RE: các bác bik con Fer này ko
thông số kỹ thuật:
related cars 1967 Ferrari 330 P4 / 2002 Ferrari Enzo
engine 65 Degree, Type F140 Aluminum V12
valvetrain DOHC, 4 Valves per Cyl w/Continuously Variable Timing
fuel feed Bosch Motronic ME7 Sequential Electronic InjectionBosch Motronic ME7 Sequential Electronic Injection
displacement 5988 cc / 365.4 cu in
bore 92 mm / 3.62 in
stroke 75.2 mm / 2.96 in
compression 11.2:1
power 492.2 kw / 660 bhp @ 4800 rpm
specific output 110.22 bhp per litre
bhp/weight 550.0 bhp per tonne
torque 657.57 nm / 485 ft lbs @ 5500 rpm
body / frame RWD w/TCS
driven wheels Custom Carbon Fibre Body over Carbon FIbre Tub
wheel type Custom Wheels
front brakes Brembro CCM (Carbon-Ceramic) Discs w/6-Pot Calipers, Power Assist ABS
f brake size 340 mm / 13.4 in
rear brakes Brembro CCM (Carbon-Ceramic) Discs w/4-Pot Calipers, Power Assist ABS
r brake size 340 mm / 13.4 in
f suspension Double Wishbones w/Push-Rod Actuated Coil-Shock Units, Adaptive Dampers, Electronic Shock Absorbers, Anti-Roll bar
r suspension Double Wishbones w/Push-Rod Actuated Coil-Shock Units, Adaptive Dampers, Electronic Shock Absorbers, Anti-Roll bar
weight 1200 kg / 2645 lbs
wheelbase 2650 mm / 104.3 in
front track 1691 mm / 66.6 in
rear track 1707 mm / 67.2 in
length 4630 mm / 182.3 in
width 2042 mm / 80.4 in
height 1126 mm / 44.3 in
transmission 6-Speed Semi-Automatic w/Electrohydraulic Acuation, 215mm Twin-Plate Clutch
gear ratios :1
top speed 362.1 kph / 225 mph
0 - 60 mph 3.55 seconds
drag 0.340 Cd
designers Jason Castriota
120
42
otosaigon.com
Em hẻm thấy SLR đâu hít vậy bác
ý bác ấy là so sánh con Fer với SLR chứ có nói trong hình đâu. hay là bác cố ý spam thế [8D]
139
em nghe nói, cái bác Pininfarina design cho chiếc này đã tử nạn rồi đúng hông mấy bác :)
1.605
477
Trích đoạn: Gallardo0101
chính xác . niềm tiếc thương lớn
