RE: hỏi về C/S ở số tự động
Các bác phải xem là model gì sản xuất năm bao nhiêu chứ. Chủ thớt đang băn khoăn về C-2008 mà. nêú là C-2008 thì hình phải như thế này:
Và được chú thích như sau (trong HDSD):
C Comfort
for a comfortable driving style
S Sport
for a sporty driving style
Press program selector button repeatedly until the letter C or S for the desired drive program appears in the rev counter's multi-function display.
If either automatic drive program C or S is selected and you restart the engine, the automatic transmission will always switch to drive program C.
Drive program C is characterised by the following:
comfort-oriented engine and suspension settings.
the vehicle pulling away more gently in forward and reverse gears, unless the accelerator pedal is depressed fully.
increased sensitivity. This improves the driving stability of the vehicle on slippery road surfaces, for example.
the automatic transmission shifting up sooner. The vehicle is driven at lower engine speeds and the wheels are less likely to spin.
Drive program S is characterised by the following:
sporty engine and suspension configuration
the vehicle pulling away in first gear.
the automatic transmission shifting up later.
Kết luận: Như vậy cũng là C/S nhưng ở các model khác nhau thì có thể nghiã khác nhau.
