545
132
KNAFG521287201532, thanks cụ nào giúp
Your VIN number was successfully decoded:
[xtable]
{thead}
{tr}
{th}
{/th}
{th} {/th}
{/tr}
{/thead}
{tbody}
{tr}
{td}
VIN:
{/td}
{td}
KNAFG521287201532
{/td}
{/tr}
{tr}
{td}
WMI / VDS / VIS:
{/td}
{td}
KNA / FG5212 / 87201532
{/td}
{/tr}
{tr}
{td}
Manufacturer:
{/td}
{td}
Kia Korea
{/td}
{/tr}
{tr}
{td}
Brand:
{/td}
{td}
Kia
{/td}
{/tr}
{tr}
{td}
Model:
{/td}
{td}
Unknown model
{/td}
{/tr}
{tr}
{td}
Check:
{/td}
{td}
{/td}
{/tr}
{tr}
{td}
Year:
{/td}
{td}
2008
{/td}
{/tr}
{tr}
{td}
Sequential number:
{/td}
{td}
01532
{/td}
{/tr}
{/tbody}
[/xtable]
[xtable]
{thead}
{tr}
{th} Extra information on the vehicle:{/th}
{th} {/th}
{/tr}
{/thead}
{tbody}
{tr}
{td}Status{/td}
{td}Not found{/td}
{/tr}
{/tbody}
[/xtable]
CARENS 06
2008/03/27
KNAFG521287201532
WAGON - 5DR 7P > 2000 CC - THETA > DOHC - MPI > GASOLINE - UNLEADED > MANUAL T/M - 5 SPEED 2WD
K\@
[xtable]
{tbody}
{tr}
{td}A26A{/td}
{td}BKW7L2615{/td}
{/tr}
{tr}
{td} {/td}
{td}20080327{/td}
{/tr}
{tr}
{td}S2843A2{/td}
{td}EVAP. GAS CONTROL - EURO-3{/td}
{/tr}
{tr}
{td}S2911A2{/td}
{td}UNDER COVER - W/O NOISE PAD{/td}
{/tr}
{tr}
{td}S2921A2{/td}
{td}ENGINE COVER - SEMI{/td}
{/tr}
{tr}
{td}S3111B5{/td}
{td}FUEL TANK-CAPACITY - 55 LITER{/td}
{/tr}
{tr}
{td}S371CA1{/td}
{td}BATTERY SAVER{/td}
{/tr}
{tr}
{td}S371DA1{/td}
{td}BATTERY COVER{/td}
{/tr}
{tr}
{td}S3711A8{/td}
{td}BATTERY CAPACITY - 60AH (20HR){/td}
{/tr}
{tr}
{td}S529AB5{/td}
{td}TIRE PRESSURE LABEL - GENERAL{/td}
{/tr}
{tr}
{td}S529TA6{/td}
{td}TOOL SET & JACK LABEL - GENERAL{/td}
{/tr}
{tr}
{td}S5296A1{/td}
{td}HUB CAP - A TYPE{/td}
{/tr}
{tr}
{td}S5297C1{/td}
{td}TEMPORARY - STEEL WHEEL & TIRE{/td}
{/tr}
{tr}
{td}S5411A1{/td}
{td}FR SUSP TYPE - MACPH. W/COIL SPRING{/td}
{/tr}
{tr}
{td}S5412A2{/td}
{td}S/ABSORBER TYPE - CONVENTIONAL VALVE{/td}
{/tr}
{tr}
{td}S5511B1{/td}
{td}RR SUSP TYPE - MULTI LINK-NORMAL{/td}
{/tr}
{tr}
{td}S5512A2{/td}
{/tr}
{tr}
{td}S5631A3{/td}
{td}STEER'G COLUMN-MANUAL LWR TILT{/td}
{/tr}
{tr}
{td}S5711A2{/td}
{td}HPS(HYDRAULIC POWER STRG){/td}
{/tr}
{tr}
{td}S5811A4{/td}
{td}FR BRAKE - DISC-15 INCH{/td}
{/tr}
{tr}
{td}S5812A8{/td}
{td}RR BRAKE - DISC-15 INCH{/td}
{/tr}
{tr}
{td}S5911B1{/td}
{td}TANDEM BOOSTER - 8+9 INCH{/td}
{/tr}
{tr}
{td}S5971A2{/td}
