Rbx confirmed
6.990
12.965
www.raobanxe.com
raobanxe.com
Có nhiều ý kiến khác nhau về việc sử dụng lọc gió KN. Ngoài lời khen thì tiếng chê cũng không ít, nhất là khi sử dụng dầu quá nhiều khi rửa lọc gió làm hư cảm biến gió, maf, họ cũng nói rằng nếu lọc gió kiểu như KN tốt hơn lọc theo xe thì tại sao nhà sản xuất xe không làm lọc giống như KN, họ thừa sức làm điều này.
KN Airfilter reviews
1.In many cases, the addition of "high flow" or "high filtration" filters will cause poor performance or failure of emissions components.
An oiled air filter will often cause contamination of the MAF and may cause MIL illumination which would not be covered by an emissions warranty. The airflow change may also result in a variety of MIL events.
If the manufacturer thought they could do better with one of those filters, they would have installed that, the cold-air induction pipes and water injection at the factory. Save yourself some grief, man - keep it stock or OE-equivalent.
If you choose to ignore my advice, don't tell me about the MAF you have to buy, or the fact that XYZ shop charged you ____ dollars to replace your air filter when it wouldn't run right. (dslreports.com/forum/r20143269-KN-or-AEM-air-filter)
2.You'll get one of every kind of opinion here and you can take the advice offered in any one of them.
I've Run K&N filters for maybe 30 years in every kind of engine you can imagine. I've never had any kind of problem you can pin on an oil filter that's not working as well as the next one on the shelf. I put one in a 1980 Porsche 911 Carrera that I brought from Germany and that car is still running with almost 300,000 miles on it and the engine has never been out of it. It's still running just fine, with good leak-down tests and great compression.
Buy any of them, put them in and forget. They'll all work well enough for any of us.(tacomaworld.com/forum/2nd-gen-tacomas/159670-k-n-drop-filter-reviews.html).
3.Wow - old thread revival.....
I've had many K&N's over the years. They work great if you keep them cleaned regularly and you DO NOT over-oil them. I used to clean mine every 6 months.
The oils is what traps the fine dust particles. If the filter is dirty and the oils are already 'filled' with dust - then it can't filter properly anymore. They have good airflow and work great. I got slight MPG gains from using them.
In my current truck - I'm running the AFE. I do not get as much air flow as I did with the K&N's and I do not see any MPG improvements. The filter works fine and I don't clean it as often because I don't need to.
If I wanted more performance - I'd get a K&N.
If I wanted convenience (of having a cleanable filter) - I'd get the AFE.
4.The only people who ever have a problem with the K&N are those that over oil. There are some vehicles (my '05 V6 Altima is one) that have BIG problems with oiled filters, particularly in destroying MAF sensors, oiled correctly or otherwise. This truck is not one.
I shied away from K&N with this truck because of research I've done on them. You be your own judge on that one but I didn't like what I saw when it came to actual filtering. The AFE was a happy medium for me.
(MIL: Malfunction indicator light: CEL: Check engine light.)
Như vậy tốt nhất là thận trọng khi rửa lọc KN bằng dầu, không nên rửa nhiều dầu (over oiling). Sau khi rửa dầu thì rửa lại bằng nước sinh hoạt và phơi trong bóng râm cho khô rồi gắn vào hộp lọc gió.
Em cũng đã tìm được lọc KN sài cho Grandis, không cần phải cắt gọt, nhưng vụ này làm em lăn tăn quá.
Hay vậy bác part nó là gì bác... nếu được cho em xin thông tin...
1/4/07
21.919
17.467
Có nhiều ý kiến khác nhau về việc sử dụng lọc gió KN. Ngoài lời khen thì tiếng chê cũng không ít, nhất là khi sử dụng dầu quá nhiều khi rửa lọc gió làm hư cảm biến gió, MAF (Mass Air Flow Sensor), họ cũng nói rằng nếu lọc gió kiểu như KN tốt hơn lọc theo xe thì tại sao nhà sản xuất xe không làm lọc giống như KN, họ thừa sức làm điều này.
Như vậy lọc gió KN có khả năng ảnh hưởng đến cảm biến gió, tốt nhất là thận trọng khi rửa lọc KN bằng dầu, không nên rửa nhiều dầu (over oiling). Sau khi rửa dầu thì rửa lại bằng nước sinh hoạt để dầu trôi đi và phơi trong bóng râm cho khô rồi gắn vào hộp lọc gió.
Em cũng đã tìm được lọc KN sài cho Grandis, bản máy xăng, không cần phải cắt gọt, nhưng vụ này làm em lăn tăn quá.
Theo mình thì lọc gió K&N nếu dùng trên Động cơ xăng thì chỉ ở mặt tiết kiệm phụ tùng. Động cơ xăng, nhất là ở Việt nam chỉ sự dụng trung bình khoảng 1/3 cong suất, tối đa khoảng 2/3 công suạt nên việc nạp được gió vào nhiều hơn không có ý nghĩa (vì có bao giờ mở rông hét bướm ga đâu).
Đối với động cơ dầu thì rõ ràng nó có tác dụng nạp khong khí nhiều hơn, do dó có khả năng tăng công suất và lực kéo (công suât máy dầu lúc nào cũng yếu yếu).
Nói tóm lại, ý kiến của mình là dùng lọc K&N nếu nó kinh tế hơn (lọc nhà máy). Nếu dùng thì mình có thể bị các vấn đề mà bác Thi đã nêu.
Còn động cơ dầu thì nếu ai muốn động cơ mạnh hơn một tí, có thể dùng, cũng có tác dụng một chút.
Vì em mới thay cái lọc gió của K&N vào thấy tự nhiên tay lái nhẹ hẳn .
Lúc trước xe em đánh lái ở tốc độ de cũng khá nặng . nhưng khi em thay lọc gió xong thì em chỉ cần 1 tay cũng đánh lái dễ dàng dc.
Các bác cho em hỏi vậy lọc gió có ảnh hưởng như thế nào với trợ lực ?
Khi gắn lọc K&N vào thì động cơ chạy nhanh hơn (do lực cản ít, gió vào nhiều); động cơ quay nhanh hơn nên bơm lái dược nạp đủ vòng, có thể sau môt thời gian, ECU tự điều tiết lại thì hiện tượng này mất.
Chuyenj này tốt hơn bác nên đến AMC quan 4 gặp anh Bảo. nghe bác Innova222 nói anh ấy đã giải quyết xong chuyện này nhờ làm một khớp nối rộng hơn.
Reactions: trantrongthivn
6/8/14
134
45
Tân Phú
Vấn đề là grandis ko có, chứ có thì em đã xơi rồi bác ạ
Gắn được đó bác,K&N không làm lọc cho Grandis nhưng em bày cho bác cách này nhé,trước đây em đã làm qua.
1)Tháo lọc zin đo kích thước dài & rộng.
2)Vào trang knfilters.com,vào mục Search by Dimension,nhập thông số dài & rộng vào.Lấy mã lọc nào gần với kích thước của lọc zin nhất.Chênh lệch 5mm đổ lại là OK.
3)Mua được lọc rồi,cắt vát nhẹ 4 góc lắp vào vừa y.Vì lọc K&N vuông 4 góc trong khi lọc Grandis có 4 góc hơi bo tròn 1 tí.
Reactions: Rbx
