limited Drive type Front-Wheel Drive (std.) Active All-Wheel Drive (opt.) Engine type 3.5L Twin independent Variable Cam Timing (TiVCT) V6 Engine Transmission 6-speed automatic (SE) / 6-speed SelectShift Automatic™ (SEL and Limited) Final drive ratio 3.16 (FWD & AWD) / 3.39 (Limited AWD with 20" wheels) Fuel economy (EPA-estimated) TBD Horsepower (SAE net @ rpm) 285 @ 6,500 Torque (lb.-ft @ rpm) 253 @ 4,000 Compression ratio 10.8:1 Valve lifters Direct acting mechanical bucket Fuel delivery Sequential multi-port electronic fuel injection Exhaust Quasi-Dual exhaust with polished round beveled-edge rolled tips and two catalytic converters Engine block type Cast aluminum Cylinder head material Cast aluminum
Powertrain Sport Drive type Front-Wheel Drive (std.) Active All-Wheel Drive (opt.) Engine type 3.7L Twin independent Variable Cam Timing (TiVCT) V6 Engine Transmission 6-speed SelectShift Automatic™ with paddle activation Final drive ratio 3.16 (FWD) / 3.39 (AWD) Fuel economy (EPA-estimated) TBD Horsepower (SAE net @ rpm) 305 @ 6,500 Torque (lb.-ft @ rpm) 280 @ 4,000 Compression ratio 10.5:1 Valve lifters Direct acting mechanical bucket Fuel delivery Sequential multi-port electronic fuel injection Exhaust True Dual exhaust with chrome oval rolled-edge tips with two catalytic converters (Increased seperated length tuned exhaust for low-end torque enhancement) Engine block type Cast aluminum Cylinder head material Cast aluminum
sẵn đó cho em gửi lời chúc tết đến mấy bác nha.
mọi chi tiết mời các bác xem ở đây
http://www.fordvehicles.com/crossovers/edge/2011/gallery/photos/
