4.804
87.929
vechai Tập Lái
Tham gia ngày:
13/1/18
Mới
2 lỗi:
- Lỗi software của 2018 Outback và Legacy không bật đèn báo sắp hết xăng và tính sai quãng đường còn đi được. Vì lỗi này xe có thể hết xăng và chết máy trên đường gia tăng khả năng tai nạn.
- Lỗi lò xo cò xú páp của 2012, 2014 Impreza và 2013 BRZ, XV Crosstrek và Toyota Scion FR-S có thể gãy làm chết máy.
DETROIT — Subaru is recalling about 640,000 vehicles worldwide to fix two problems that can cause them to stall.
The first recall covers about 229,000 Outback and Legacy vehicles in the U.S. from the 2018 model year. Government documents say a software problem can stop the low-fuel warning light from illuminating and make the miles-to-empty display inaccurate. The problem can cause drivers to run out of fuel and stall, increasing the risk of a crash.
The other recall covers Subaru Imprezas from 2012 to 2014 and the 2013 BRZ, XV Crosstrek and Toyota Scion FR-S.
The engine valve springs in about 411,000 vehicles worldwide can fracture, causing the engines to malfunction or stall.
Dealers will replace the springs. Toyota and Subaru jointly designed the FR-S sports car.
In both recalls, owners will be notified starting in December, Subaru said. In the fuel indicator recall, dealers will reprogram the software. If reprogramming tools aren’t ready, owners will be notified by letter again when they are. In the valve springs recall, if parts aren’t ready, owners will be notified a second time of when they should take vehicles in for repairs.
Subaru says it has no reports of crashes or injuries due to either problem.
Copyright 2018 The Associated Press. All rights reserved. This material may not be published, broadcast, rewritten or redistributed.
https://www.washingtonpost.com/nati...ory.html?noredirect=on&utm_term=.40f2380d5701
