70
Tp. HCM
Tôi gặp lỗi này khi vào sửa đổi Profile, rất mong được hướng dẫn cách khắc phục.
Xin Cảm ơn.
[H1]Server Error in '/Forum' Application. <hr/> [/H1] [H2]Value of '7/1/1999 12:00:00 AM' is not valid for 'SelectedDate'. 'SelectedDate' should be between 'MinDate' and 'MaxDate'.
Parameter name: SelectedDate
[/H2] [font="arial, helvetica, geneva, sunsans-regular, sans-serif "]Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentOutOfRangeException: Value of '7/1/1999 12:00:00 AM' is not valid for 'SelectedDate'. 'SelectedDate' should be between 'MinDate' and 'MaxDate'.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[PRE][ArgumentOutOfRangeException: Value of '7/1/1999 12:00:00 AM' is not valid for 'SelectedDate'. 'SelectedDate' should be between 'MinDate' and 'MaxDate'. Parameter name: SelectedDate] Telerik.Web.UI.RadDatePicker.set_SelectedDate(Nullable`1 value) +570 editprofile.PopulateEditForm() +942 editprofile.Page_Load(Object sender, EventArgs e) +43 System.Web.UI.Control.OnLoad(EventArgs e) +99 System.Web.UI.Control.LoadRecursive() +50 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627 [/PRE]
<hr/> Version Information: Microsoft .NET Framework Version:2.0.50727.3603; ASP.NET Version:2.0.50727.3082 [/font]
70
Tp. HCM
Ban Quản trị ơi, giúp tôi một chút.
Server bị lỗi lâu lâu rồi, không edit được profile các bác ơi.
leo
Hà nội
Vẫn bình thường đó chứ bác, em thử tuỳ chỉnh profile của mình vừa xong và mọi thứ đều OK, bác thử lại xem nào