{td}PARKG BRK CONTROL - FOOT TYPE{/td}
{/tr}
{tr}
{td}S6501A1{/td}
{td}HIGH GRADE{/td}
{/tr}
{tr}
{td}S8131A2{/td}
{td}CENTRAL DR LOCK/UNLOCK-DR'S & PA'S CTRL{/td}
{/tr}
{tr}
{td}S8136A1{/td}
{td}CHILD SAFETY RR DR LOCK'G{/td}
{/tr}
{tr}
{td}S8152A4{/td}
{td}FUEL FILLER DR REL TYPE - ELECTRIC{/td}
{/tr}
{tr}
{td}S817AB3{/td}
{td}TAIL GATE FINISH'G-FORMED TYPE(PLASTIC){/td}
{/tr}
{tr}
{td}S817BA1{/td}
{td}WINDOW TRIM{/td}
{/tr}
{tr}
{td}S8177A1{/td}
{td}CENTRAL T/GATE LOCK/UNLOCK{/td}
{/tr}
{tr}
{td}S8195A1{/td}
{td}IGNITION ILLUMINATED - BULB TYPE{/td}
{/tr}
{tr}
{td}S8221A1{/td}
{td}DR FRAME MLDG - BLACK{/td}
{/tr}
{tr}
{td}S8231B1{/td}
{td}FORMED TYPE - STD{/td}
{/tr}
{tr}
{td}S8233C1{/td}
{td}CENTER TRIM - PVC{/td}
{/tr}
{tr}
{td}S8235A1{/td}
{td}MAP POCKET FINISH'G - W/O T/C PILE{/td}
{/tr}
{tr}
{td}S8236A1{/td}
{td}ARM REST COVER'G - PVC{/td}
{/tr}
{tr}
{td}S8241A2{/td}
{td}FR DR GLASS - TINTED{/td}
{/tr}
{tr}
{td}S8245A2{/td}
{td}RR DR GLASS - TINTED{/td}
{/tr}
{tr}
{td}S8262A3{/td}
{td}LEVER FINISH'G - METAL PAINT{/td}
{/tr}
{tr}
{td}S834DA1{/td}
{td}AUTO DOWN - DRIVER SIDE{/td}
{/tr}
{tr}
{td}S8341A2{/td}
{td}POWER WINDOW(FR+RR){/td}
{/tr}
{tr}
{td}S8347A1{/td}
{td}SW ILLUMINATION(DR){/td}
{/tr}
{tr}
{td}S8421D2{/td}
{td}N/PUNCH - VELOUR TYPE{/td}
{/tr}
{tr}
{td}S8443A1{/td}
{td}TRAY{/td}
{/tr}
{tr}
{td}S8445A2{/td}
{td}CIGAR LIGHTER - W/ ILLUM{/td}
{/tr}
{tr}
{td}S8451A1{/td}
{td}W/O LOCK{/td}
{/tr}
{tr}
{td}S8452A2{/td}
{td}W/ DAMPER{/td}
{/tr}
{tr}
{td}S8461B1{/td}
{td}DLX - PVC{/td}
{/tr}
{tr}
{td}S8481A6{/td}
{td}GRAIN - METAL PAINT{/td}
{/tr}
{tr}
{td}S85AAA1{/td}
{td}HOOK{/td}
{/tr}
{tr}
{td}S8511B1{/td}
{td}DAY/NIGHT TYPE{/td}
{/tr}
{tr}
{td}S852AA1{/td}
{td}TICKET HOLDER{/td}
{/tr}
{tr}
{td}S852DA1{/td}
{td}ILLUMINATED{/td}
{/tr}
{tr}
{td}S852EA2{/td}
{td}SUNVISOR TYPE - SLIDING TYPE{/td}
{/tr}
{tr}
{td}S852GA1{/td}
{td}VANITY MIRROR - GLASS TYPE{/td}
{/tr}
{tr}
{td}S852KA1{/td}
{/tr}
{tr}
{td}S852LA2{/td}
{/tr}
{tr}
{td}S8521A1{/td}
{td}MATERIAL - VINYL{/td}
{/tr}
{tr}
{td}S8522A1{/td}
{/tr}
{tr}
{td}S8523A1{/td}
{/tr}
{tr}
{td}S853AA2{/td}
{td}RR - 2 EA{/td}
{/tr}
{tr}
{td}S853JA1{/td}
{td}RR - 1 EA{/td}
{/tr}
{tr}
{td}S8531A2{/td}
{td}ROOF TRIM MATERIAL - FABRIC{/td}
{/tr}
{tr}
{td}S8532A1{/td}
