Re:Hành trình nghịch phá tập 2: [1 em matiz từ trang 3]...
CN ghé Gara để gắn thêm cái nắp cốp, chủ trước hay đi đánh golf bỏ ra cho đỡ vướng
vô tình thấy hàng thửa nhờ bác SUV chuyển bển về, ướm cái nào:
ây dà, vừa rồi, tháo bao cao su ra:
bình vẫn báo ok khi đang nghe nhạc:
Tuy nhiên, thấy đề có vẻ yếu hơn chút, khi bật máy lạnh và đèn nữa thấy bình xuống 10.5V, hix, chắc gắn thêm 1 bình nữa quá...hehe
Đọc thông số, chẳng hiểu gì...
[font="arial, helvetica, sans-serif"]
Infinity’s BassLink T has been developed to deliver great bass in pickup trucks, SUV’s and hatchbacks. Its low profile design allows it to be positioned in the confined space of a pickup truck, or behind the rear seats of a hatchback or SUV. Small in size but big in output, BassLink T requires produces enough bass to wake up the neighborhood. BassLink T consists of a 10-inch subwoofer, two 10-inch passive radiators and a 250-watt Class D amplifier housed in a great looking rigid polymer enclosure, all carefully engineered to work together as a unique, integrated system. The extremely versatile BassLink T accepts both speaker-and line-level inputs, and it provides an internal low-pass filter, proprietary signal processing and abundant amplification. User-adjustable controls allow listeners to set the system’s response to achieve optimum performance based on the vehicle’s cabin gain or transfer function. These controls include: a 0 or 180-degree phase switch; a continuously variable electronic low-pass filter that is adjustable between 70 and 170Hz; variable input sensitivity; and Bass EQ that provides for adjustments between +3 and –6dB. At maximum gain, the system can accept inputs as low as 250mV. [/font]
+ Specifications
- Power Output: 250 Watts RMS
- Frequency Response: 20Hz - 170Hz
- Variable Bass EQ: +3dB to -6dB at 45Hz
- Variable Electronic Crossover: 70Hz - 170Hz
- Phase control: 0 or 180 degrees
- Preamp Level Inputs: 250mV - 4V
- Dimensions (H x W x D): 14-3/8 x 40-3/8 x 6-7/16
BassLink T includes a remote level bass control allow adjustments to be made from the drivers position. [/font]
