51
California
Đang là kể lể và kèm hình bên otofun
đây là những thứ đã thay đổi trên xe:
ACCESSORIES/COSMETIC:
-aftermarket oil reservoir cover
-polished oil cap,coolant caps
-billet fuel rails,custom fuel return system
-silver powder coated pulleys
-Samco red silicon hose kit
-Python polished hose lock kit
-polished cam gears & front engine cover
-clear corners
-personalize license plate/frame
-aluminum pedals
-custom billet alum. shift knob
-Top Secret hood bonnet dampers
AERODYNAMICS:
-Data System rear spoiler
-Nismo type N front bumper with custom grilles
-Extreme Dimensions side skirts
-Impul rear bumper
ENGINE/PERFORMANCE:
-SFR (Speed Force Racing) custom twin turbo which Includes:
2 - 304SS Exhaust Manifolds -
2 - 3'' 304SS Downpipe -
2 - Spearco Intercoolers
1 - 2.25'' Aluminum Intercooler Piping
1 - HKS SSQV BOV
1 - 3'' Intercooler piping w/ custom MAF Sensor Fitting
2 - K&N Air Filters
2 - Turbonetics 60-1 HiFi Turbos
1 - Oil Sump Tank
1 - Stainless Oil Lines and Fittings
1 - Mocal Oil Pump
2 - 38mm Tial Wastegates
2 - Wastegate Dump Tubes
2 - Turbo Elbows inlets / outlets
1 - Split Second Fuel Controller
2 - CNC Mounting Brackets for Turbos
2 - 3-an Oil Feed lines, tees and fittings
10 - Silicone hoses and Clamps
-Mobil 1 synthetic oil 15w50
-Arias Pistons 8.5:1 comp.
-Carrillo H-beam connecting rods
-Bearings,gaskets
-ARP head/main studs
-Nismo cams
-polish/port head
-ferrera 1mm oversize valves,springs,retainers
-Fuel system,SX pump,regulator,SS lines,rails
-720cc RC engineer injector
-FTC fuel and timing controller
-Greddy boost controler
-NGK 1 steps Colder Iridium spark plugs
-Technosquare reflashed L-spec
DRIVETRAIN/SUSPENSION:
-race spec. built transmission
-high stall torque converter
-Cusco sway bars.front/rear
-Tokico D-spec dampers
-Tein H-tech springs
EXHAUST/HEADERS:
-SFR custom polished intake manifold
-SFR test pipe/y-pipe
-Fujitsubo legalis-R exhaust with magnaflow custom tips
BRAKES
-stoptech red caliper 14" drilled rotor front
-stoptech red caliper 14" drilled rotor rear
-Stainless steel lines
-Motul fluids
-Hawk HPS pads
WHEELS/TIRES
-Custom 3 pcs HRE 547 splitted 5 spokes fully polished:
19x8.5 front +23 offset/ 19x10 rear +31 offset
-BFgoodrich G-Force KWD2 :245/35/19-285/35/19
ICE
-2 Boston acoustic pro 6 1/2" component speakers
-2 Boston acoustic 5 1/4" coaxial mid range drivers
-2 Image Dynamic subwoofers 10"
-1 Arc Audio amp 100x4
-1 Arc Audio amp 1000x2
-Custom fiberglass enclosure
-Tsunami wiring/grills
-Dynamat
Xe đã vào cuốn lịch , 2 Magazines và vài websites ,có đi show vài lần ,chụp hình với cả chục mẫu .
51
California
khakha cái cuối đó ai mà chẳng thích ?
về được 2 lần , lần cuối hồi 2011 .lần tới chưa biết ...đang để dành tiền cắc . :)
676
33
vậy hả bác? gớm thiệt. Kiểu này ra đường dư sức để kéo, khi cần :)
51
California
Thời hạn treo chân đã qua,giờ đã được up hình
Nhưng trước hết nhà em xin giới thiệu lên đây những cụ Siêu Xe Cổ Khủng này vì nhà em có thể môi giới cho các Đại Gia nào muốn chơi xe loại ngoại hạng hiếm này nhé.
1994 JAGUAR XK 220
1972 MASERATI GHIBLI SS 4.9L
1956 MERCEDES BENZ 300 SL GULLWING COUPE
1969 FERRARI GTC COUPE
Và đây là chiếc 2003 INFINITI G35 COUPE
Nó là thương hạng sang của dòng NISSAN
Trước giờ hình ảnh để trong một Photobucket FREE account cho nên bandwidth có giới hạn ,vì nhiều người thăm viếng nên đã đầy . Nay đã có account khác không sợ chuyện đó xảy ra nữa. Các bạn nào có câu hỏi gì xin đừng ngại .
Vài cái VIDEO trước nhé.
click vào cái link.
http://www.youtube.com/watch?v=XN_X5qStCRA
http://s406.photobucket.com/user/lo...solution Images/MVI_1444_zps55438fda.mp4.html
http://s406.photobucket.com/user/lo...solution Images/MVI_1389_zpsfb92392b.mp4.html
TKM confirmed
2.139
18.403
xe bác độ tới quá hơn 450hp lận, cho em hỏi bác bỏ vô xe này tiền độ khoảng $25k ko? niềm đam mê của em
