Bác BlueRex đem xe qua bác Kim và làm thử mấy bước sau xem sao nhe.
Tools Required:
Rachet
10mm
Short Extention
Jack
Jack Stands
Wheel Lock
Rag or Paper Towels
1) First start by removing the front wheel for either passenger or driver side depending on which one you start with. Make sure to support your car on jack stands and not just the jack.
2) Next turn the steering wheel
all the way in, opposite the side your working on. For example if your working on the passenger side, turn the wheel all the way towards the drivers side.
3) Locate the abs wheel sensor which is directly mounted onto the knuckle and then remove the two 10mm bolts that hold the abs sensor directly. Then along the line theres another two 10mm bolts, that need to be removed, just follow the abs sensor line to get at them. Three of the four bolts are pictured below.
Here's what I had to deal with.
Driver Side
Tools Required:
Rachet
10mm
Short Extention
Jack
Jack Stands
Wheel Lock
Rag or Paper Towels
Driver Side
