11
Tp.HCM
Em xài lọc gió K&N nhìn chung là tiền nào của đó bác à, đi máy nhẹ và ít hao xăng hẳn. Em lấy bên bác phong Nguyễn đó
tienhoa nói:
bác cho e hỏi lợi xăng nhiều không bác? E nghe nói đề pa x
808
10
Google là có hết bác ơi. Em phụ bác chút bề vụ bugi nè:
Q: How much of a performance improvement can I expect from changing plugs?
A:[/b] A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
http://www.ngksparkplugs..../faqpower.asp?mode=nml
6.178
Xe_chuong_ga nói:
NoiDayBinhYen nói:
Sao bác Chim với bác Gà thường đi cặp với nhau thế nhỉ:D
Ai thích của nợ ấy đâu bác! Dai như đỉa....hehe...
Nói éo biết nhục....éo biết ai là đỉa...kekeke....
10.172
565
Ô Cấp
Thientuan nói:
Buồn quá không có bác nào giúp e ah
Em giúp ngay từ đầu, bác có nghe em đâu, cái xe nó làm sao cứ vậy mà đi thui ạ, cái cần quan tâm là làm bảo dưỡng ĐÚNG VÀ ĐỦ, tránh mất tiền oan ạ....