{td}FR - 1 EA{/td}
{/tr}
{tr}
{td}S857GA1{/td}
{td}LUGGAGE SIDE RH{/td}
{/tr}
{tr}
{td}S857HA1{/td}
{td}LUGGAGE UNDER FLOOR BOX{/td}
{/tr}
{tr}
{td}S8571B1{/td}
{td}LUGGAGE SIDE - PLASTIC{/td}
{/tr}
{tr}
{td}S8573A3{/td}
{td}FLOOR - N/PUNCH{/td}
{/tr}
{tr}
{td}S8578A1{/td}
{td}LUGGAGE NET HOOK{/td}
{/tr}
{tr}
{td}S858RA1{/td}
{td}DR SCUFF - STD{/td}
{/tr}
{tr}
{td}S8611B2{/td}
{td}W/S GLASS TYPE-TINTED (W/ S/BAND){/td}
{/tr}
{tr}
{td}S8612A1{/td}
{td}MLD'G-WINDSHIELD - BLACK{/td}
{/tr}
{tr}
{td}S863CA2{/td}
{td}GRADE - GLS{/td}
{/tr}
{tr}
{td}S8641A1{/td}
{td}TOWING HOOK{/td}
{/tr}
{tr}
{td}S8642A1{/td}
{td}TIE DOWN HOOK(LASHING){/td}
{/tr}
{tr}
{td}S8648A1{/td}
{td}ANTI-CORROSION TREATMENT{/td}
{/tr}
{tr}
{td}S8649B6{/td}
{td}ID PLATE - GEN+MES TYPE(ID){/td}
{/tr}
{tr}
{td}S8651B1{/td}
{td}TYPE - 2.5 MILE{/td}
{/tr}
{tr}
{td}S8652B1{/td}
{td}COLOR - BODY COLOR{/td}
{/tr}
{tr}
{td}S871BA1{/td}
{td}RR HEATED W/ TIMER{/td}
{/tr}
{tr}
{td}S8711A1{/td}
{td}MLD'G-BACK LITE - BLACK{/td}
{/tr}
{tr}
{td}S8712B4{/td}
{td}BACK LITE GLASS TYPE -TINTED(W/ HEATED){/td}
{/tr}
{tr}
{td}S8722A4{/td}
{td}H.M.S.L - T/GATE OTR{/td}
{/tr}
{tr}
{td}S8731B1{/td}
{td}MLD'G - BODY COLOR{/td}
{/tr}
{tr}
{td}S8762C4{/td}
{td}PASS'S SIDE - ELECTRIC HTD-CONV{/td}
{/tr}
{tr}
{td}S8763C4{/td}
{td}DRIVER'S SIDE - ELECTRIC HTD-CONV{/td}
{/tr}
{tr}
{td}S8765A2{/td}
{/tr}
{tr}
{td}S8791B1{/td}
{td}RR QTR GLASS TYPE -TINTED{/td}
{/tr}
{tr}
{td}S8801A1{/td}
{td}FR FLAT TYPE - FR FULL FLAT{/td}
{/tr}
{tr}
{td}S8802A1{/td}
{td}RR FLAT - RR FULL FLAT{/td}
{/tr}
{tr}
{td}S8811C1{/td}
{td}CLOTH - CLOTH{/td}
{/tr}
{tr}
{td}S8821A3{/td}
{td}HEAD REST - UP/DOWN & TILT{/td}
{/tr}
{tr}
{td}S8823A1{/td}
{td}SLIDING{/td}
{/tr}
{tr}
{td}S8824A2{/td}
{td}DOUBLE RECLIN'G{/td}
{/tr}
{tr}
{td}S8825A3{/td}
{td}ADJUSTER - DUAL HEIGHT ADJUSTER{/td}
{/tr}
{tr}
{td}S8828A1{/td}
{td}LUMBAR SUPPORT - MANUAL{/td}
{/tr}
{tr}
{td}S8836A1{/td}
{td}SEAT BACK POCKET{/td}
{/tr}
{tr}
{td}S885DA1{/td}
{td}SLIDING{/td}
{/tr}
{tr}
{td}S885EA2{/td}
{/tr}
{tr}
{td}S8854A3{/td}
{/tr}
{tr}
{td}S8858A1{/td}
{td}RR BAG HOOK{/td}
{/tr}
{tr}
{td}S886BA1{/td}
{td}SEAT BACK - SEAT BACK POCKET{/td}
{/tr}
{tr}
{td}S8868A1{/td}
{td}SEAT UNDER TRAY{/td}
{/tr}
{tr}
{td}S888KA2{/td}
{td}S/BELT ANCHOR - ADJUSTABLE{/td}
