lót đường tiếp
EDL = Using the ABS sensors in reverse, this systems detects wheelspin and uses the brakes to slow the spinning wheel. This system works up to 50mph.
ASR = Used on FWD cars. Cuts back engine power until traction is regained if wheel slippage exceeds the ability of the EDL to cope. Works over all speeds.
QTR = has no front to rear or side to side bias. Optimally, it sends 25% to each wheel. Up to 66% of the total power can be directed to one wheel. The center diff is a mechanical unit that does not require slippage to activate a clutch or viscous coupling. The front and rear diffs are open and rely on the EDL to re-distribute power from side to side.
ESP = Uses yaw sensors as well as steering angle sensors and speed sensors. Recognizes when the car is no longer traveling on its intended path when steering angle does not co-oincide with yaw sensors. Selectively brakes different wheels ( like a tank slowing its tracks on one side and speeding them up on the other to complete a turn ), and if this is not enough to bring the car back in line, power is reduced.
EBD = electronic brake-force distribution. The car does not have a preset bias from front to rear like most cars, but uses the ABS sensors to detect impending lock-up and regulate brake force seperately at each wheel. Keeps the car more stable if you have to brake and turn at the same time.
Nếu bác hỏi 'thuật ngữ" thì tên riêng Audi không có liên quan. Nếu bác cho AUDI là viết tắt cũng không phải. tên hãng xe AUDI xuất phát là từ tên của người sáng lập AUGUST HORCH. "Horch" có nghĩa là "nghe" khi dịch ra tiếng latinh thì là "Audi"boy_cadillac nói:Xin chào các bác!
Các bác cho em hỏi, bác nào biết trang web nào nói về thuật ngữ viết tắt của hãng xe Audi không ạ. VD ELECTRONIC BRAKE DISTRIBUTOR, viết tắt ( EBD ), Phân bổ lực phanh): bác nào biết thì pm em nhé. Xin cảm ơn các bác.
Cần cù bù khả năng.
