RE: Aston Martin DB9 2009
DB9
Engine:
All alloy quad overhead cam 48 valve 5935cc V12. Compression ratio 10.3:1.
Visteon engine management controlling fuel injection, ignition, diagnostics and misfire detection system. Stainless steel by-pass valve exhaust system.
Transmission:
Shift by wire six speed auto transaxle. Six speed manual transaxle. Limited slip differential.
Final Drive Ratio: 3.15:1 (auto) 3.54:1 (man)
Steering: ZF Rack and pinion, servotronic speed sensitive power assistance 3.0 turns lock to lock. Column tilt and reach adjustment.
Brakes:
Front - Ventilated grooved steel discs 355mm diameter with alloy four piston Brembo monobloc calipers.
Rear - Ventilated steel discs 330mm diameter with four piston monobloc calipers and separate handbrake caliper.
Conti Teves stability control system including anti-lock braking activation system (ABS), electronic braking distribution (EBD), traction control (TC), electronic brake assist (EBA) and dynamic stability control (DSC).
Suspension:
Front - Independent aluminium double wishbone incorporating anti-dive geometry. Coil over aluminium bodied monotube dampers and anti-roll bar.
Rear - Independent double aluminium wishbone, coil over monotube dampers and anti-roll bar.
Body: Two door coupe body style with 2+2 seating. Extruded aluminium bonded monocoque. Aluminium and composite skin panels. Extruded aluminium door side impact protection beam.
Wheels and Tyres:
Unique lightweight aluminium alloy wheels 8½J x 19 (front), 9½J x 19 (rear),Bridgestone REO 50 235/40 ZR19 tyres (front), 275/35 ZR 19 (rear)
Boot Volume: 0.172 cu m (6.074 cu ft)
Turn Circle: 11.5 m
Fuel tank capacity: 85 litres, 95 RON unleaded fuel only.
Length: 4710 mm
Width: 1875 mm
Height: 1270 mm (Coupe)
Kerb Weight: 1710 kg (Coupe - Manual) 1800 kg (Coupe - Automatic)
Front Track: 1570 mm
Rear Track: 1560 mm
Cd: 0.35 (Coupe)
Fuel Consumption (Coupe Automatic): Litres/100 km (mpg)
Urban - 24.9 (11.4)
Extra Urban - 11.7 (24.2)
Combined - 16.5 (17.1)
CO2 Emissions (Coupe Automatic): 394 g/km
Maximum Power: 335 kW (450 bhp) @ 6000rpm
Maximum Torque: 570 Nm (420 Ib ft) @ 5000 rpm
Acceleration:
0-60 mph: 4.7 seconds (Coupe Manual)
0-100 km/h: 4.9 seconds (Coupe Manual)
0-60 mph: 4.9 seconds (Coupe Automatic)
0-100 km/h: 5.1 seconds (Coupe Automatic)
Maximum Speed: 186 mph (300 km/h)
DBS
Aston Martin DBS Specification
Body
* Two-door coupe body style with 2+0 seating
* Bonded aluminium VH structure
* Aluminium, magnesium alloy and carbon-fibre composite body
* Extruded aluminium door side-impact beams
* High Intensity Discharge (HID) headlamps (main beam)
* LED rear lamps and side repeaters
Engine
* All-alloy, quad overhead camshaft, 48-valve, 5935cc V12.
* Compression ratio 10.9:1
* Front-mid mounted engine, rear-wheel drive
* Fully catalysed stainless steel exhaust system with active bypass valves
* Max power: 380kW (510bhp/517 PS) at 6500rpm
* Max torque: 570Nm (420 lb.ft) at 5750rpm
* Acceleration: 0-100 km/h (0-62mph) in 4.3 seconds
* Max speed: 302 km/h (191mph)
Transmission
* Rear-mid mounted, six-speed manual gearbox
* Alloy torque tube with carbon fibre propeller shaft
* Limited-slip differential
* Final-drive ratio 3.71:1
Wheels and Tyres
* Front: 8.5'' x 20'' Pirelli P Zero 245/35
* Rear: 11'' x 20'' Pirelli P Zero 295/30
Steering
* Rack and pinion, Servotronic speed-sensitive power-assisted steering, 3.0 turns lock-to-lock. Column tilt and reach adjustment
Suspension
* Front: Independent double wishbone incorporating anti-dive geometry, coil springs, anti-roll bare and monotube adaptive dampers
* Rear: Independent double wishbones with anti-squat and anti-lift geometry, coil springs, anti-roll bar and monotube adaptive dampers
* Adaptive Damping System (ADS) with Track mode
Brakes
* Front: Ventilated carbon ceramic discs, 398mm diameter with six-piston calipers
* Rear: Ventilated carbon ceramic discs, 360mm diameter with four-piston calipers
* Dynamic Stability Control (DSC) with Track mode
* Anti-lock Braking System (ABS)
* Electronic Brakeforce Distribution (EBD)
* Emergency Brake Assist (EBA)
* Traction control
Dimensions
* Length: 4721mm (185.9'')
* Wheelbase: 2740mm (107.9'')
* Width: 1905mm (75'') (exc. Mirrors) 2060mm (81.1'') (inc. Mirrors)
* Fuel tank capacity: 78 litres (17.2 Imp.galls, 20.5 US galls)
* Height: 1280mm (50.4'') Weight: 1695kg (3737lb)
trước mắt thì 2 em này khác nhau cái dàn ngòai bác ạTrích đoạn: jupiter17vn
Cho em hỏi DB9 và DBS có gì khác nhau ko
DB9
Engine:
Transmission:
Brakes:
Suspension:
Wheels and Tyres:
Turn Circle: 11.5 m
Length: 4710 mm
Width: 1875 mm
Rear Track: 1560 mm
Cd: 0.35 (Coupe)
Urban - 24.9 (11.4)
Acceleration:
DBS
Body
Engine
Transmission
Wheels and Tyres
Steering
Suspension
Brakes
* Traction control
Dimensions
