Hỏi/Đáp Kỹ Thuật Đèn check engine sáng hòai ???
82
RE: Đèn check engine sáng hòai ???
Bác Dodge thử làm theo hướng dẩn này xem sao ? Chysler ,Plymouth, Dodge dùng chung .
The 1980s-1990s Chrysler Computer CodesClick here for details on how to get the codes, what they might mean, and for newer codes.
Start with the ignition off. Within five seconds, switch the key on, off, on, off, on. (On is *not* start!)
The "check engine" light will flash. Count the flashes Each code is a two digit code, so a (for example) 23 would be FLASH FLASH (pause) FLASH FLASH FLASH (loong pause)
It will never flash more than 9 times, watch for pauses!
55 is end of codes - it's normal. Before you call your dealer or mechanic, consider that the blink-spacing is not always perfectly uniform, so if you see 23 23, it's probably just a single 55. (Codes are not repeated.)
33 is normal on earlier models if you don't have air conditioning.
John McGuire wrote: "The older Vipers will blink out diag codes with four off/on key turns. They removed the capability starting in... I think 2000, at any rate I know my 2001 requires a computer to check the codes."
On some models (such as a 1995 Neon), when the check engine light goes on, you may be able to get the codes simply by putting in the key and moving it to the RUN position; the light will blink out the codes by itself.
Please note that some codes are NOT included below, this is not a complete listing, but it IS very close to complete. It stemps from a list posted on the Mopar Mailing List, but many modifications have been made.
* Activates Power Limited/Check Engine light on some models.
IMPORTANT. Codes may be different for newer vehicles starting in the late 1990s. See the earlier section.
11 No ignition reference signal detected during cranking (bad Hall effect) OR timing belt skipped one or more teeth; OR loss of either camshaft or crankshaft position sensor. Can cause the engine to stop working entirely with no limp-home mode.
12 Battery or computer recently disconnected
13* MAP sensor or vacuum line may not be working
14* MAP sensor voltage below .16V or over 4.96V
15 No speed/distance sensor signal
16* Loss of battery voltage detected with engine running
17 Engine stays cool too long (bad thermostat or coolant sensor?)
17 (1985 turbo only): knock sensor circuit
21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor
22* Coolant sensor signal out of range - May have been disconnected to set timing
23* Incoming air temperature sensor may be bad
24* Throttle position sensor over 4.96V (SEE NOTE #3)
25 Automatic Idle Speed (AIS) motor driver circuit shorted or target idle not reached, vacuum leak found
26 Peak injector circuit voltage has not been reached (need to check computer signals, voltage reg, injectors) (SEE NOTE #4 BELOW)
27 Injector circuit isn't switching when it's told to (TBI)
OR (MPI) injector circuit #1 not switching right
OR (turbo) injector circuit #2 not switching right
OR (all 1990-) injector output driver not responding
- check computer, connections
31 Bad evaporator purge solenoid circuit or driver
32 (1984 only) power loss/limited lamp or circuit
32 EGR gases not working (1988) - check vacuum, valve
32 (1990-92, all but Turbo) computer didn't see change in air/'fuel ratio when EGR activated - check valve, vacuum lines, and EGR electrical
33 Air conditioning clutch relay circuit open or shorted (may be in the wide-open-throttle cutoff circuit)
34 (1984-86) EGR solenoid circuit shorted or open
34 (1987-1991) speed control shorted or open
35 Cooling fan relay circuit open or shorted
35 (trucks) idle switch motor fault - check connections
36 (turbo) Wastegate control circuit open or shorted
36 (3.9/5.2 RWD) solenoid coil circuit (air switching)
36 (Turbo IV) #3 Vent Solenoid open/short
37 Shift indicator light failure, 5-speed
OR
part throttle lock/unlock solenoid driver circuit (87-89)
OR
solenoid coil circuit (85-89 Turbo I-IV)
OR
Trans temperature sensor voltage low (1995 and on; see NOTE 2)
