RE: Thèm FJ Cruiser
Em cũng mún ké vào nè . Em này giá 71K . bran new . 1 tháng có xe .
2008 Toyota FJ Cruiser - Base 4dr 4x4
Summary for the Base 4dr 4x4
Options
Engine: 4.0L V6 DOHC 24V w/VVT-i
Transmission: ECT 5-Speed Automatic
Wheels: 7.5 x 17" Steel
Tires: P265/70R17 Mud & Snow SBR BW STD STD PAINT
Monotone Paint Application
FA Fabric Seat Trim
Front Bucket Seats
Radio: AM/FM/CD
Audio System w/6-Speakers
Standard Equipment for the 2008 Toyota FJ Cruiser
Body Exterior
4 doors
Driver and passenger manual door mirrors
Metal-look door mirrors
3 skid plates
Two-tone clearcoat paint
Black bumpers
Convenience
Manual air conditioning
Driver 1-touch down
Manual tilt steering wheel
Rear door bins
Driver and passenger door bins
Full floor console
Passenger visor vanity mirror
Front and rear cupholders
Day-night rearview mirror
Power door locks with illuminated entry
Power front windows
Entertainment Features
AM/FM stereo radio
Single CD player
6 speakers
Fixed antenna
MP3 capability
Lighting, Visibility and Instrumentation
Halogen aero-composite headlights
Auto off headlights
Variable intermittent front windshield wipers
Low tire pressure warning
Voltmeter
Tachometer
Light tinted windows
Fixed rearmost windows
Rear window defroster
Off-Road Capability
Max ground clearance: 244mm (9.6")
Approach angle: 34.0 deg
Ramp breakover angle: 27 deg
Departure angle: 30.0 deg
Powertrain
239hp 4.0L DOHC 24 valve V-6 engine with variable valve control
Manual transfer case shift
Multi-Mode part-time 4 wheel drive
3.73 axle ratio
5 speed automatic transmission with overdrive
Emissions Type: LEV II
750 CCA battery
Fuel Economy City: 16mpg
Recommended fuel : premium unleaded
Fuel Economy Highway: 20mpg
Fuel Tank Capacity: 19.0gal.
Safety and Security
4-wheel ABS brakes
Dual front impact airbags
Overhead airbags
Power door locks
3 manually adjustable rear head restraints
Manually adjustable front head restraints
Ignition disable
Airbag occupancy sensor
Dual seat mounted side impact airbags
ABS and driveline traction control
Brake assist
4-wheel disc brakes
Stability control
Seats and Trim
Seating capacity of 5
Front bucket seats
8-way driver seat adjustment
Manual height adjustable driver seat
4-way passenger seat adjustment
Driver armrest
60-40 folding rear split-bench seat
Premium cloth seat upholstery
Body-colored/metal-look instrument panel insert
Specs and Dimensions
Engine displacement: 4.0L
Cylinders: V-6
Engine horsepower: 239hp @ 5,200RPM
Engine torque: 278 lb.-ft. @ 3,700RPM
Bore x stroke : 94.0mm x 95.0mm ( 3.70" x 3.74")
Compression ratio: 10.00:1
5 speed transmission
Gear ratios (1st): 3.52
Gear ratios (2nd): 2.04
Gear ratios (3rd): 1.40
Gear ratios (4th): 1.00
Gear ratios (5th): .72
Gear ratios (reverse): 3.22
Curb weight: 1,948kg (4,295lbs)
GVWR: 5,570lbs.
Payload: 1,325lbs.
Towing capacity : 2,268kg (5,000lbs)
Exterior length: 4,671mm (183.9")
Exterior body width: 1,895mm (74.6")
Exterior height: 1,829mm (72.0")
Wheelbase: 2,690mm (105.9")
Front tread: 63.2"
Rear tread: 63.6"
Turning radius: 6.4m (20.9')
Front legroom: 1,064mm (41.9")
Rear legroom: 795mm (31.3")
Front headroom: 1,049mm (41.3")
Rear headroom: 1,024mm (40.3")
Front hiproom: 1,407mm (55.4")
Rear hiproom: 1,295mm (51.0")
Front shoulder room: 1,483mm (58.4")
Rear shoulder room: 1,369mm (53.9")
Interior cargo volume: 790L (27.9 cu.ft.)
Interior cargo volume seats folded: 1,892L (66.8 cu.ft.)
Interior maximum cargo volume: 1,892L (66.8 cu.ft.)
Suspension/Handling
Front independent double wishbone suspension with anti-roll bar, gas-pressurized shocks
Rear rigid axle multi-link suspension with anti-roll bar, gas-pressurized shocks
Front and rear 17" x 7.5" black steel wheels
P265/70SR17 BSW M+S front and rear tires
Speed-sensing hydraulic power-assisted rack-pinion steering
