[tube]http://www.youtube.com/watch?v=HQ7R_buZPSo[/tube]
2009 Subaru WRX STI
650 WHP
Máy:
- CP SR5 2.65L race engine, CP billet 84mm stroker crankshaft, Pauter billet Long rods, CP spec, J/E forged pistons, CP spec, Subaru “Gold” STI rod bearings, Subaru STI main bearings, piston rings, head gaskets, 10mm oil pump, camshafts, intake manifold, CP High flow water pump, CP Fuel rails with stainless steel lines, CP rotated twin scroll turbo kit with Garrett ball bearing turbo, Subaru twin scroll headers, ARP head studs, Tial 44 wastegate, CP cold air intake, K/N air filter, CP front mount intercooler, Air oil separator, Fuel swirl pot, Radiator tank, custom radiator, oil cooler, stainless steel exhaust with dual CP Megaphones, Bosch fuel pump and fuel injectors
Suspension:
- Tein Super Racing Coilovers, Cusco swaybars, CP custom front hubs, custom tie rods, custom front A arms
Ngoại thất và nội thất:
- CP carbon fiber roof, hood, STI carbon fiber roof scoop, front lip, Prodrive carbon fiber wing, carbon fiber OEM wing cover, carbon fiber dash, Syms carbon fiber mirrors and door panels, Recaro carbon / kevlar seats, customized for Ken Block, Willans seat belts, Sparco steering
Hộp Số, Mâm & Vỏ:
- KAPS six speed dog box, STI short through shifter, Exedy triple carbon clutch, Driveshaft Shop aluminum driveshaft and high performance axels, Volk TE37 wheels, Carbonetic front and rear carbon differentals, BFGoodrich KDW “Smokey” tires, Motul tranny and differential fluids
Điện tử:
- Motec M800 ECU, SDL digital dash display, SDC center diff controller, PDM power distribution module, Knock detection system, 5 bar MAP sensor
Thắng:
- Brembo Gran Turismo six piston monobloc front and four piston rear, STI brake bias controller, Prodrive / STI hydraulic hand brake, Stainless steel brake lines and fittings, Motul RBF 600 brake fluid