41* Alternator field control circuit open or shorted
42 Automatic shutdown relay circuit open or shorted
42 Fuel pump relay control circuit
42 Fuel level unit - no change over miles
OR
42 Z1 voltage missing when autoshutdown circuit energized (SEE NOTE #6)
43 Peak primary coil current not achieved with max dwell time
OR
43 Cylinder misfire
OR
43 Problem in power module to logic module interface
44 No FJ2 voltage present at logic board
OR
44 Logic module self-diagnostics indicate problem
OR
44 Battery temperature out of range (see Note #1!)
45 Turbo boost limit exceeded (engine was shut down by logic module)
46* Battery voltage too high during charging or charging system voltage too low
47 Battery voltage too low and alternator output too low
51 Oxygen sensor stuck at lean position (Bob Lincoln wrote: may be tripped by a bad MAP sensor system causing a rich condition, and the O2 sensor trying to compensate. The O2 sensor may still be good. The MAP assembly consists of two pieces, the valve and the vacuum transducer (round plastic unit with cylinder on top and both electrical and vacuum connections) - If you get hot rough idle and stalling, especially on deceleration, accompanied by flooded engine and difficulty restarting, that can be a bad MAP sensor causing the O2 sensor to try to compensate. If you get poor cold driveability, stumbling and bucking, and acceptable warm driving with poor gas mileage (a drop of 10 mpg or more), that is usually the O2 sensor. [Webmaster note: MAP sensors seem to die regularly.]
OR
51 Internal logic module fault ('84 turbo only).
52 Oxygen sensor stuck at rich position (SEE NOTE #5!)
OR
52 Internal logic module fault ('84 turbo only)
53 Logic module internal problem
54 No sync pickup signal during engine rotation (turbo only)
OR
54 Internal logic module fault ('84 turbo only) - or camshaft sensor/distributor timing (7)
55 End of codes
61 "Baro" sensor open or shorted
62 EMR mileage cannot be stored in EEPROM
62 PCM failure SRI mile not stored
63 Controller cannot write to EEPROM
64 Catalytic converter efficiency failure
65 Power steering switch failure
88 Start of test (not usually given, don't expect it)
Footnotes
NOTE #1.The power module has an air-cooled resistor which senses incoming air temperature. The logic modules uses this information to control the field current in the alternator. This code applies ONLY to alternators whose voltage is computer regulated. If you lose the feed to keep RAM information stored when the engine's off, you also lose battery voltage sensing. -- Bohdan Bodnar
NOTE #2.From the 1995 TRUCK manuals: the trailer towing package includes a transmission coolant temp sensor while the standard package doesn't. This may cause the low (no) voltage indication. -- J.E. Winburn
NOTE #3.Matt Rowe comments: The throttle postion circuit tells the computer how far the accelerator is depressed. The Throttle Position Sensor (TPS) is on the throttle body on the opposite side of the throttle cable. The connector should have a round rubber cover over the connections. Clear the fault codes, start the car and try jiggling the wires/connectors to try to trip a fault code. Loss of this signal could cause other problems.
NOTE #4.During cranking, the computer will test the current through the injector to see whether there's too much resistance in the injector's path. If there is, code 26 is set.
The problem may be cured with tuner cleaner on the connectors.
For TBI engines, the injector's cold resistance should be between 0.9 and 1.2 ohms (specs vary with year). This is a peak-and-hold injector. With the engine idling the peak period should be about 1.2 milliseconds whereas the hold period will vary. If it's lower than this at idle, then the injector's shorted or there's a defect in the injector driver circuit. (Bohdan Bodnar)
NOTE #5.Wade Goldman wrote: In my case, the breather tube leading into the catalytic converter had rusted and become detached. This some how would cause the sensor to read an over rich condition and run crummy. I did not trust the reliability of the weld over a corroded surface and opted for the more expensive route of replacing the converter, breather tube and all.
NOTE #6.The Z1 voltage is the voltage of the circuits fed by the autoshutdown relay. This typically includes fuel pump and switched-battery feed to the ignition coil(s). In my Le Baron, the Z1 circuit leaves the power module and splits into two paths: the fuel pump and the positive side of the ignition coil. Internal to the power module is the auto shutdown relay (in my case, it's a sealed box about 1" by 1"). The output voltage is monitored to determine whether the relay responds correctly. I suspect that the ASD relay (and, therefore, the Z1 circuit) also feeds the fuel injector(s) driver(s) and current sensing circuit, but can't prove this.
