Nói chung là Lexus đi rất nhanh chán, đến Lx570 đi cũng bồng bềnh lắm. Chạy tốc độ cao không có cảm giác yên tâm như xe Đức. Nhưng có ưu điểm rất lớn đó là độ lành của xe Lexus rất cao, không lỗi lặt vặt như xe Đức và quan trọng đó là sau thời gian sử dụng chán bán Lexus ít lỗ hơn.
e copy . paste cho các bac coi
PRICE Base price : $58,900 (CAD) $44,950 (CAD) Monthly payments : $1,112/month
$848/month
ENGINE Type : V6 3.5 litres V6 3.5 litres Power : 302 hp @ 6,500 rpm (225 kW) 270 hp @ 6,200 rpm (201 kW) Torque : 273 lb·ft @ 3,500 - 5,250 rpm (370 N·m) 248 lb·ft @ 4,700 rpm (336 N·m) Induction : Atmospheric Atmospheric Power to weight ratio : N/A N/A Bore : 92 mm 94 mm Stroke : 86 mm 83 mm Fuel type : Premium Regular CO[sub]2[/sub] emissions : 4,968 kg/year 4,692 kg/year Ohter engines : none none Transmission : 7-speed automatic 6-speed automatic Drivetrain : AWD AWD VEHICLE TYPE / CATEGORY Vehicle type : SUV SUV Category : Midsize SUVs over $50,000 Midsize SUVs over $50,000 Assembly : Tuscaloosa, Alabama, É-U Cambridge, ON, Canada Generation : 3 3 What's new : N/A N/A FUEL EFFICIENCY / AUTONOMY City : 12.3 l/100km 11.8 l/100km Highway : 8.9 l/100km 8.3 l/100km Autonomy : 756 km 619 km TIRES / SUSPENSION / BRAKES / SAFETY Steering : rack and pinion, electrical variable assist rack and pinion, electrical variable assist Traction control : yes yes Stability control : yes yes Seat belts : 5 5 Airbags : 9 10 Front suspension : independent, double wishbones independent, Macpherson strut Rear suspension : independent, multi-link independent, double wishbones Front brakes : disc (ABS) disc (ABS) Rear brakes : disc (ABS) disc (ABS) Front tires : P255/50R19 P235/60R18 Rear tires : P255/50R19 P235/60R18 DIMENSIONS / WEIGHT Length : 4,804 mm (189″) 4,770 mm (188″) Width : 2,141 mm (84″) 1,885 mm (74″) Height : 1,796 mm (71″) 1,684 mm (66″) Wheelbase : 2,915 mm (115″) 2,740 mm (108″) Front track : 1,648 mm (65″) 1,630 mm (64″) Rear track : 1,663 mm (65″) 1,620 mm (64″) Weight : 2,130 kg (4,696 lbs) 2,050 kg (4,519 lbs) Weight distribution front-rear : 54% - 46% N/A CAPACITIES Fuel tank : 93 l (25 gal) 73 l (19 gal) Trunk : 690 to 2,010 l (24 to 71 ft[sup]3[/sup]) 1,132 to 2,273 l (40 to 80 ft[sup]3[/sup]) Towing : 3,500 kg (7,716 lbs) 1,590 kg (3,505 lbs) Box length : N/A N/A PERFORMANCE 0-100 km/h : 7.6 s 8.2 s 80-120 km/h : N/A 6.2 s Top speed : 210 km/h 180 km/h Braking distance : 44.0 m 42.0 m WARRANTY Base warranty : 4 years / 80,000 km 4 years / 80,000 km Powetrain warranty : 4 years / 80,000 km 6 years / 110,000 km Insurability rating : 2 Less than average N/A
