Re:Con nghiện accord
Cái Manual cho Accord 91 cả ngàn trang down trên mạng về nó không có sẵn mục lục nên mỗi lần mở lên tìm chỗ cần tra cứu khá mất thì giờ. Rảnh nằm 1 chỗ em làm cái mục lục để dễ tìm trang cần tra, post lên chia với các bác nào cần nhé
GENERAL
Chassis n Engine number 2
Lift n Support point 8
Special caution Items 12
Abbreviation 21
Special Tools 22
Standards n Service limits 26
Design Specification 41
Frame repair chart 45
Lubrication points 49
Maintenance Schedule 51
ENGINE TUNE UP
-Radiator cap testing 54
-Oil level Inspection 55
-Oil filter replacement 56
-Air cleaner inspection/replacement 58
-Compression pressure inspection 60
-Spark plug inspection 62
-Drive belt inspection 63
-Alternator (A/C) belt adjustment 64
-P/S pump belt adjustment 66
-Valve clearance adjustment 67
-Idle speed inspection/Adjustment 69
-Tailpipe emissions inspection 74
-Ignition timing inspection and setting 77
-Timing belt 85
-Timing balance belt 87
-Timing belt and Timing balance belt 88
-Cylinder head 93
-Engine removal/ installation 102
-Exhaust pipe and muffler 111
-Radiator 112
-Thermostat 117
-Water pump 118
PGM-CARB
Component locations 120
Vacuum connections 125
Electrical connections 134
TROUBLE SHOOTING
-Self- Diagnostic procedure 136
-How to read flow charts 138
-Symptom-to System chart 139
-PGM CARB control system:
+Oxygen sensor 141
+Vehicle speed sensor 143
+MAP sensor 144
+Vacuum switch 148
+TW sensor 151
+Ignition coil signal 153
+TA sensor 154
+Power source (IG1,Bat) and ground 156
+AT shift position signal (AT only) 157
+P/S oil pressure switch signal 159
+Air conditioning signal 161
-Carburetor 163
-Fuel supply system 206
-Air intake system 210
-Emission control system 213
PGM-FI
-Component locations 235
-Vacuum connections 240
-Electrical connections (with and w/o CATA) 252
TROUBLE SHOOTING
-Trouble shooting guide (w and w/o CATA) 254
-Self diagnostic procedure 261
-How to read flow chart 264
-Trouble shooting:
+ECU 265
+O2 sensor 269
+O2 sensor heater 273
+MAP sensor 275
+TDC/Crank/Cyl sensors 281
+Throttle angle sensor 283
+TA sensor 285
+IMA sensor (w/o CATA) 287
+PA sensor 289
+Ignition output signal 291
+Vehicle speed sensor 293
+AT FI signal A 295
+AT FI signal B 297
-Idle control system:
+Symptom trouble shooting guide 299
+EACV 301
+Air conditioning signal 305
+Alternator FR signal 307
+AT shift position signal 309
+Starter switch signal 311
+P/S oil pressure signal 312
+Fast idle valve 313
+Idle speed setting 314
-Fuel supply system 315
-Air intake system 324
-Emission control system 329
TRANSMISSION MECHANISM
Illustrated Index 341
Pedal free play 342
Clutch master cylinder 343
Slave cylinder 344
Release bearing and release folk 348
Pressure plate 349
Clutch disc 350
Flywheel 351
Transmission oil and back up light switch 352
Gear shift mechanism 353
Transmission assembly 355
Symptom to Component chart-Hydraulic system 361
Road test 365
Pressure testing 367
Stall speed test 373
Fluid level checking/changing 374
Component location 377
Circuit diagram 379
Symptom to Component chart-Electrical system 381
Electrical Trouble shooting flow chart 383
Lock-up control solenoid valve A/B 413
Shift control solenoid valve A/B 414
S switch and AT speed sensor 415
Symptom to Component chart-Hydraulic system 416
Road test 420
Pressure testing 422
Stall speed test 428
Fluid level checking/changing 429
Transmission removal 430
Transmission installation 435
Gear shift selector 440
Shift cable 441
Throttle control cable 443
Drive shaft removal 445
STEERING SYSTEM
Component location 455
General trouble shooting 457
Noise and vibration 460
Fluid leak 461
Pump belt adjustment 469
On-car check 470
Steering Wheel: Disassembly/ Reassembly 475
Steering pump 481
Steering Gearbox 491
Wheel alignment 530
Wheel measurement 540
Front Suspension 541
Rear Suspension 553
Brake 568
ALB (ABS) 605
ACCESSORIES
Doors 644
Windshield, Rear Window 660
Sunroof 673
Interior Trim 680
Dashboard 697
Front Bumper 698
Rear Bumper 699
Hood 700
Trunk Lid 701
Front Grille/Side Sill Panel 705
Roof Molding/ Side Moldings 706
Heater 707
Air Conditioner 744
Relay & Control unit locations 793
Wire harness & Ground locations 800
Fuses 801
Power Distribution 806
Ground Distribution 814
Battery 824
Ignition Switch 825
Starting System 827
Lighting System 828
Ignition System 837
Charging System 857
Gauge Location index 876
Lighting system 924
Sound system 942
Clock 951
Cigarette Lighter 952
Horns 953
Power door mirrors 954
Power seat 959
GENERAL
Abbreviation 21
Special Tools 22
ENGINE TUNE UP
-Timing belt 85
-Cylinder head 93
-Radiator 112
-Thermostat 117
-Water pump 118
PGM-CARB
TROUBLE SHOOTING
+Oxygen sensor 141
+MAP sensor 144
+Vacuum switch 148
+TW sensor 151
+TA sensor 154
-Carburetor 163
PGM-FI
TROUBLE SHOOTING
-Trouble shooting:
+ECU 265
+O2 sensor 269
+MAP sensor 275
+TA sensor 285
+PA sensor 289
+AT FI signal A 295
+AT FI signal B 297
+EACV 301
Pedal free play 342
Slave cylinder 344
Pressure plate 349
Clutch disc 350
Flywheel 351
Road test 365
Circuit diagram 379
Road test 420
Shift cable 441
STEERING SYSTEM
Fluid leak 461
On-car check 470
Steering pump 481
Wheel alignment 530
Rear Suspension 553
Brake 568
ALB (ABS) 605
ACCESSORIES
Doors 644
Sunroof 673
Interior Trim 680
Dashboard 697
Front Bumper 698
Rear Bumper 699
Hood 700
Trunk Lid 701
Heater 707
Air Conditioner 744
Fuses 801
Battery 824
Ignition Switch 825
Starting System 827
Lighting System 828
Ignition System 837
Charging System 857
Lighting system 924
Sound system 942
Clock 951
Horns 953
Power seat 959
