Bác Da đỏ ơi biết xe này chưa cho cái cảm nhận về vận hành cũng nhụ tốc độ em nó nha
Lạng ngang qua web của megabike mới thấy con này
159 triệu ~7k5, thấy kiểu dáng ổn quá, 2 pô đút đít như Hornet mà 400cc, 50-60hp tùy phiên bản, cỡ này thì thay thế SF chắc ổn vì SF nhiều thanh niên chê "già", con này nhìn trẻ trung hơn
Thông số xe 2011 đây!
Model: Suzuki GSR 400
Year: 2011
Category: Naked bike
Rating: 62.3 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 398.00 ccm (24.29 cubic inches)
Engine type: In-line four, four-stroke
Power: 60.35 HP (44.1 kW)) @ 12000 RPM
Torque: 39.00 Nm (4.0 kgf-m or 28.8 ft.lbs) @ 10000 RPM
Compression: 12.2:1
Bore x stroke: 54.6 x 42.5 mm (2.1 x 1.7 inches)
Valves per cylinder: 4
Fuel control: DOHC
Ignition: Electronic
Cooling system: Liquid
Gearbox: 6-speed
Transmission type,
final drive: Chain
Clutch: Wet multi-plate
Chassis, suspension, brakes and wheels
Frame type: Diamond
Rake (fork angle): 25.3°
Trail: 104 mm (4.1 inches)
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 180/55-ZR17
Front brakes: Double disc. Optional ABS
Rear brakes: Single disc
Physical measures and capacities
Dry weight: 210.0 kg (463.0 pounds)
Weight incl. oil, gas, etc: 215.0 kg (474.0 pounds)
Power/weight ratio: 0.2874 HP/kg
Seat height: 785 mm (30.9 inches) If adjustable, lowest setting.
Overall height: 1,075 mm (42.3 inches)
Overall length: 2,090 mm (82.3 inches)
Overall width: 95 mm (3.7 inches)
Ground clearance: 130 mm (5.1 inches)
Wheelbase: 1,435 mm (56.5 inches)
Fuel capacity: 16.00 litres (4.23 gallons)
Oil capacity: 3.90 litres (0.26 quarts)
Other specifications
Starter: Electric
Color options: White, black, grey
