Cần bán màng hình Sony 6,95in Fullbox chưa từng tháo gỡ
Em order nhầm 2 sets nên chia lại cho bác nào cần. Màng hình Sony XAV-V750BT.
Người nhà em sẽ về tới VN ngày 10/3. Em rao bán cho bác nào cần, Lây cọc trước 100k là đủ. Giao dich tại nhà hoặc lấy tại sân bay TSN
Gia 4tr8. Vì người nhà xách tay nên ko mất phí ship hay thuế gì cả. Xem như order trực tiếp
LH 0907888266
Chuc năng:
NFC, Megabass, amply 4x55watts, Siri iphone,
Songpal,
4K: 3,840 x 2,160 pixels.
Full Specifications & Features Buy General Features
OUTPUT POWER 55W
PRE OUT 3Pre 2V HIGH VOLTAGE
SUB OUT Yes
AUX-IN Yes(Rear)
REAR VIEW CAMERA IN Yes
USB Yes
BT Yes
BALANCE Yes
FADER Yes
HIGH PASS FILTER Yes
LOW PASS FILTER Yes
ATT Yes
ZAPPIN Yes(only for tuner preset)
Connectivity NFC Yes
Tuner Features
PRESET FM18/AM12 AUTO MEMORY
(1.1) Bluetooth Feature
SPEED DIAL Yes (6 memories)
RECENT CALLS (# OF) Yes (20 numbers) LAST DIALED CALL Yes(select from the dialed call history)
PHONEBOOK ACCESS VIA PBAP Yes
AUTO ANSWER Yes(off/on)
RING VOLUME LEVEL CONTROL Yes
CALL VOLUME LEVEL CONTROL Yes
VOICE DIAL ACTIVATION Yes
EXTERNAL MICROPHONE Supplied
BATTERY REMAINDER INDICATION Yes
SIGNAL STRENGTH INDICATION Yes Bluetooth Audio Feature
AUDIO CODEC (BLUETOOTH AUDIO) SBC PAUSE (BLUETOOTH AUDIO) Yes
TRACK +/- Yes
GROUP (FOLDER) +/- Yes
AUDIO LEVEL ADJUSTMENT Yes(-8dB to +18dB)
REPEAT CONTROL (AUDIO DEVICE SIDE) Yes
SHUFFLE CONTROL (AUDIO DEVICE SIDE) Yes
META DATA INDICATION Yes Monitor(AVC)
LCD TYPE TFT Active Matrix
SCREEN ASPECT 0.7145833333
SCREEN DIAGONAL (INCH / MM) 6.95 inch
SCREEN SIZE (W X H MM) 157.20 x 82.32 mm
RESOLUTION (DOT) 800 x 480 DIMMER Yes COLOR SYSTEM NTSC/PAL/SECAM/PAL-M
CONTRAST RATIO 400
BRIGHTNESS 400 cd/m2
Display Panel
DIMMER ADJUST Yes
/DRIVE USB DEVICE CONTROL (SHUFFLE) OFF/FOLDER USB DEVICE CONTROL (PAUSE) Yes USB DEVICE CONTROL (RESUME PLAY) Yes USB DEVICE CONTROL (AUDIO CODEC) MP3/WMC/AAC/WAV/FLAC USB DEVICE CONTROL (AUDIO PLAYABLE EXTENSION) .mp3/.wma/.aac/.wav/.flac Multi Language CAUTION English;Spanish;Russian FEATURES
