1.341
391
Laptop cùi bắp của em mấy hôm nay Outlook chạy như rùa. Kh  Turn Off thì lúc nào máy cũng báo còn 1 ông ThorConnWnn đang hoạt động. Cái này phải vi rút không các bác? Em quét đủ thứ mà nó vẫn... cười khà khà mỗi khi tắt máy. Có bác nào giúp em vụ này với, em cám ơn trước.
1.776
121
FFC
Em chưa gặp lỗi này nhưng có thông tin cho bác đây ạ. hinh như là ThorConnWndClass bác ơi.
When you start Outlook, it has to also load all add-ons and plug-ins that
are installed for it. When Outlook exits, it first has to unload all these
add-ons and plug-ins. So it appears you have an add-on or plug-in that
errors on exit. Start Outlook in its safe mode ("outlook.exe /safe") to see
if the problem goes away as none of the add-ons and plug-ins get loaded in
safe mode (so they don't have to be unloaded later).
If Outlook's safe mode works, disable all the add-ons and plug-ins. Look
under Tools -> Options -> Other -> Advanced to see what add-ons and plug-ins
you have installed. Then disable them to see, exit Outlook, reload Outlook,
and then check if exiting Outlook generates the error again. If not, keep
reenabling them one at a time, cycle through Outlook and exit again until
you see the error reappear, and then you know which add-on or plug-in is
causing the problem.
Have you tried using Detect and Repair (under an Office component's Help
menu)? You will need the install CD (and then follow with Office updates).
I see a "MSN.ThorConnWndClass" string in the %windir%\system32\inetcomm.dll
file. A Google search on "+thorconnwndclass +outlook" shows it is an old
problem. Since you are using Windows XP,
http://support.microsoft.com/kb/q182022/ doesn't look like it applies but
you might want to visit Windows Update to make sure you have them all.
Are the copies of the file exactly the same under:
%windir%\system32\dllcache\inetcomm.dll
You may need to use a DOS prompt to get to the DLLcache folder since
Explorer will hide it (even if the option to display hidden files is enabled
as it is considered a special folder). Use the 'fc' DOS program at a DOS
prompt to compare the 2 files ("fc /b <file1> <file2>"). If they are not
the same, copy the one from the DLLcache folder, or run "sfc /scannow", and
then follow with a visit to Windows Update.
It could also be that you or malware have corrupted the registry so this DLL
is not properly registered (in the registry). Try running the following:
cd %windir%\system32
regsvr32 inetcomm.dll
