Bác haiphush
VIN KMHEC41BBAA031754
Model No :
GFS4L561F
Car Name :
???(SONATA YF) 10MY / KOREA,SOUTH
Engine No :
G4KD9A22613 P/Date :
2009/11/05
Body Color :
FHM FHM Interior Color :
RY
Body: SEDAN-4DR(5) Engine Capacity: 2.0L-THETA2 Engine: DOHC-MPI Fuel: GASOLINE-UNLEADED T/M: 6AT 2WD Drive Type: LHDGASOLINE-UNLEADED
Full Option View Option Code
Description
INTAKE TYPE - VARIABLE INTAKE SYSTEM
EMISSION REGULATION - DOM 2006 EVAP. GAS CONTROL - EURO-3 O.B.D(ON-BOARD DIAGNOSTICS) - K.O.B.D MUFFLER MAIN ASSY - SINGLE-BLACK PAINT MUFFLER MATERIAL - SUS SEMI ACTIVE MUFFLER ENGINE COVER - FULL FUEL TANK-CAPACITY - 70 LITER FLOOR MTG TYPE BATTERY UPR COVER BATTERY SAVER BATTERY CAPACITY - 48AH (5HR) AMS - W/ MICOM AT KNOB - LEATHER WRAPPED SHIFT LOCK SYSTEM - ELECTRONIC TYPE GATE TYPE H-MATIC LH/RH - BJ95+TJ95 TIRE PRESSURE LABEL - KOREA TOOL SET & JACK LABEL - GENERAL TIRE MATERIAL - SILICA TEMPORARY - STEEL WHEEL & TIRE FR SUSP TYPE - MACPH. W/COIL SPRING RR SUSP TYPE - MULTI LINK-SPORTY 4-SPOKE - LEATHER STEER`G COLUMN-MANUAL LWR TILT PASS`S - KOREAN LANGUAGE DRIVER SIDE - DEPOWERED PASSENGER SIDE - DEPOWERED HPS(HYDRAULIC POWER STRG) FR BRAKE - DISC-15 INCH RR BRAKE - DISC-14 INCH ABS (ANTI LOCK BRK SYS) SINGLE BOOSTER - 11 INCH PARKG BRK CONTROL - FOOT TYPE CARRIER MATERIAL - PLASTIC(HYBRID) MTG TYPE - BOLTING HIGH GRADE FENDER MATERIAL - STEEL LICENCE PLATE - KOREAN TYPE HOOD INSULATOR HOOD PANEL MATERIAL - STEEL HOOD OPENING DEVICE - GAS LIFT T/LID EMERGENCY RELEASE TRUNK LID PANEL MATERIAL - STEEL TRUNK LID OPENING DIVCE - TORSION BAR TRUNK LID RELEASE TYPE - ELECTRIC TRUNK LID TRIM - FULL COVER T/LID INSIDE HANDLE - HOOK TYPE SPEED SENS`G AUTO DR LOCK IMPACT SENS`G AUTO DR UNLOCKG IGN KEY REMINDER IGN KEY REMOVG AT DR UNLOCK CENTRAL DR LOCK/UNLOCK - DR`S CONTROL INSIDE HNDL OVER RIDE - DRIVER SIDE ONLY CHILD SAFETY RR DR LOCK`G FUEL FILLER DR MATERIAL - PLASTIC FUEL FILLER DR REL TYPE - ELECTRIC FUEL FILLER DR FINISH`G - BODY COLOR KEYLESS ENTRY-B/ALARM KEYLESS ENTRY-PANIC KEYLESS ENTRY-T/OPEN KEY TYPE - INSIDE CUTTING VALET PARKING (+SUB KEY) TYPE - SEPARATION IGNITION ILLUMINATED - BULB TYPE *** DR LWR STRIP LWR TRIM (MAIN TRIM) - PAINT MAP POCKET TYPE - FIXED BODY SIDE W/STRIP-RUBBER(SILICON COATG) DR SIDE W/STRIP - RUBBER(SILICON COAT`G) DR BLACK OUT MATERIAL - TAPE DR BELT LINE MLD`G - BRIGHT DR BELT LINE E/PIECE - NATURAL UPR GARNISH - FLIM INSERT FORMED TYPE - STD UPR TRIM FINISH`G - PVC CENTER TRIM - ARTIFICIAL LEATHER ARM REST COVER`G - PVC P/WINDOW DR`S - AUTO UP/DOWN & SAFETY P/WINDOW PA`S - NONE AUTO P/WINDOW RR DR - NONE AUTO FR DR GLASS - TINTED RR DR GLASS - TINTED FINISH`G - CR COAT`G LEVER FINISH`G - CR COAT`G AUDIO KNOB HTR CONTROL KNOB AMBIENT TEMP DISPLAY GARNISH PANEL - W/ TRAY DOOR TRIM GARNISH CTR FACIA PNL A/T INDICATOR SIDE AIR VENT T/C PILE - CARPET_STD CAR MAT - T/C PILE, STD FR - PORTABLE CIGAR LIGHTER - W/ ILLUM W/ LOCK W/ DAMPER W/ STORAGE BOX ARM REST - DLX(2 DIN) DLX - ARTIFICIAL LEATHER CUP HOLDER - FR(W/O ILL) TICKET HOLDER VANITY MIRROR COVER ILLUMINATED VANITY MIRROR - NON GLASS TYPE VANITY MIRROR COVER ILLUMINATED MATERIAL - CLOTH(STD) VANITY MIRROR - NON GLASS TYPE MATERIAL - CLOTH(STD) RR - 2 EA RR - 1 EA ROOF TRIM MATERIAL - CLOTH(STD) FR - 1 EA RR P/TRAY MATERIAL - W/PAPER LUGGAGE SIDE - W/PAPER RR - WALL PAPER FLOOR - WALL PAPER LUGGAGE NET HOOK LUGGAGE NET A PILLAR - STD B PILLAR - STD C PILLAR - STD W/ WIPER DEICER A` TYPE - CR COAT`G TOWING HOOK TIE DOWN HOOK(LASHING) ID PLATE - KOREAN TYPE TYPE - 2.5 MILE COLOR - BODY COLOR RR HEATED W/ TIMER BACK LITE GLASS TYPE- TINTED(W/ HEATED) MLD`G - CR COAT`G ELECTRIC FOLD`G CONTROL PASS`S SIDE - ELECTRIC HTD-CONV DRIVER`S SIDE - ELECTRIC HTD-CONV COLOR - BODY COLOR MLD`G-S/SILL - BODY COLOR MLD`G-ROOF - BLACK ACTIVE HEAD RESTRAINT HEAD REST - UP/DOWN & TILT SLIDING DOUBLE RECLIN`G ADJUSTER - HEIGHT ADJUSTER POWER SEAT LUMBAR SUPPORT - ELECT LUMBER SUPPORT SEAT BACK PNL(W/POCKET) SEAT WARMER (HEATER) - HIGH/LOW - SEESAW ACTIVE HEAD RESTRAINT SLIDING DOUBLE RECLIN`G HEAD REST - UP/DOWN & TILT SEAT BACK - SEAT BACK PNL(W/POCKET) SEAT WARMER (HEATER) - HIGH/LOW - SEESAW PRE TENSIONER - ELECTRICAL TYPE LOAD LIMITER S/BELT ANCHOR - ADJUSTABLE S/BELT ANCHOR - ADJUSTABLE DRIVER`S SIDE - ELR PASSENGER`S SIDE - ELR RETRACTOR PRETENSIONER - ELECTRICAL TYPE LOAD LIMITER W/O BOX DRINK HOLDER FOR 3 PEOPLE - BENCH-FIXED LH RH HOLDER - UPR ANCHOR ISO FIX CHILD ANCHOR SKI-THROUGH
Model No :
GFS4L561F
Car Name :
Engine No :
2009/11/05
Body Color :
RY
Description
