467
13
lang thang trên Net mình thây có cái này, không biêt có nên găn không ? Các Bác cho ý kiên vơi'.
http://www.gruppem.co.jp/news/newsen/item_253.html
The mass filter case where engine room capacity is harnessed in the maximum is designed. Engine power and the adapter pipe for air mass sensors important for ECU setting were also made with carbon by the test & try, and the product adhering to a performance side and a quality was made. Furthermore, the run wind from the front is direct inhaled in the aluminium air guide installed in a grill reverse side area.
It effects by repeating a chassis dynamo test and a run test, and power and torque advance all over the districts.It is preeminent for especially that it can blow going up up to 3,000 to 5,000rpm.A powerful air intake sound is also united with the presence in the engine room when opening a bonnet, and it is satisfied with the product made from real carbon of Japanese making of all.
(This product installation needs the desorption work of a front bumper)
2.477
2.961
E ko bit, vi duong Saigon e chay ko len het cs duoc
1.256
103
sigfe nói:
Lâu lâu chỉ cần tỏa sáng vài giây thôi :D chứ sáng liên tục thì chỉ có bóng đèn :D:D
