Server Error in '/' Application.
String or binary data would be truncated. The statement has been terminated.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Data.SqlClient.SqlException: String or binary data would be truncated. The statement has been terminated.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[SqlException: String or binary data would be truncated.
The statement has been terminated.]
System.Data.SqlClient.SqlCommand.ExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream) +742
System.Data.SqlClient.SqlCommand.ExecuteNonQuery() +194
ASP.pmsend_aspx.__Render__control1(HtmlTextWriter __output, Control parameterContainer) +30648
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +27
System.Web.UI.Control.Render(HtmlTextWriter writer) +7
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +243
System.Web.UI.Page.ProcessRequestMain() +1926