I've used the Z1 voltage to test for good power connections to the power module. I connected my OTC 500 multimeter from the battery's positive post to the ignition coil's switched battery terminal and measured the voltage drop using the bar graph to monitor peak voltages. Voltage spikes of around 200 mV to 300 mV are ok -- anything more means tv tuner cleaner time (or replacing the power module). Another thing to check is the maximum voltage drop during the priming pulse. With the old power module, I was losing about 2 volts across the circuit; the replacement is losing about 1/4 volt. (Thanks, [email protected])
Note #7Steve Knickerbocker wrote: Inside your distributor you have two pickups, one is for the ignition and one is to tell the computer where number one cylinder is in its rotation. If you look at the four slotted tangs inside there you will see one has a bigger slot, that's the one that tells the sync pickup what's number one. In other words, the pickup inside the distributor is bad.
Home - Cars - Engines - History - Resources - Repairs - Reviews - Other Brands - Books - News - Search
Corrections or additions? Click here!
Please read the terms of use. Mopar, Dodge, Jeep, Plymouth, and Chrysler are trademarks of DaimlerChrysler, AG. We are not affiliated with DaimlerChrysler. We are not responsible for the consequences of actions taken based on this site and make no guarantees regarding validity or applicability of information, opinions, or advice. The Webmaster is not an expert. Copyright © 1999-2000, David Zatz; copyright © 2001-2005, Allpar LLC. All rights reserved. Recommend this page!
1.543
20
Biên Hòa
Bác cạc te pót thế thì chóang thật nhẩy,bác Đò ơi theo em thì giải pháp tình thế là:trong khi bác sợt net và kiếm cách thì bác mua thỏi chewingum đúp bơ min bác nhai tí rồi vo tròn và dán lên cai mặt đồng hồ chỗ cái đèn đỏ đỏ đó em bảo đảm nó hết sáng liền hà,bác nhớ mua đúp bơ min lọai mới nha dích chắc cú lắm đó .:D
Bác sĩ
20/4/04
3.488
325
Sai gon,Vietnam
Cảm ơn bác Tecate đã cất công sưu tầm và Post bảng Flash Code rất giá trị lên. :D
922
26
Vietnam
. sau khi vệ sinh lọc gió, xịt cabcleaner v..v. thì nó hết nhưng chạy khỏang vài km thì nó lại sáng . có cảm tưởng như máy nóng thì nó bị như vậy đồng thời garangti tuột xuống khỏang 400 à nhưng không tắt máy .
>>>>> chắc cái AIR MASS SENSOR:D
bác thử bật tắt khóa điện 5 lần xem đèn CheCk nó có báo lối không?Em thử xe em (1998) nó không thèm báo:mad:
33
Hanoi
Đèn check engine ságn có nhiều lỗi lắm, tuy nhiên cũng có thể lỗi đơn giản như bẩn lọc dầu máy (trước xe của cty em cũng bị đi kiểm tra một hồi gara nó thay lọc dầu thì lại hết). Hay bác cũng thử như vậy xem, vì đằng nào thi cũng phải thay lọc dầu sau một tg, có thay trước chút cũng ko sao mà.
591
913
Biên Hòa - Vietnam
Báo cáo các bác là thay dầu, lọc,kim phun, vệ sinh lọc gió v..v. vẫn không hết . sau khi check code bằng cách on off ba lần chứ không phải 5 lần nhé bác GAZ69 và tra trên bảng của bác treo xe trên cây thì được như sau :
Check code : 12, 21, 13, 21,55 . Tóm lại là có ba lỗi 12,21 và 13
Xử lý :
- 21: 21 Oxygen sensor signal doesn't change (stays at 4.3-4.5V). Probably bad oxygen sensor : lỗi này đã đóan trứoc đã tháo ra xịt rửa nhưng không ăn thua ---> cảm biến đã hư :(.
