2.132
Engine and transmission
Engine type: 4 cylinders, 4-stroke, Inline Displacement: 1340 cc (81.87 cubic inches) Bore × stroke: 81 mm × 65 mm (oversquare - shortstroke) Cooling system: Water cooled Power: 196.87 HP (144.8 kW) @ 9500 rpm Torque: 155 Nm (15.81 kg-m) @ 7200 rpm Throttle: Cable operated Valves Valve train: DOHC, variable Valves per cylinder: 4 Fuel and ignition Sparks per cylinder: 1 Fuel supply system: Fuel injection Ignition type: Digital CDI Compression: 12.5:1 Engine mounting: Transverse Lubrication system: Wet sump Gear box: Manual 6-speed Clutch: Wet, multiple discs, cable operated Final drive: Chain Spark plug pipe type: NGK Starter: Electric Dimensions
Physical measures Length: 2190 mm Width: 735 mm Height: 1165 mm Wheel base: 1480 mm Trail: 98 mm Ground clearance: 120 mm Seat height: 805 mm Weight Curb weight: 260 kg Dry weight: 220 kg Chassis and suspension
Frame type: aluminium, twin spar Front Suspension: Cartridge - upside-down Suspension travel: 120 mm Fork angle: 24° Brake: Twin Disk, Ø310 mm Tire: 120 / 70 R17 ZR Rear Suspension: mono shock, Swingarm Suspension travel: 140 mm Brake: Disk, Ø260 mm Tire: 190 / 50 R17 ZR Other
ABS available: No Power-to-weight ratio: 0.56 HP/kg (1.80 kg/HP) Acceleration (0-100 km/h): 2.8 sec Top speed: 370 km/h Fuel capacity: 21 l Number of riders: 2 persons
http://forum.vietyo.com/topic/nhin-thong-so-khung-2011-suzuki-gsx-1340-r-hayabusa-136073.html
1.996
37
xe này chạy 3 chăm 7 luôn à, nếu gắn 2 cánh nữa là có thể cất cánh như máy bay nhể ?!:D
