Re:ACCORD CLUB - PHÂN ĐÀ MIỀN BẮC !
chet that, xem lai hoa ra chu quan, mai thu sau ranh khong? anh em minh lam vai coc bia nhe? gan nha anh co vai hang ngon bo re, san chu check ho minh voi? xe moi thay may khac quan a, em ai nhung den check sang va mat bu ga. nhe? cam on chu truoc
674
Phamngoctuan nói:
Chiều nay em sẽ qua anh một lúc nhé!
674
songcongemdem73 nói:
Quan ơi ? Sơn toàn bộ xe à, dùng loại sơn gì ? giá bao nhiêu và địa chỉ ở đâu thế ?
Sơn lại toàn bộ luôn anh ạ. Sơn dupont ở một gara quen của cậu bạn em anh ạ. Bác có định spa cho V2 không ạ?
cam on Quan_nq da check ho, theo thong tin em tra cuu duoc thi day la loi 6: ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor, tam hieu la loi cam bien nhiet - (lam mat may).nhung van de la quat gio xe em bi dau tat chu khong qua role. mong cac bac cho y kien giup em.
Quan_nq: mot so loi code day quan oi: can dich code nao thi alo cho anh nhe
CODE DEFINITION
1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
* not 94-95
6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
* invalid code for non-equipped EGR valve vehicles
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14 IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector defective circuit or unplugged / defective sensor
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23 KS (Knock Sensor) defective circuit or unplugged / defective sensor
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
* invalid code for 1996
31 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41 Primary Oxygen Sensor - Heater circuit malfunction
43 Fuel Supply System defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 Automatic Transmission malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
3.265
448
Bắc trung bộ
Cụ Guc dịch :
1 Cảm biến oxy "A" (Tiểu học) bị lỗi mạch hoặc cắm / lỗi cảm biến
2 cảm biến oxy "B" khiếm khuyết mạch hoặc cắm / cảm biến bị lỗi
3 cảm biến MAP (Manifold áp suất tuyệt đối) bị lỗi mạch hoặc cắm / lỗi cảm biến
4 CKP cảm biến (trục cảm biến định vị) bị lỗi mạch hoặc cắm / lỗi cảm biến
5 MAP cảm biến (Manifold áp suất tuyệt đối) vấn đề cơ khí / đường ống bị ngắt kết nối
* Không 94-95
6 ECT cảm biến (động cơ làm mát nhiệt độ) bị lỗi mạch hoặc cắm / lỗi cảm biến
7 TP Sensor (Chức vụ Throttle) bị lỗi mạch hoặc cắm / lỗi cảm biến
8 TDC cảm biến (Top chết Center) bị lỗi mạch hoặc cắm / lỗi cảm biến
9 CYP cảm biến (xi lanh) bị lỗi mạch hoặc cắm / lỗi cảm biến
* Mã không hợp lệ cho cơ thể điều tiết tiêm Honda
** Mã không hợp lệ cho động cơ V6
10 IAT Sensor (Air Intake Nhiệt độ) bị lỗi mạch hoặc cắm / lỗi cảm biến
12 EGR nâng cảm biến (khí thải tuần hoàn) bị lỗi mạch hoặc cắm / lỗi cảm biến
* Mã không hợp lệ cho người không được trang bị xe van EGR
13 BARO cảm biến (áp suất khí quyển) bị lỗi mạch hoặc cắm / cảm biến bị lỗi
14 Van IAC (Idle Air Control) bị lỗi mạch hoặc cắm / lỗi cảm biến
15 đánh lửa Đầu ra tín hiệu bị mất tích hoặc bị lỗi tín hiệu đầu ra đánh lửa
16 nhiên liệu Injector hệ thống bị lỗi mạch hoặc cắm / khiếm khuyết phun nhiên liệu
17 VSS (Vehicle Speed ​​Sensor) bị lỗi mạch hoặc cắm / cảm biến bị lỗi
19 tự động truyền Khóa Lên điều khiển van điện từ khiếm khuyết mạch hoặc cắm / khiếm khuyết van điện từ
20 điện tải dò mạch bị lỗi hoặc cắm / cảm biến bị lỗi
21 VTEC Van điện từ mạch bị lỗi hoặc cắm / van điện từ khiếm khuyết
* Mã không hợp lệ cho động cơ không-VTEC
** Không hợp lệ cho cơ V6
22 VTEC áp suất dầu Chuyển khiếm khuyết mạch hoặc cắm / lỗi công tắc áp suất dầu
23 KS (Knock Sensor) mạch bị lỗi hoặc cắm / cảm biến bị lỗi
* Mã không hợp lệ cho cơ V6
30 tín hiệu tự động truyền động: "A" / SEAF / SEFA / TMA hoặc TMB mạch bị lỗi hoặc cắm / cảm biến bị lỗi
* Mã không hợp lệ trong năm 1996
31 tự động truyền tín hiệu "B" khiếm khuyết mạch hoặc cắm / cảm biến bị lỗi
41 Tiểu oxy cảm biến - nóng mạch sự cố
43 hệ thống cấp nhiên liệu bị lỗi hoặc trục trặc hệ thống cung cấp nhiên liệu
45 Hệ thống Quá nạc hoặc quá giàu trục trặc trong hệ thống giám sát nhiên liệu
48 LAF cảm biến (Lean khí nhiên liệu) bị lỗi mạch hoặc cắm / lỗi cảm biến
54 cảm biến CKF (trục Tốc độ biến động) bị lỗi mạch hoặc cắm / lỗi cảm biến
61 oxy cảm biến, nóng - Bộ cảm biến 1 (Tiểu học) điện áp cao, điện áp thấp, hoặc phản ứng chậm
63 oxy cảm biến, nóng - cảm biến 2 (Trung học) điện áp cao, điện áp thấp, hoặc phản ứng chậm
65 cảm biến oxy nóng (Trung học) bị hỏng hóc hoặc bị lỗi cảm biến oxy nóng
67 hệ thống chất xúc tác hiệu quả dưới ngưỡng bị hỏng hóc hoặc bị lỗi hệ thống chất xúc tác
70 sự cố truyền dẫn tự động với các điều khiển hộp số tự động
71 xi lanh 1 sự mất lửa hoặc Misfire ngẫu nhiên một điều kiện là hiện đó là tạo ra một sự mất lửa xi lanh
72 xi lanh 2 mất lửa hoặc Misfire ngẫu nhiên một điều kiện là hiện đó là tạo ra một sự mất lửa xi lanh
73 xi lanh 3 mất lửa hoặc Misfire ngẫu nhiên một điều kiện là hiện đó là tạo ra một sự mất lửa xi lanh
74 xi lanh 4 bị Misfire hay Misfire ngẫu nhiên một điều kiện là hiện đó là tạo ra một sự mất lửa xi lanh
80 khí thải tuần hoàn không đủ lưu lượng phát hiện
86 ECT cảm biến (động cơ làm mát nhiệt độ) mạch phạm vi / Kết quả hoạt động
90 bay hơi khí thải Hệ thống kiểm soát rò rỉ được phát hiện trong khu vực bồn chứa nhiên liệu
91 bồn nhiên liệu cảm biến áp suất đầu vào thấp
92 bay hơi khí thải Hệ thống kiểm soát không đủ lưu lượng cuộc thanh trừng
bac songcong oi, em thay 3 con cam bien nhiet : hai con giong nhau, 1 con co phan do nhiet do phai khong bac? ngay mai em moi dau role sau. vi tho no bao the
