RE: Piaggio Beverly 125cc
Spec của em này như sau 250/125
PIAGGIO BEVERLY 250/125
Engine Single cylinder 4 stroke Piaggio QUASAR Single cylinder 4 stroke Piaggio LEADER
Displacement 244 cc 124 cc
Bore / stroke 72 mm / 60 mm 57 mm / 48.6 mm
Compression ratio 11: 1 12.3: 1
Max. power 22 hp at 8,250 rpm 15 hp at 9,500 rpm
Max. torque 20.2 Nm a 6,500 rpm 12 Nm at 8,000 rpm
Fuel Unleaded
Distribution SOHC, 4 valve
Cooling Liquid
Lubrication Wet sump
Start Electric
Gears CVT and torque server
Clutch Dry automatic centrifugal type
Frame Twin cradle tubes in high tensile steel
Front suspension Telescopic fork, Ø 35 mm shafts, 104 mm travel
Rear suspension Dual hydraulic shock absorber, 4-position spring preload, 90 mm travel
Front brake Ø 260 mm disc, floating calliper with two pistons
Rear brake Ø 260 mm disc, floating calliper with opposed pistons
Front wheel rim Die-cast aluminium alloy 3.00 x 16"
Rear wheel rim Die-cast aluminium alloy 3.50 x 16"
Front tyre Tubeless 110/70 16"
Rear tyre Tubeless 140/70 16"
Length 2,110 mm
Width 760 mm
Seat height 785 mm
Wheelbase 1,470 mm
Dry weight 149 kg
Fuel tank capacity 10 litres (includes 2.2 litres reserve)
Max. speed 125 km/h 104 km/h
Consumption (ECE 40 cycle) 25 km/l 24 km/l
Emissions Euro 2
Và spec của SH125
Model: Honda SH 125
Year: 2002
Category: Scooter
Rating: 74.8 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 13.80 HP (10.1 kW)) @ 9000 RPM
Torque: 11.50 Nm (1.2 kgf-m or 8.5 ft.lbs) @ 7250 RPM
Compression: 11.0:1
Bore x stroke: 52.4 x 57.8 mm (2.1 x 2.3 inches)
Gearbox: Automatic
More details Consult a Honda repair manual.
Physical measures
Dry weight: 123.1 kg (271.4 pounds)
Seat height: 780 mm (30.7 inches) If adjustable, lowest setting.
Overall height: 1,145 mm (45.1 inches)
Overall length: 2,020 mm (79.5 inches)
Overall width: 705 mm (27.8 inches)
Ground clearance: 126 mm (5.0 inches)
Wheelbase: 1,335 mm (52.6 inches)
Chassis and dimensions
Front suspension travel: 120 mm (4.7 inches)
Rear suspension travel: 70 mm (2.8 inches)
Front tyre dimensions: 100/80-16 50L
Rear tyre dimensions: 120/80-16 60L
Front brakes: Single disc
Front brakes diameter: 220 mm (8.7 inches)
Rear brakes: Expanding brake
Rear brakes diameter: 130 mm (5.1 inches)
Speed and acceleration
Power/weight ratio: 0.1121 HP/kg
Other specifications
Fuel capacity: 8.30 litres (2.19 gallons)
Xác em Beverly này nặng hơn SH125 26kg [8|],power lại mạnh hơn 1.8HP nên em nghĩ khả năng tăng tốc không kém SH125 là mấy,đúng là em này hay bị tèo đồng hồ điện tử,vào hãng thay là 3tr .Ngoài ra em này còn hay hỏng vặt hay khi mua xe nên chú ý những điểm gì nữa ạ,bác nào đã từng kinh qua và có kinh nghiệm xin cho chút ý kiến quý báu
