A1
14/12/03
2.550
4.854
We are sorry...
You are seeing this message because of one of the following reasons:
1. Your session timed out.
2. The server was restarted before you made a HTTP POST (posting a message, registering an account, login, etc.)
Problem #1:
You probably spent too much time and your session timed out. This is, however, rarely the cause of the problem because we implemented a session keep-alive mechanism to prevent this issue from happening. However, the server itself could have experienced some problems that prevented this mechanism to work as it should, and therefore we cannot completely rule out the possibility of this either.
You need to make sure your browser has cookies enabled. See below for instructions:
Netscape Communicator 4+:
* Select "Edit" from the browser Menu bar
* Select "Preferences"
* Double click on "Advanced"
* Verify that "Accept only cookies that get sent back to the originating server" is selected
* Select the "OK" button
Microsoft Internet Explorer 4+:
* Select "View" from the browser Menu bar
* Select "Internet Options"
* Select "Security" tab
* Select "Custom (for expert users)" security level and select the "Settings" button
* Locate "Cookies" and verify that "Allow per-session cookies (not stored)" is enabled
* Select the "OK" button on the "Security" window
* Select the "OK" button on the "Internet Options" window
If you already have cookies enabled and still experienced the problem, see problem #2 below for other possible causes.
Problem #2:
Your server experienced problems and was forced to restart. Restarting a server will erase all session data and our protective mechansim had no choice but to drop your HTTP POST because we had no way to identify you without valid session data.
Many forum administrators host their forums on shared servers, on which could have more than 200 sites hosted together. Sometimes the server has to be restarted because some badly written programs on other sites may drain the CPU/RAM and cause the IIS to restart itself. This is unfortunately an inevitable situation that many site administrators and its users have to face from time to time.
Technical Information
Em htường xuyên post bài bằng FF thì bị báo thế này, nhưng chuyển sang IE thì không sao.
Xin hỏi các bác cách khắc phục cho FF (em không dùng IE7 vì nó chuối quá).
Xin cảm ơn các bác.
3.605
168
RE: Tại sao Firefox post bài bị lỗi??
Bác thử tải bản mới nhất FF về xem sao. Chứ em toàn post bài qua FF không hà nhưng khi thêm icon "tình cảm" thì lúc được lúc không:D
1.137
Em dùng mạng VNN post Fast Reply bị y chang như trên....
12.148
2.304
Bình Thạnh -Tp HCM
Tui cũng dùng FF,thỉnh thỏang cũng post cả bài dài,khi chọn gửi bài mà quên Ctr-C và xui đúng lúc cái đồ quỉ Wifi_FPT chỗ tui nó đến lúc bắt mình đăng nhập là phải đăng nhập,xong nó lại bắt mình thế này: "bạn cần phải đăng nhập lại vào diễn đàn OS",rồi nó sẽ tặng cho mình 1cái thông báo dài như của bác Túi Khí và...mất bài.Nếu tui dùng Acoo Browser thì khi đăng nhập lại vào FPT nó hiện bảng The Page not found nhưng nếu tui chọn BACK vài lần sẽ tìm lại được bài mình đã post và khi đó chọn gửi bài là xong,không mất bài như trường hợp dùng FF.
Tui cũng từng gặp tình trạng dùng Acoo Browser thì insert được biểu tượng tình cảm còn nếu dùng FF thì không insert được biểu tượng tình cảm.
Được biết dùng IE hay có "lỗ thủng" nên tui chỉ chọn FF hoặc Acoo Browser mà thôi.Với máy tính của tui thì dùng Acoo duyệt nhanh hơn FF nhưng hay bị cắt ngang bởi một cảnh báo gì đó có từ DEBUG...OK.Nếu tui không chọn OK là cái thông báo này cứ hiện lên hòai mỗi khi vào một trang lạ hoặc tải một file gì đó rất phiền tóai!Còn nếu tui chọn OK thì nó lại bắt mình thực hiện nhiều bước tiếp theo cũng phiền tóai không kém...Cuối cùng tui lại chọn FF và luôn nhớ bấm Ctr-C mỗi khi viết xong bài của mình.
Bác Túi Khí dùng thử Acoo Browser xem có dễ chịu hơn không nhỉ?:D
P/S: Viết bài này xong là tui cũng bị lại như đã nên ở trên.May là đã Copy-Past vào M.WORD nên gửi được cho các bác đọc,nếu không đành bỏ cho rồi...:mad:
12.148
2.304
Bình Thạnh -Tp HCM
Tui cũng dùng FF,thỉnh thỏang cũng post cả bài dài,khi chọn gửi bài mà quên Ctr-C và xui đúng lúc cái đồ quỉ Wifi_FPT chỗ tui nó đến lúc bắt mình đăng nhập là phải đăng nhập,xong nó bắt mình đăng nhập lại vào OS -4R,rồi nó hiện cái thông báo dài như của bác Túi Khí và...mất bài.Nếu tui dùng Acoo Browser thì khi đăng nhập lại vào FPT nó hiện bảng The Page not found nhưng nếu tui chọn BACK vài lần sẽ tìm lại được bài mình đã post và khi đó chọn gửi bài là xong,không mất bài như trường hợp dùng FF.
---Hồi nãy bị lỗi giống bác Air Bag,tưởng hệ thống không cho gửi bài đó.Đăng nhập xong Paste lại bài viết và gửi được rồi,giờ xem lại thì thấy 2 lần post bài (trùng lắp) là sao nhỉ?
151
Vietnam
Nảy giờ em vẫn post bài bình thường bằng FF mà bác Túi khí. Tuy nhiên, theo kinh nghiệm bản thân, cứ mỗi khi viết bài dài thì lưu lại bằng Ctrl-C cho chắc ăn:D Bác nào viết phóng sự cho OS thì nhớ làm hẳn trong Word cho an toàn.
2.946
489
Từ trước giờ e cũng post bài = FF có sao đâu ! :)
6.835
145
em dùng FF cũng bị, đổi lại IE luôn, chuối cũng kệ, sống chung với lũ