{/tr}
{tr}
{td}S888RA2{/td}
{/tr}
{tr}
{td}S8881B1{/td}
{td}DRIVER'S SIDE - ELR{/td}
{/tr}
{tr}
{td}S8884D1{/td}
{td}PASSENGER'S SIDE - ELR{/td}
{/tr}
{tr}
{td}S89B1A1{/td}
{td}W/O BOX{/td}
{/tr}
{tr}
{td}S8912D4{/td}
{td}6:4 SPLIT BACK FOLD'G - CUSHION+BACK{/td}
{/tr}
{tr}
{td}S8913A1{/td}
{td}LH{/td}
{/tr}
{tr}
{td}S8914A1{/td}
{td}RH{/td}
{/tr}
{tr}
{td}S8915A1{/td}
{td}CTR{/td}
{/tr}
{tr}
{td}S892HA1{/td}
{td}SEPARATE{/td}
{/tr}
{tr}
{td}S892QA1{/td}
{td}WALK IN DEVICE{/td}
{/tr}
{tr}
{td}S892VA1{/td}
{td}RR LUGGAGE FULL FLAT{/td}
{/tr}
{tr}
{td}S8922A2{/td}
{/tr}
{tr}
{td}S893LA1{/td}
{td}DIVE{/td}
{/tr}
{tr}
{td}S8931B2{/td}
{td}FOR 2 PEOPLE - 5:5 SPLIT FOLD'G DOWN{/td}
{/tr}
{tr}
{td}S8934C3{/td}
{td}HEAD REST - UP/DOWN(LH/RH){/td}
{/tr}
{tr}
{td}S8981A4{/td}
{td}SIDE - ELR{/td}
{/tr}
{tr}
{td}S8982A1{/td}
{td}CTR - STATIC{/td}
{/tr}
{tr}
{td}S9211D1{/td}
{td}PROJECTION - HIGH BEAM{/td}
{/tr}
{tr}
{td}S9221A2{/td}
{td}CONVENTIONAL - CLEAR LENS{/td}
{/tr}
{tr}
{td}S9241A1{/td}
{td}RR COMBI LAMP - CLEAR{/td}
{/tr}
{tr}
{td}S928CA1{/td}
{td}ROOM LAMP-RR(GLOW LAMP){/td}
{/tr}
{tr}
{td}S928FA1{/td}
{td}CTR - GLOW LAMP{/td}
{/tr}
{tr}
{td}S928WA2{/td}
{td}BULB TYPE - 2 BULB{/td}
{/tr}
{tr}
{td}S9282A1{/td}
{td}FR - W/ SUNGLASSES{/td}
{/tr}
{tr}
{td}S94C6A1{/td}
{td}DIRECTION INDICATOR{/td}
{/tr}
{tr}
{td}S94C7A1{/td}
{td}OIL PRESSURE{/td}
{/tr}
{tr}
{td}S94C9A1{/td}
{td}PARK'G BRAKE{/td}
{/tr}
{tr}
{td}S94D0A1{/td}
{td}DR AJAR - DR AJAR{/td}
{/tr}
{tr}
{td}S94D1A1{/td}
{td}BATTERY CHARGE{/td}
{/tr}
{tr}
{td}S94D2A1{/td}
{td}HIGH BEAM{/td}
{/tr}
{tr}
{td}S94D7A1{/td}
{td}TRUNK LID(T/GATE) OPEN{/td}
{/tr}
{tr}
{td}S94D9A1{/td}
{td}CHECK ENGINE{/td}
{/tr}
{tr}
{td}S94E3A1{/td}
{td}SEAT BELT{/td}
{/tr}
{tr}
{td}S94F9A1{/td}
{td}FUEL EMPTY WARN'G LAMP{/td}
{/tr}
{tr}
{td}S94G4A1{/td}
{td}FR FOG LAMP{/td}
{/tr}
{tr}
{td}S94M0A1{/td}
{td}SPEEDOMETER TYPE - KMPH{/td}
{/tr}
{tr}
{td}S94N0A1{/td}
{td}TEMPERATURE UNIT - C{/td}
{/tr}
{tr}
{td}S940AA3{/td}
{td}TRIP ODOMETER - LCD{/td}
{/tr}
{tr}
{td}S940BA1{/td}
{td}TACHOMETER{/td}
{/tr}
{tr}
{td}S940CA1{/td}
{td}FUEL{/td}
{/tr}
{tr}
{td}S940DA1{/td}
{td}WATER TEMP.{/td}
{/tr}
{tr}
{td}S9402A1{/td}
{td}SPEEDOMETER{/td}
{/tr}
{tr}
{td}S9451A1{/td}
{td}TYPE - DIGITAL{/td}
{/tr}
