RE: Lancer Evolution
Engingeering: EVOLUTION VIII
Engine Type: Inline-4
Engine Block: Cast Iron
Cylinder Head: Aluminum Alloy
Displacement (liters / cu.in. / cc): 2.0 / 121.9 / 1997
Horsepower @ rpm (SAE net): 271@6500
Torque (lb-ft @ rpm): 273@3500
Redline (rpm): 7000
Bore and Stroke (mm / in): 85.0 x 88.03.38 x 3.46
Compression Ratio: 8.8:1
Valvetrain: DOHC 16-Valve
Valve Cover: Magnesium
4-Wheel Ventilated BREMBO® Disc Brakes with Aluminium Caliper Housings:
Fuel System: ECI-MULTI Electronic Fuel Injection
Engine Oil Type: 100% Fully Synthetic Oil Required
Turbocharger Type: Twin Scroll Turbine
Drive Train: Full-Time All-Wheel Drive with 50/50 Viscous Coupled, Center Differential, Front Helical Limited Slip Differential and a Rear Mechanical Limited-Slip Differential.
Transmission Type: 5-Speed Manual
Front Suspension: MacPherson Strut with Inverted Shock Absorber, Forged Aluminum Lower Control Arms, Stabilizer Bar and Front Strut Tower.
Front Stabilizer Bar Diameter (mm): 24
Rear Suspension: Multi-Link Wishbone Configuration using Forged Aluminum Trailing-Links, Casted Aluminum Cross-Member and Stabilizer Bar.
Rear Stabilizer Bar Diameter (mm): 22
Wheels Type: 17" x 8" Enkei®Light-Weight Alloy Wheels
Tire Size: 235/45 R17 93W Yokohama ADVAN® high-grip tires
EPA Fuel Economy (City/Highway): 18/26
Recommended Fuel: Premium Unleaded
*Estimate to be used as a standardized comparison with other vehicles. Your mileage may vary depending on driving style and environmental conditions.
HID(High Intensity Discharge) Headlights with Auto-Off:
Projector Halogen Headlights:
Reflector-Type High Beam Headlights
Built-In Fog Lights:
Front and Rear Color-Keyed Bumpers
Black Front Grill Mesh
Front Center Bumper Air Inlets
Aluminum Hood with Heat Expulsion Vent
Aluminum Front Blister-Type Fenders
Twilight Side Marker Lights
Front Intermittent Fixed Wipers and Washers
Front Intermittent Variable Wipers and Washers
Rear Window Intermittent Fixed Wipers and Washers
Rear Center Roof Antenna
Clear, Jewel-Style Rear Taillights
Dual-Model Muffler with Variable Back-Pressure Valve
4" Chrome-Plated Single Tailpipe
Large Carbon-Fiber Rear Spoiler
Tinted Glass and Windshield Shade Band
Electric Rear Window Defroster with Timer
Front Underbody Aero-Dam
Tinted Solar Control Glass
Power Slide and Tilt Sunroof: Pkg
Headroom (in., front/ rear) [with Sunroof]: 39.9/36.7 [39.1/36.4]
Legroom (in., front/rear): 43.0/36.6
Shoulder Room (in., front/rear): 54.1/53.3
Hip Room (in., front/rear): 51.2/50.2 51.2/50.2
Passenger Volume (cu. ft) [with Sunroof]: 95.1 [93.7]
Cargo Area (cu. ft.): 10.2
Maximum Seating Capacity: 5
Customized MOMO® 3-Spoke Leather Wrapped Steering Wheel:
Power Windows & Door Locks
Height Adjustable Steering Wheel
Illuminated Ignition Key Cylinder
Manual Heater and Air Conditioning with Multi-Speed Climate Control Fan
Leather Wrapped Shift Knob
Leather Wrapped Parking Brake Lever
Glove Compartment with Light
Dual Visor Vanity Mirrors
Floor Mats
Remote Hood, Fuel Door and Trunk Releases
12-Volt Accessory Outlet with Illumination
Assist Grips x3
Front Map Lights
Front and Rear Cup Holders
Center Console with Storage Compartments
Center Console with Armrest and Storage Compartments
Cargo Area Light and Trim
Customized RECARO® Front Sport Bucket Seats: Cloth - Std (Leather Opt)
Highback Rear Seats With Rear Center Armrest with Cup Holders
Rear Seat LATCH system (Lower Anchor and Tethers for Children)
315-Watt Infinity® Premium AM/FM/CD Audio System with 7 Speakers
In-dash 6-CD Changer
170 MPH, Full-Scale Black-Faced, Full-Time Red Illuminated Instrument Cluster
Center-Located 9000 RPM Tachometer
Digital Odometer and Tripmeter
I/P Mounted Headlight Leveling Control
Auto/Manual Intercooler Water Spray Switch
Full-time AWD with Viscous-Coupled Center
Limited-Slip Rear Differential
Helical Torque-sensing Limited-Slip Front Differential
Dual Front Air Bags
Front Seatbelt Pretensioner with Force Limiter
3-Point Seatbelts and Headrest for all Occupants
Rear Door Child Safety Locks
Rear Seat LATCH System (Lower Anchors and Tethers for Children)
Front and Rear Crumple Zones
4-Channel, 4-Sensor Sport ABS with Steering Angle and G-Force Sensors
Electronic Brake Distribution (EBD)
Trunk Entrapment Release Handle
Anti-Theft Engine Immobilizer
Keyless Entry
Evo này cũng có twinturbo đó các bác ạ.
