Camera của năm đâu? D800 ngon hơn
http://www.tipa.com/engli...103433.php?iExpand1=70
Hình như Canon tự sx cảm biến chứ ko mua? Nó là ít ỏi vài nhà sx có thể sx FF.
Giá vs Chất lượng
http://www.luminous-lands...marking_cameras2.shtml
Kết luận là có vẻ Canon hơi yếu về công sx chip. Nhưng cứ yếu hoài cũng kỳ nhỉ.
ps: em rảnh post chơi, ko phải chê canon fans nhé
Giờ em ko sài máy nào từ mấy hãng này.
Giá vs Chất lượng
Tuy nhiên Canon đang test công nghệ mới, không biết khi nào ra mắt.
<h3>Low ISO Dynamic Range and Canon</h3> At present, Canon cameras underperform on the Dynamic Range test or, more precisely, on dynamic range measured at low ISO settings. At high ISO, the Canon 1Dx actually has a better dynamic range than the D800(E), and the Canon 5D3 matches the D800(E) at high ISO. This confirms that newer Canon models like the 5D3 and the 1Dx are state-of-the-art as high ISO cameras.
But the problem with Canon (and all tested sensors except those with the latest and greatest Sony sensors) is that the dynamic range hardly increases when you go below about 800 ISO. This is consistent with test photos that show that the 5D3 cannot match the low ISO clean shadow performance of the D800(E), the K-5(II/IIs) or the D7000.
This is illustrated in Photo 2 that shows a 750x750 pixel crop of a 21 MPixel wedding[53] photo taken at 200 ISO on a Canon 5D Mark III. The top of the image is exposed at 100%[54], while the bottom contains 0.05% gray[55]. This implies an estimated dynamic range of 2000:1 or 11 EV. DxOMark’s more precise measurement gives 11.65 EV of dynamic range for the Canon 5D3 at the 200 ISO setting.
Note that the noise at the bottom of Photo 2 exhibits horizontal “banding”. As the camera was held in portrait mode, this is normally called vertical banding or “fixed-pattern column noise”. If you cannot see this (or details in the other photos) be sure you are viewing this on a calibrated monitor. And you may want to save the picture and inspect it in a trustworthy photo viewing application such as Photoshop, Lightroom or Capture One.
Sony claims[56] that they are the first and only sensor supplier so far that is able to avoid visible fixed pattern (column) noise. For this, Sony uses a combination of having on-chip analog to digital convertors (one ADC per column[57]) and a digital trick to elegantly subtract the black or empty level of each sensor pixel. In our rain & cups analogy, it is like emptying the cup before starting the measurement, first weighing it (with any residual water inside), then exposing the cup to rain, and then weighing the cup a second time. Subtracting the original weight avoids measurement errors due to the “empty” weight and due to measurement offsets. In sensor engineering, this technique is known as Correlated Double Sampling and is standard for both digital weighing[58] and for light sensors, but Sony has a somewhat cooler way to do this.
Canon users frequently wonder whether Canon will catch up, particularly in terms of low ISO dynamic range – given that it has lost the lead since the Nikon D3x back in late 2008. Some industry analysts[59] expect that Canon will catch up when they start using a new state-of-the-art 0.2 μm copper[60] sensor manufacturing process which they are currently testing. This allows Canon to switch from off-chip analog to digital converters to on-chip per-column ADCs.
Tạp chí popular photography nhé, không phải tự sướng hay sao vàng đất việt
http://www.popphoto.com/g...-canon-eos-5d-mark-iii
With ground-breaking low-light performance and Hollywood-esque video flair, the Mark III grabs our coveted Camera of the Year award
Thì hội nhiếp ảnh TIPA cũng vote cái khoản quay phim 5De 3 là nhất còn gì
TIPA uy tín hơn bác ls nhé.
http://en.wikipedia.org/w...mage_Press_Association
Thì TIPA là thằng gom những tạp chí nhiếp ảnh của châu Âu
Nói vui chứ 5 Dê 3 của bác là niềm ao ước mọi người rồi. Em ko có nên em chê thôi
Trờ lại chủ đề. Theo chấm điểm thì cảm biến ngày nay tốt hơn ngày xưa, crop hôm nay còn hơn FF xưa. Vậy thật sự lúc ra ảnh có đúng nhỉ? Em chả có máy nào để test.
Thực sự là em không đủ trình để thẩm định những bài viết trên các trang web này có công minh hay không?
Chiến lược marketing lobby của từng hãng cũng khác nhau lắm
Trước đây cũng có một vụ bê bối về việc test xe hơi rồi. Toàn những tạp chí và những trang web danh tiếng
