2.791
16.679
Re:Súng!
QV giỏi thì đọc cái nầy đi:
Operating mechanism
Diagram of an M16 rifle, firing
The main mechanism of operation for the rifle is known as direct gas impingement. Gas is tapped from the barrel as the bullet moves past a gas port located above the rifle's front sight base. The gas rushes into the port and down a gas tube, located above the barrel, which runs from the front sight base into the AR-15's upper receiver. Here, the gas tube protrudes into a "gas key" (bolt carrier key) which accepts the gas and funnels it into the bolt carrier.
The bolt and bolt carrier together form a piston, which is caused to expand as the cavity in the bolt carrier fills with high pressure gas. The bolt is locked into the barrel extension, so this expansion forces the bolt carrier backward a short distance in line with the stock of the rifle to first unlock the bolt. As the bolt carrier moves toward the butt of the gun, the bolt cam pin, riding in a slot on the bolt carrier, forces the bolt to turn and unlock from the barrel extension. (The gas system only serves to unlock the bolt while the projectile has long exited the barrel). Once the bolt is fully unlocked it begins its rearward movement along with the bolt carrier. The bolt's rearward motion extracts the empty cartridge case from the chamber, and as soon as the neck of the case clears the barrel extension, the bolt's spring-loaded ejector forces it out the ejection port in the side of the upper receiver. The bolt is much heavier than the projectile, and along with the recoil-spring pressure inside the stock buffer-tube performs the cartridge ejection function and chambers the following cartridge.
Đại khái là cái ống gas nầy sẽ unlock bolt carrier và làm nó move về phía sau động tác nầy sẽ :
- kéo võ đạn ra khỏi nòng súng
- lên cò
- nạp đạn mới khi bolt carrier chạy về phía trước
Hay
261
9
Re:Súng!
HP nói:
Hàng Mỹ nhìn ngon vãi. Đạn bác mua một đống vậy chắc cũng tốn lúa lắm.
Lần em sang chơi, vào shooting range mua có 1 hộp đạn súng ngắn (loại gì em không biết nhưng nghe thằng em nói là loại này dùng cho cảnh sát Mỹ hiện tại), băng đạn mười mấy viên lận, bắn êm, bác 9 cho em hỏi loại mà cảnh sát Mỹ đang dùng tên là gì ạ?. Xong 1 hộp hết USD85.00, đắt phết :)
Một lần đi bắn, em mua đạn khoảng vài trăm đô. Đống đạn em chụp, mua hết $400, 500 viên đạn cho AR, 200 viên đạn .45 và 50 viên đạn 9 ly.
Bác đi bắn ở trường bắn thì tốn $85 cho hai người cũng phải. Một hộp đạn khoảng $13 đến $23 (tùy theo bắn súng gì), cộng tiền mướn chỗ bắn, tiền mướn súng (nếu mình kô có súng riêng), tiền mướn kính, tai, tiền dọn dẹp vỏ đạn.
Cảnh Sát Mỹ hay dùng Glock, 9 ly, .40, .45.
@QV: Ai kô biết cái ống sắt màu bạc đó là gas tube?
@Anh Metro: Ku QV nó chỉ giỏi tài lanh. :D
Súng em ráp, các bộ phận A, B, C và F kô dùng đến trong hình QV đưa lên. Một bộ phận kô dùng đến trong hình đó nữa là A2 front sight base/gas block.
Những món cần mua để ráp xong cây này:
1. Quadrail (Troy VTAC 15")
http://troyind.com/%20/partners/viking-tactics/troy-vtac-battlerail-alpha-15
2. Optic (Aimpoint Pro)
http://www.opticsplanet.com/aimpoint-pro-patrol-rifle-optic-red-dot-riflescope-30mm.html
3. Flash suppressor/Flash hider. (Battlecomp) :)
http://battlecomp.com/index.php?main_page=product_info&cPath=6&products_id=4&zenid=8grfh46bgsm1vq0ju7eehcver5 [/i]
Số 1 thì hiện tại có hàng, số 2 và 3 hiện tại chỗ nào cũng hết hàng. :mad:
2.125
65
Houston, Texas
Re:Súng!
@ 9XD, METRO: Em search cái hình ra cho dễ nhìn thoai, lanh chanh tí đó mà :D
Chứ em cũng không biết nó là cái giề luôn :confused: .... Hahahaha
Vậy là anh 9XD sắp lắp xong cây thứ 2 rồi phải không ?! Nhìn cây màu đen chơi ống ngắm kia phê vật
6.038
1.066
Sài Gòn
Re:Súng!
@9XD: Cây này có mang về VN? Đánh trận giả cùng súng sơn chắc là ngon lắm đây!
261
9
Re:Súng!
@QV: Cây đen sắp xong, bây giờ có thể đem đi bắn thử. Mai anh đi tìm mua đạn cho nó.
@Wusnat: Em mà chơi bắn súng với mấy bác..em sợ mấy bác trốn hết..hehehe.
261
9
Re:Súng!
Em mới tìm mua được 2 món trong 3 món cần mua để ráp hoàn thành cây súng săn. Món 1 và 3 đã mua được, cộng thêm 2 món khác..:D Tốn gần 5 tờ ($493), chỗ này có bán ốm nhắm em muốn mua và rẻ hơn những chỗ kia $30. Nhưng nó cũng hết hàng!
261
9
Re:Súng!
Cây súng AR đầu tiên em ráp tốn hết $3008.50, vẫn còn thiếu vài món cần mua để gắn thêm.
Cây súng AR thứ hai em ráp cho đến hôm nay tốn hết $1417.70, vẫn còn thiếu vài món cần mua. :D
Đạn 300 ACC BLK hiếm quá, em tìm khắp nơi vẫn kô có để mua. Chẳng lẽ ráp xong, để treo trên tường làm kiểng! Kiểu này, em phải chi thêm tiền mua dụng cụ tự sản xuất đạn riêng cho mình. Em dư tính khoảng $800 đến $1000 cho bộ máy sản xuất đạn. :mad: Thay vì mua ở tiệm thì giá khoảng 48 xu (rẻ nhất hiện nay) một viên đạn, thì mình tự làm đạn chỉ tốn khoảng 20 xu một viên. Tính về lâu dài thì lơi nhiều lắm!
261
9
Re:Súng!
Ngồi xem lại mới thấy thiếu một thứ mua rồi mà quên cộng vô. :D Kô biết còn gì mua rồi mà em quên kô ta? Mua nhiều quá mà! Khi nào nhớ bổ sung thêm sau vậy. Hehe
2.791
16.679
Re:Súng!
9 Xây Dựng nói:
Théc méc cây súng săn là súng gì ?
261
9
Re:Súng!
METRO nói:
9 Xây Dựng nói:
Cây súng đen em đang ráp sắp xong là cây súng săn đó anh. Ngày mai, UPSP giao 4 món em mới mua hôm chủ nhật. Ráp xong chụp hình đưa lên anh coi hen.