- 13: 13* MAP sensor or vacuum line may not be working : Có dấu * có thể xe mình không thuộc đời này với lại tìm không thấy cái này nó nằm chỗ nào . bác nào biết chỉ tui với
- 12: 12 Battery or computer recently disconnected: Không hiểu nhưng cố hiểu , bát te ri thì chắc chắn không đít còn nét nên chỉ còn cái com pìu tơ. Mà trên xe mình làm quái gì có compìu tơ nhể. Suy luận: nếu là compìu tơ thì mọi thứ dây điện phải chụm về đó, sau một hồi nhìn ngó , móc, kéo .v..v dưới nắp capô thì thấy có cái cục này
Nó nằm ngay đầu cổ lấy gió , air qua cổ hút qua nó qua đường ống dẫn rồi mới tới lọc gió .
Hình dạng nó như sau
SAu khi tháo ra thì thấy nó là một bo mạch đã đổ keo silicon lên thành một khối chỉ lòi ra mấy cái này .
Vệ sinh sạch sẽ, gắn lại vào vị trí cũ , cắm đầu jack cẩn thận , siết thật kỹ .
Nổ máy lên và hồi hộp chờ đợi nào .......... và cái đèn check engine vẫn sáng :D
VẬy rút ra là bị hư hai cái
1: oxygen sensor .
2: cái của nợ này
Thấy trên ADV có mấy chỗ nó để bảng sửa ECU không biết có phải là sửa cái nài hông ta [8|]
HAi cái trên mà mua ở VN thì bó tay hihi BÁc GAZ̉68 ới ời - BÁc check giùm tui đi bác - CẢm ơn bác nhiều nhiều :)
Bác Đò giỏi ve...!
Thế mấy hôm nay xe chạy có biểu hiện gì khác không bác? Hao xăng hơn? Máy lì? Đề khó nổ ? ...
Em đọc trong cái manual xe em thì nó bảo là khi đèn engine sáng, xe vẫn chạy được, nhưng không vọt và hao xăng...Nếu xe bác cũng có tình trạng trên thì bác có thể đến Mitsu mua đồ thay vào....
À, có khi nào nguyên nhân là hỏng cái của nợ số 2 là do quả đèn bô inh không? [8|]
922
26
Vietnam
chúc mừng và chia buồn với bác Đò :mừng vì xe bác có flash code,vậy bác hẳn sẽ được giúp đỡ rất nhìu trong sửa chữa bây giờ và sau này.Buồn vì bác đi cái MAPSENSOR ..vì theo em biết thì cảm biên õygen bị hỏng không làm sáng đèn check được.Mà nói thiệt ra thì em nghĩ 9/10 cái oxygen sensor ở nước ta nó hỏng hết:DRất buồn là em không coi được hình của bác post nhưng em cũng quả quyết suy đoán lí do sáng đèn check là do MAP sennsor-cái đó thực ra gồm 2 cái:lưu lượng và nhiệt độ khí nạp.Ở đây bác tự phân tích xem bộ phận nào hỏng nhá:nếu phần đo nhiệt độ thì sáng ra vòng tua máy sẽ thấp(400v/ph)sau đó máy nóng sẽ chạy bình thường.Còn nếu phần lưu lượng thì xe chạy rất kém
Còn cái code code 12(battery)thì bác đừng để ý làm gì mất công,em đọc flash code 2 xe rùi đều có nó
Còn về hoạt động của ECU xe bác thì sau khi bác lắp dây nhợ vào nó không tắt đèn check ngay đâu,nếu mọi việc okie thì sau vài KM chạy xe nó mới tắt.Bác thử reser lại bằng cách tháo cọc ắcqui xem sao:D
mà hình như cái hình đầu tiên em xem được không phải MAP bác Đò ui,hình như nó là cái Vị trí chân ga,cái kia thực ra chỉ là sợi dây điện thò ra thui[:Dhay bác gửi mấy cái hình cho em qua mail hay link vào yahoo mes : bonmos2003
