RE: Các bác tư vấn giúp em mua Honda Shadow, VTX hoặc Harley Davision VROD
Làm sao Honda có thể so với V-Rod hả bác?
GENERAL INFORMATION
Insurance Get an Insurance Quote
Manufacturer Honda
Model Year 2006
Model VTX™1300C (VTX1300C)
M.S.R.P. $9,599.00*
POWERTRAIN
Engine Liquid-cooled 52-degree V-twin
Displacement 1312 cc
Bore x Stroke 89.5 mm x 104.3 mm
Compression Ratio 9.2:1
Fuel System Single 38 mm CV
DRIVETRAIN
Carburetion
Ignition Digital with three-dimensional mapping, two spark plugs per cylinder
Transmission 5-speed
Final Drive Shaft
DIMENSIONS
Wheelbase 64.45 in.
Seat Height 27.46 in.
Dry Weight 641.0 lbs.
Fuel Capacity 4.8 gal. including 1.0 gal. reserve
COLOR OPTIONS
Colors Black, Candy Black Cherry (additional cost), Candy Orange (additional cost), Dark Gray Metallic (additional cost)
BRAKES / WHEELS / TIRES
Suspension Front: 41 mm fork; 5.1 in. travel
Rear: Dual shocks with five-position spring-preload adjustability; 3.6 in. travel
Brakes Front: Single 336 mm disc with twin-piston caliper
Rear: Single 296 mm disc with single-piston caliper
Tires Front: 110/90-19 M/C
Rear: 170/80-15 M/C
Rake 32°
Trail 5.9 in. (149 mm)
V-ROD
SPECIFICATIONS 2001 Harley-Davidson V-Rod
Designation: VRSCA
Suggested base price: $16,995
Standard colors: Anodized aluminum only
Harley-Davidson web site: Harley-Davidson.com
V-Rod owners group: Yahoo! V-Rod eGroup
For 2004, the V-Rod is available in colors, including blue.
ENGINE & DRIVETRAIN
Type: Liquid-cooled 60-degree 1130cc V-twin
Valve arrangement: Dual overhead cam, chain driven
Displacement, bore x stroke: 1130cc, 100 x 72mm
Compression ratio: 11.3:1
Carburetion: Sequential Port Electronic Fuel Injection (SPEFI)
Lubrication: Wet sump, 4.5 qt.
Minimum fuel grade: 92 octane
Transmission: 5 speed, dog and pocket (spur type first-fifth gear, others helical)
Final drive: Belt
2004 also brought the very similar VRSCB, with black frame and different handlebar mounting.
CHASSIS
Wet weight: 620 lb.
GVWR: 1022 lb.
Wheelbase: 67.5 in.
Overall length: 93.6 in.
Rake/trail: 34 degress / 3.9 in.
Front tire: 120/70ZR-19
Rear tire: 180/55ZR-18
Front brake: Four-piston caliper, dual 293mm discs
Rear brake: Four-piston caliper, single 293mm disc
Front suspension: 49mm custom stanchions, 3.94 in. travel
Rear suspension: Dual shocks, 2.36 in. travel
Fuel capacity: 3.7 gal.
Seat height: 26.0 in.
Inseam equivalent: 32 in.
Handlebar width: 28.5 in.
H-D has a complete accessory line for the 'Rod.
ELECTRICAL & INSTRUMENTATION
Charging output: 360 watts
Battery: 12v, 12 AH
Instruments: Electronic speedometer, tachometer, fuel gauge, LCD odometer/tripmeter with diagnostic capabilities, warning lights for high beams, neutral, oil pressure
PERFORMANCE
Fuel mileage: 33 to 39 mpg, 36.9-mpg average
Average range: 137 miles
Rpm at 60 mph, top-gear: 2700
200 yard, top-gear acceleration from 50 mph, terminal speed: 82.7 mph
Quarter-mile acceleration: 11.92 sec., 112.8 mph
