319
10
Tối nay em search linh tinh thì tìm được chú này. Thấy cũng phù hợp, giá hạt dẻ nên xin các bác chỉ giáo thêm.
07-09 HYUNDAI SANTA FE
2 DIN 6.5" Car DVD Player, GPS, Bluetooth, iPod and More!
This unit come with iGo8 map for the GPS system
Bluetooth ready
Ipod adpter so you can see and touch the song you want to play from the unit screen.
AM/FM Radio.
Mini SD card and mini USB port with adapter.
Play CD, Mp3, VCD, burn CD, burn DVD, and DVD.
Back by 3 year SquareTrade Warranty (Must be purchase separately )
Specifices:
- Standard Double Din Mounting Size OEM FITMENT
- UI Language: English
- Car Audio & Video System
- Screen Size: 6.5 Inch
- Touch Screen Function
- Resolution: Digital 800x480 touch Screen
- Control Panel Night Illumination Function
- Compatible Format: MP4/DIVX5.0/DVD/VCD/MP3/CD/CD-RW/JPEG
- DVD OSD Language: English
- Audio/ Subtitle Language: English
- Support Bluetooth
- Built-in Microphone in the control panel
- Built-In USB Port/SD Slot
- TV system: PAL/NTSC
- Built-in Radio Tuner (30 Preset Stations)
FM (3*6)87.5-108MHz Increment 0.05MHz
AM (2*6)522-1620KHz Increment: 9 KHz
- Built-In RDS Radio Receiver Function
- External GPS Box
- iGo GPS Software Included
- Steering Wheel Control Function
- Built in amplifier FR/FL/RR/RL 4-Channel Audio Output
- Two Channel Video Output / One Channel Video Input /AUX Audio R/L Input (RCA)
- Support Back sight video Input
- 4×45W Surround Stereo
- Effect Compensation: POP ROCK CLASS
- Image Brightness /Contrast/ Color /Saturation adjustable
- Auto-memory Function
- Power Supply: DC 12V
- Max Working Current: 10A
GPS Features:
Map supported: Route66,TOMTOM, IGO,DESTINATOR etc.
Operation system: Windows CE 5.0
Processor: SAMSUNG High performance processor S3C2440A-40, Max.main frequency 400MHZ.
EMS Memory :64MB SDRAM
Storage device: 128MB NAND FLASH,Support SD Card.
Display output : CVBS+S-VIDEO output. (Resolution:480*234) or simulation RGB output .
Audio output: Stereo output of CD tone.
GPS specification: Adopt SiRF STAR III 20 channel and excessive high sensitivity GPS receiving module REB-3310, Orientation sensitivity reach -159dBm, Orientation presicion<10M,Orientation time of cold boot is 42S,Orientation time of warm boot is 35S,Orientation time of hot boot is 1S.
Power specification: Connect car power DC12V,Current<500mA;Max power
Consumption:4.5W(12V/360mA),Normal power consumption 3W(12V/250mA).
System parameters:
Working voltage DC 11V~14V
Working current MAX 15A
Standby current <25 mA
Video system Automatic PAL or NTSC
Radio parameters:
FM/ AM Frequency FM:87.5MHz~108MHz; AM:522KHz~1620KHz
Tune method PLL frequency complex tune
Display method TFT Graphical User Interface OSD
Storage quantity FM radio :18 channels, AM radio: 12 channels
Search method Automatic/manual
DVD parameters:
Video output range 1+10.2Vp-p (75)
Disc spec Diameter 12cm disc
Compatible disc DVD(NON REGION 1 )/VCD/CD/MP3/WMA/JPEG/MPEG4
Amplifier parameters:
Testing voltage 13.8 V
Maximum power output : 4×45W
Speaker impedance 8Ω (4-8 acceptable)
Audio parameters :
Track imbalance degree 2dB
Segregative degree 45db
Frequency response: 20Hz~20KHz(±3dB)
Volume adjustment :
Low 100HZ±7dB
Medium 1KHZ±7dB
High 10KHZ±7dB
Accessories
- 1×User's Manual
- 1×Remote Controller (Battery inside)
- 1×Power Cable
- 1×USB Cable
- 1×SD CARD with the GPS MAP
Other thing to know:
*-Advance Picture in Picture screen
*-Dual Zone, Can listen to music while in GPS mode
*-6 Disc Changer Memory ( 6 CD can be copy in to the unit memory for easy listen later )
*-Ipod ready- For easy touch screen controll
319
10
Cái này là China bác ạh!
Quái thật, em không làm sao mà paste ảnh của em nó vào 4R được, lúc soạn thì thấy ảnh nét như sony nhưng bấm post thì thành trắng phớ luôn. Mod ơi, xem giùm em với.
Cảm ơn nhiều nhiều!
4.840
40
Hà Nội
1.Lắp vừa vặn vào xe chỉ là 1 điều kiện cần, có vai trò rất nhỏ trong hệ thống nghe nhìn của xe.
2.Đã gọi là hệ thống nghe nhìn-> chất lượng âm thanh, độ sắc nét màn hình phải đặt lên hàng đầu.
3. 99,99% các sản phẩm Conan77 giới thiệu là hàng Trung Của Xỉ mả, chạy cho nó nhanh....
4. GPS nếu là hàng OEM cho SF nội địa thì chỉ xài được ở Hàn xẻng thôi...
Quay trở lại chủ đề Alpine, Pioneer đi các bác :)))
9.716
33
Ukraine
Hehe bác Kienvang nói thế nagy thì Conan cụt hứng ...nhưng mà đúng bác ơi , em vừa gắn cái bộ gối sau hàng Taiwan cho tuỵ nhỏ ... nói chung chất lượng màn hình chán so với Pioneer
319
10
Nếu không chắc chắn về nguồn gốc: Japan, Korea,... thì em vẫn thích đồ China xịn. Đến Iphone,... vẫn sản xuất tại Tung Của mà. Khiếp quả báo Hàn xèng hoặc .... nhưng kỳ thực là China.
Còn chỗ GPS thì không lo vì có cửa hàng đã fix được quả GPS các loại xe nội địa rồi các cụ ạ. Cụ tỉ thì các bác hỏi bác Gúc nhé.
Alpine và Pionner em cũng ham lắm, nhưng khiếp vụ cắt dây ra đấu nối. Nếu các nhãn hàng này mà có support riêng cho STF hoặc có option cho Santafe thì quá tuyệt.
Có lẽ đành chờ cơ hội xách một quả DVD nagavition của STF xịn thôi. :))
467
GPS Features:
Liệu có phải của Samsung không các bác nhi?
4.840
40
Hà Nội
huunhan2k nói:
GPS Features:
Bộ vi xử lí của Samsung thôi bác à! Cái này Trung Của chưa làm được :)))
