Em có 1 loa sub hơi focal p30 mới 100% mua từ mỹ về mà lười.đóng thùng quá..
Bác nào muốn trải nghiệm thì đổi cái sub điện nào hay hay với em nhé. Ưu tiên infinity nhé or bán luôn 3.5tr. Giá gốc 6 củ ạ
DUY 0908898484
12’’ (30CM) SUBWOOFER
The Performance line’s P 30 DB subwoofer has a nominal power of 300W RMS. It is ideal for using with sealed or bass-reflex enclosures. Its 2 x 4 Ohm double voice coil gives you various options for hooking it up to an amplifier.
The Sub P30 DB really gives your car audio system an upper edge. It offers high power handling thanks to the 2″ (50mm) voice coil with a Kapton frame.. The butyl suspension gives the subwoofer more durability, and the decompression of the spider ventilates the voice coil. This enables your system to achieve extreme performance with pronounced and tight bass.
Key points :
- For sealed or vented box
- High sensitivity
- 2 x 4 Ohms dual voice coil
- 511/16" (14,5cm) dual ferrite
Mẫu này là đỉnh kute của focal
