Hỏi/Đáp Kỹ Thuật Freeze frame là gì?
9
Em đang đọc và tìm hiểu về máy quét OBD2 Scanner - Innova 3040c. Trong đó có đoạn giới thiệu "Freeze frame shows engine conditions such as fuel trim, engine coolant temp, etc., at the time the Malfunction"
Em không hiểu Freeze Frame là gì?
Nhờ các bác chuyên ngành giải thích giúp em với ạ.
852
3.680
Freeze Frame is an element of the Diagnostic Executive that stores engine operating conditions at the moment an emission-related fault is stored in memory (when the MIL is commanded on). This data can be used to help identify the cause of an emissions-related fault.
Regulations related to the OBD II System require that certain engine-operating conditions be captured and stored whenever the MIL is illuminated. The data captured is called Freeze Frame data. This data can be thought of as a single record of a certain set of operating conditions. Whenever the MIL is turned on, the corresponding record of operating conditions is recorded to the Freeze Frame buffer.
The Freeze Frame data can only be overwritten by data associated with a Fuel Trim or Misfire fault because data from these faults takes priority over data associated with any other type of fault. The Freeze Frame data will not be erased unless the associated History DTC is cleared.
http://www.autozone.com/repairguide...nology/Freeze-Frame-Data/_/P-0996b43f80cb37ca
DTC stands for “diagnostic trouble code,” usually a series of five letters and numbers (such as P0300) that tells automotive service technicians – aka mechanics – what’s wrong with your engine, emissions controls and other components according to your vehicle’s on-board diagnostics system.
The acronym also represents some BMW and Mini traction control systems, named Dynamic Traction Control.
http://ask.cars.com/2010/08/what-does-dtc-stand-for.html
Malfunction Indicator Lamp: Mil
Tóm tắt là như thế này: Một khi động cơ bị lỗi thì đèn động cơ sẽ sáng lên ( đèn này tiếng Anh là MIL, như em đã ghi ở trên, thì Hộp ECU trên xe sẽ ghi lại toàn bộ tình trạng lỗi của xe , lưu vào bộ nhớ của ECU, thì công việc này nó gọi là Freeze frame. Cũng giống như CSGT thông vậy, khi có tai nạn xảy ra, họ đến hiện trường chụp lại toàn bộ hiện trường xảy ra tai nạn, việc chụp lại này gọi là Freeze frame.
Như vậy khi máy OBD hoạt động thì nó sẽ tiếp nhận thông tin tình trạng máy bị lỗi gọi là freeze frame data lưu trên bộ nhớ ECU để phân tích và tìm ra lỗi, khi đã tìm ra lỗi rồi thì nó sẽ báo lỗi theo các lỗi đã quy định theo mã, viết tắc là DTC, ví dụ máy báo P0300 là cảm biến gió bị hư, P0400 là cảm biến oxy bị hư....em chỉ ví dụ
