143
61
1080p vẫn chơi được tuy nhiên DTS Audio thì chịu thua. Bitrate cao vẫn chơi vô tư mà các bác, em đã test thử file này thì chạy ok, nhưng phải chuyển từ DTS sang AC3 để có tiếng.
Mã:
General
Unique ID								: 227876777745256770568502110447473779467 (0xAB6F7892BC4BA3DF8953B2D216CFE30B)
Complete name							: G:\Movies\rio.2.2014.1080p.bluray.x264-sector7-submux.mkv
Format								   : Matroska
Format version						   : Version 4 / Version 2
File size								: 6.55 GiB
Duration								 : 1h 41mn
Overall bit rate						 : 9 270 Kbps
Encoded date							 : UTC 2014-09-09 07:54:42
Writing application					  : mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
Writing library						  : libebml v1.3.0 + libmatroska v1.4.1
_STATISTICS_WRITING_APP				  : mkvmerge v7.1.0 ('Good Love') 64bit built on Jul 27 2014 13:06:55
_STATISTICS_WRITING_DATE_UTC			 : 2014-09-09 07:54:42
_STATISTICS_TAGS						 : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
DURATION								 : 01:30:37.823000000
NUMBER_OF_FRAMES						 : 1277
NUMBER_OF_BYTES						  : 54887
Video
Format								   : AVC
Format/Info							  : Advanced Video Codec
Format profile						   : [email protected]
Format settings, CABAC				   : Yes
Format settings, ReFrames				: 5 frames
Codec ID								 : V_MPEG4/ISO/AVC
Duration								 : 1h 41mn
Bit rate								 : 7 760 Kbps
Width									: 1 920 pixels
Height								   : 800 pixels
Display aspect ratio					 : 2.40:1
Frame rate mode						  : Constant
Frame rate							   : 23.976 fps
Color space							  : YUV
Chroma subsampling					   : 4:2:0
Bit depth								: 8 bits
Scan type								: Progressive
Bits/(Pixel*Frame)					   : 0.211
Stream size							  : 5.35 GiB (82%)
Writing library						  : x264 core 142 r2431 ac76440
Encoding settings						: cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=7760 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language								 : English
Default								  : Yes
Forced								   : No
DURATION								 : 01:41:11.190000000
NUMBER_OF_FRAMES						 : 145563
NUMBER_OF_BYTES						  : 5887516708
Audio
Format								   : DTS
Format/Info							  : Digital Theater Systems
Format profile						   : ES
Mode									 : 16
Format settings, Endianness			  : Big
Codec ID								 : A_DTS
Duration								 : 1h 41mn
Bit rate mode							: Constant
Bit rate								 : 1 509 Kbps
Channel(s)							   : 6 channels
Channel positions						: Front: L C R, Side: L R, LFE
Sampling rate							: 48.0 KHz
Bit depth								: 24 bits
Compression mode						 : Lossy
Stream size							  : 1.07 GiB (16%)
Title									: English
Language								 : English
Default								  : Yes
Forced								   : No
143
61
Đang ngóng firmware khắc phục được các điểm yếu này thì tuyệt.
14
Biên Hòa
E có bộ DVD cũ AVH-X5550BT và Cap Pioneer CD-IU201. Bác nào cần e để lại giá rẻ. Hàng còn bảo hành nhé!
Bac oi co gan vua kia morning 2014 hay inova 2014 ko bac co gi alo dum e số dt 0949667398 hoặc cho em so dt cua bác nha.
son la
(AUDIO xây dựng trong Amplifier: MOSFET 50W x 4 Advanced Sound Retriever: Equalizer : 12-Band Graphic EQ)
Bác ơi em định thay con này cho kia foter bác cho em hỏi ló kéo dược 4 loa * 50W + 1 sup Pioneer 500A . có bác tư vấn cho em là kéo được nhưng em dang hoài nghi lệu có không cần amply không nhỉ nếu được thì đỡ đấu dây lòng ngoàng em cảm ơn bác trước.