{tr}
{td}S9541A1{/td}
{td}BODY CONTROL MODULE - BCM(ETACS){/td}
{/tr}
{tr}
{td}S9545A1{/td}
{td}FREQUENCY-SMART KEY - DOMESTIC{/td}
{/tr}
{tr}
{td}S9615A1{/td}
{td}FREQUENCY VIBRATION - AM9K/FM100K{/td}
{/tr}
{tr}
{td}S9741A2{/td}
{td}RR HEATING DUCTS - 2ND & 3RD SEAT{/td}
{/tr}
{tr}
{td}S9811A2{/td}
{td}FR WIPER - INTERMITTENT(VARIABLE){/td}
{/tr}
{tr}
{td}S9872A1{/td}
{td}RR WIPER SYSTEM - 1 SPEED{/td}
{/tr}
{tr}
{td}S4371A3{/td}
{td}MT KNOB - LEATHER WRAPPED{/td}
{/tr}
{tr}
{td}5291MA{/td}
{td}AL WHEEL 6.5J * 16 - A TYPE{/td}
{/tr}
{tr}
{td}5293FB{/td}
{td}205 TIRE - 205/60 HR16{/td}
{/tr}
{tr}
{td}5294B1{/td}
{td}TIRE SOURCE - MICHELIN{/td}
{/tr}
{tr}
{td}5611C3{/td}
{td}4-SPOKE - LEATHER{/td}
{/tr}
{tr}
{td}5691A3{/td}
{td}DRIVER SIDE - DEPOWERED{/td}
{/tr}
{tr}
{td}5891A2{/td}
{td}ABS (ANTI LOCK BRK SYS){/td}
{/tr}
{tr}
{td}813BA1{/td}
{td}IMPACT SENS'G AUTO DR UNLOCKG{/td}
{/tr}
{tr}
{td}8161C4{/td}
{td}POWER-TOUCH SAFETY{/td}
{/tr}
{tr}
{td}819AA1{/td}
{td}KEYLESS ENTRY-B/ALARM{/td}
{/tr}
{tr}
{td}819CA1{/td}
{td}KEYLESS ENTRY-T/OPEN{/td}
{/tr}
{tr}
{td}8261A4{/td}
{td}FINISH'G - CR COAT'G{/td}
{/tr}
{tr}
{td}8631B3{/td}
{td}B TYPE - CR COAT'G{/td}
{/tr}
{tr}
{td}8672A2{/td}
{td}ROOF RACK - W/ CROSS BAR{/td}
{/tr}
{tr}
{td}8681A1{/td}
{td}MUD GUARD-FR{/td}
{/tr}
{tr}
{td}8682A1{/td}
{td}MUD GUARD-RR{/td}
{/tr}
{tr}
{td}876MA1{/td}
{td}ELECTRIC FOLD'G CONTROL{/td}
{/tr}
{tr}
{td}8771G1{/td}
{td}BRIGHT - CR & BODY COLOR{/td}
{/tr}
{tr}
{td}888AA2{/td}
{td}PRE TENSIONER - ELECTRICAL TYPE{/td}
{/tr}
{tr}
{td}8885A2{/td}
{td}RETRACTOR PRETENSIONER - ELECTRICAL TYPE{/td}
{/tr}
{tr}
{td}9297A1{/td}
{td}W/ MAP LAMP{/td}
{/tr}
{tr}
{td}9298A1{/td}
{td}W/ SUNGLASS BOX{/td}
{/tr}
{tr}
{td}9299A1{/td}
{td}W/ SUNROOF SW{/td}
{/tr}
{tr}
{td}94E5A1{/td}
{td}A.B.S{/td}
{/tr}
{tr}
{td}94E6A1{/td}
{td}A/BAG{/td}
{/tr}
{tr}
{td}961AA1{/td}
{td}AUX{/td}
{/tr}
{tr}
{td}9761A3{/td}
{td}FR COOLER - FULL AUTO A/CON{/td}
{/tr}
{/tbody}
[/xtable]
Của bác day ko biet chính xác không :) ?
Reactions: tuannn
422
1.770
Các bác chạy dòng Kia KOREA cần check số VIN kiểm tra option nguyên bản em nó thì vào đây, cho em cái số VIN địa chỉ mail, em sẽ check giúp.
Số VIN xe em KNAMB752276000243 , kia carnival 2007 . Bác check giùm em nhé.''
Thanks!
