Hỏi/Đáp Kỹ Thuật powershift vs selectshift
275
45
Các cụ cho em hỏi sự khác nhau giữa 2 cái này ạ. mê Ford focus mà lăn tăn quá.
Careful with what Ford refers as "Select-Shift".
In their order guides, Select-Shift term is used for the normal 6 speed transmission which has the +/- toggle button on the gear shift which allows the driver to manually shift with the gear shift in S location.
Powershift name is the name for all of Ford's dual clutch transmission, which can have the term Select-Shift attached to the Powershift name as well.
Example from a Focus Order Guide
6-speed PowerShift Automatic Transmission with
SelectShift® (SST with thumb switch on gear shifter)
6-speed Automatic Transmission with SelectShift® (SST with thumb switch on
gear shifter)
Note: Only available in the EcoBoost® Appearance Package (67E)
