Em dang muốn lắp bộ âm thanh cho con Yaris giờ em muốn thay bộ âm thanh và đã tìm hiểu cấu hình như sau mong các Huynh giúp đỡ để em chọn được bộ âm thanh tốt
các bác giúp em nhé! vì em gà quá
-Giờ em đang dùng đầu DVD Kenwood 6309
em muốn thay 4 Loa canh cửa
-2 cái Infinity Perfect 5.1
5-1/4" Component Speakers System
[/img]
Sensitivity: 89 dB
RMS Power Range : 25-100 Watts
Peak Power Handling: 400 Watts
Frequency response: 80-23000 Hz
Diameter: 5.25 Inch
Deep-anodized-aluminum woofer cone
1" edge-driven, deep-anodized-aluminum dome tweeter
I-Mount tweeter mounting system for flush, surface, or angled mounting
Butyl rubber surround
2-way crossovers (high-pass/low-pass at 3500 Hz, 24 dB/octave)
Frequency response 80-23,000 Hz
Recommended power range 25-100 watts RMS
Peak power handling 400 watts
Sensitivity 89 dB
Top-mount depth 2-7/16"
Priced per pair
Component speakers are usually come as a pair unless noted differently.
2.********
Alpine SPX-17REF
[/img]
Sensitivity: 89.5 dB
RMS Power Range : 75 Watts
Peak Power Handling: 225 Watts
Frequency response: 35-40000 Hz
Diameter: 6.5 Inch
Features
Speaker Features
Neodymium Woofer Magnet
Cross-Rib Aluminum cone
1" Ring-Dome Tweeter
NBR Surround
Cast Aluminum Frame
Coax/Comp Convertible
Multiple Crossover Tuning Options with minimum phase shift
Crossover Features
Thermal Transfer Chassis Design
Heat Sink Resistors
Heavy Gauge Air Core Inductors
Metalized Poly Capacitors
4-level TW adjustment
Bi-amp capability
TW protection
Gold Plated Insert Terminals w/tab
Secure One-Snap Cover
Priced per pair
Amplifiers
1********
Amplifiers
Pioneer Premier PRS-D4100F
[/img]
Technical Specification
RMS Power Range : 75-300 Watts
Number Of Channels: 4
Maximum Power: 1200 Watts
Low Frequency response: 10 Hz
High Frequency Response: 40000 Hz
Built In Crossovers: Yes
Channel Separation: Yes
Features
1200 Watts Maximum Power
Bridgeable 4/3/2 Channel
ICE-power Full-Range Class FD
Output Power (4 Ohm, <=1% THD): 75 Watts x 4
Output Power (4 Ohm Bridged, <=1% THD): 300 Watts x 2
Output Power (2 Ohm, <=1% THD): 150 Watts x 4
Signal to Noise (1 Watt into 4 Ohms): 80 dBA
Peak Music Power: 1200 Watts
Signal-to-Noise Ratio: 100 dB
Dimensions: 11-15/16" x 2-3/16" x 7-11/16"
4 Channel (Gold Plated) RCA Input Jacks
RCA Outputs (Pass Thru)
Screw-Type Speaker Terminals
MOSFET Output Section
Class-D Design
Hi-Volt (400mV~6.5V) Input Level Control
4ch. HPF/LPF Built-in Crossover
Crossover Frequency Range: 40~500Hz, -12dB/Oct.
2.**********
Alpine PDX-4.100
RMS Power Range : 4x100 Watts
Low Frequency response: 20 Hz
High Frequency Response: 20000 Hz
Features
4-Channel class-D car amplifier
4/3/2 Channel Operation
100 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
CEA-2006 compliant
Stackable Installation Design with front-panel controls
Thermal Management Processor
Adjustable Crossover (HP/LP)
MOSFET Power Supply
DC-DC PWM Power Supply
MOSFET Final Outputs
STAR Circuitry
Auto Over-Current Protection
Top Mounted Blue LED Power/Status Indicator
Integrated Wire and Mounting Screw Terminals
Input Channel Selector
Input Mode Selector Switch
One Side Terminal Layout
Gold Plated RCA Input Connectors
Continuously Adjustable Gain Control
Gold Plated Power Screw Terminals
4-Layer Glass Epoxy PC Board
Speaker Quick Connect
fuse rating: 30A x 2
10-3/16"W x 2-1/2"H x 8-1/2"D
-------Subwoofers--------
1.Infinity BassLink II
[/img]
RMS Power Range : 250 Watts
High Frequency Response: 120 Hz
Diameter: 10 Inch
Features
Compact powered subwoofer
10" square woofer and passive radiator
Class D 250-watt amplifier
Wired volume control with 16-1/4' cable
Variable low-pass crossover (50-120 Hz at 12 dB per octave)
Bass boost (-6 dB to +3 dB at 40 Hz)
Phase control (0-180 degrees)
Frequency response: 20-120 Hz
Docking port for optional BassLink 4sc multichannel expansion module
Preamp- and speaker-level inputs
Vertical mounting dimensions (with mounting feet): 15"W x 15"H x 10-1/4"D
Horizontal mounting dimensions (with mounting feet): 15"W x 9-3/4"H x 15-1/8"D
Priced per speaker
Subwoofers are usually come as a single speaker unless noted differently.
2.*******
Alpine PLT-5 LAT Subwoofer System
[/img]
amplified subwoofer system with Linear Array Transducer (LAT) technology
six 5-inch woofer cones in Ultra Reflex subwoofer box
Alpine PDX 250-watt RMS digital amplifier
variable low-pass filter (50-200 Hz, 24 dB/octave)
bass boost (0-12 dB @ 45 Hz) with wired remote control
subsonic filter (15 Hz, 24 dB/octave)
phase control (0, 180 degrees)
speaker- and preamp-level inputs
8-gauge power and ground leads recommended — wiring not included with system
21-5/8"W x 13-3/8"H x 8-7/8"D1 x 6-3/16"D2
các bác giup em mói nhé! em không biết chon ra sao mong các bác chỉ giáo cho em
Thank các bác nhiều ạ mong được anh em tư vấn sớm
