781
các bác chạy Madaz3 cẩn thận hơn nhé! đăng trên VNexpres
http://www.vnexpress.net/Vietnam/Oto-Xe-may/2007/04/3B9F4AC7/
bọn trộm có thể lên mạng học được cách mở! bác nào tim được thì post link lên nhé. Vì em tìm ko ra, vì vnepress ko nói rõ chỉ nói trang web này có đăng thôi. Các bác vô tìm thử nhé
http://www.autoblog.com/:)
31
RE: MỞ cửa Madaz3 chỉ cần 1 cái vỗ tay vào cửa??
Vụ này nghe hãi đây, e mới lấy mazda3, tí về thử đánh đập em nó 1 lúc xem có cái gì bật ra không.
Sao vào autoblog toàn báo lỗi nhỉ, có bác nào có link chính xác không.
DNT
1.083
76
Thế đang chạy vỗ tay thì cửa nó có mở ra không các bác? Nếu mà có thì...[8D]
T
TamPhan
Guest
Tanh thế ???
76
Ở VN thì xe bậc trung xe nào thợ chả mở được... các bác lo lắng quá làm gì...:D
73
Hà Nội
"We debated on posting this because we always seem to get nailed in the comments for advertising a new way to break the law, but we feel it's important information for Mazda3 owners and we're encouraged by Mazda's reaction to the situation so far. First the deets: it appears that a few owners of the Mazda3 have come back to their vehicles to find their valuables missing but no visible signs of breaking and entering like shattered glass or broken locks. The only clue left by thieves is a big dent in the front passenger door. Canadian website MobileMag.com got the skinny from an anonymous Mazda dealer that if one hits the passenger door hard in just the right spot it will affect the lock assembly mechanism and unlock the doors. Mystery solved.
Mazda has been aware of and working on this issue since October of 2006, and this month it began installing a "countermeasure" in all Mazda3s being built in Japan. For those who have already had their cars broken into, in some cases Mazda has agreed to install a reinforced door lock assembly and a protective plate to prevent the same break-in from happening again, though it has not offered to repair the dents. At this point, Mazda does not consider this "trick" a defect in the product and it hasn't decided whether or not all Mazda3s will be called back to have the countermeasure installed.
We think they should be voluntary called back and have the countermeasures installed. While a thief will get into your vehicle one way or another if he wants to, being able to do it without smashing glass or looking terribly suspicious makes the Mazda3 a much more tempting target. Still, no one should leave valuables out in the open and give criminals a reason to target your vehicle. "
Vụ này thì tất nhiên là cũng thấy ghê ghê các bác nhỉ?
44
Thôi, toi. Cái chú nhà báo nào chơi anh em M3 mình quá. Bi giờ để xe ngoài phố, chú nào đọc bài trên Vnexpress đi qua cũng sẽ vỗ cho một phát để kiểm chứng. Xe có thể không mất, nhưng mấy chú Gara thì được mùa, bảo hiểm ắt méo mặt. Chắc phải làm cái biển báo "Không phải thử, cửa mở đấy" hoặc làm thêm cái khóa treo như Mr Bean mất.
137
Hà Nội
www.denthan.com
Em tò mò quá. Bác nào có M3 thì về thử rồi thông báo cho anh em đi. Nếu ko có mà có cơ hội thử cũng thử xem kết quả ra sao.
73
Hà Nội
"The only clue left by thieves is a big dent in the front passenger door."
Bác nào thử thì lưu ý, chắc chắn là mang cửa đi sơn lại nhé
Thôi thử làm gì!!
Đừng để gì trong xe là được, hoặc là nhớ để trong hộp đựng đồ và nhớ khóa hộp đựng đồ lại thôi
AXN confirmed
19
hình như đập bằng búa cửa sẽ mở ra dễ hơn đó
